Question about Kitchen Ranges
GE COOKTOP JP950BKBB PROBLEM: F153 ERROR - Kitchen Ranges
  • Anonymous May 02, 2009
    Got the same problem with my GE Profile 36" Built-in CleanDesign Cooktop. any solutions?
One of the burners has a open heat sensor. Have to replace burner assembly.
Posted on Oct 02, 2009
What is ge error code 0225
I have the same issue and was told by GE that it will take a technician to fix it because it is not a known error code. Most error codes start with "f", F0, F1, etc. This the second time a tech had to come out for this cooktop. Probably the last GE I buy. Definitely won't buy anything electronic. I want regular knobs on the next one.
May 05, 2014 | General Electric Ge Profile Pp975bmbb 36...
GE Monogram f160 error code?
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
May 03, 2014 | GE Monogram ZEU30R Electric Cooktop
GE F105 error
According the service guide, an F105 error is "Zero cross failure"
Correction action is:
(1) Recycle power to the cooktop (i.e. turn breaker off and on)
(2) If fault persists, test the line voltage supplied to the cooktop at the wall outlet. Voltage should read from 175VAC to 265VAC. If it does not, there is a problem with the power being supplied to the cooktop.
(3) If fault persists, replace power board
(4)If fault persists, replace main (Logic) board and recalibrate elements.
Mar 31, 2013 | GE 30 in. Profile JP939 Electric Cooktop
What does the code f153 mean
The profile means GE Kitchen Ranges and the code F153 means the two front elements (burners)
Jun 26, 2012 | GE Kitchen Ranges
Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
May 21, 2009 | GE Cooktops
Error code F153
Did anyone ever find out the solution to this issues. I have the same f153 fault code and want to know how to solve this
RLA
Jul 17, 2008 | GE 30 in.JP950 Electric Cooktop
Error code
Same thing happened to me. Reset your stove top by flipping your fuse off. The stove top will reset and the error code will go away.
Jan 21, 2008 | GE 30 in.JP950 Electric Cooktop
One unit show fault code F153
Hi - I've been having the same problem. GE tech service in St. Louis, MO has been a joke. 1st tech call cancelled 30 minutes before appointment. 2nd tech call to diagnose the F153 code I had already provided when I scheduled service on-line cost $74.95 and the tech didn't have the part on his truck. 3rd tech call a new tech shows up, has no knowledge of previous call diagnosis, opens the box sent to my home by GE and announces that the previous guy ordered the wrong part! We're on the 4th call. My cook top right front burner has not worked for a month. I've contacted GE corporate. The part you need (at least I need) for the right front burner which is a large burner is: WB30T10062. If I knew how to, I'd repair this myself. I don't have the extended warranty. The part is covered because my cooktop is only two years old (parts warrantied for five years) but labor is estimated to cost almost $200....plus the $74.95 "diagnostic" visit. A total rip-off. My advice, if you've got this cooktop, it's still under warranty and you aren't using all of the burners on a regular basis: start using them! The tech guy said most people use that front right burner alot and it eventually malfunctions (code F153). His suggestion was to start using the other burners on a regular basis, too, so that when they go out, at least the part will fall under the five-year warranty! When this cook top is done, I'm going to get a gas stove with "old fashioned burners" and it won't be GE!
Sep 24, 2007 | GE 30 in. Profile JP938 Electric Cooktop
Kitchen Ranges Logo
463 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
