Question about Mitsubishi WS-55807 TV
Mitsubishi WS 55807 TV
I press the power button and it clicks and the green light comes on for a second then it clicks and blinks again and powers off, the picture never comes on. I ran the diags and recieved error code 2-4, thanks for any advise. I also noticed the day before that the sound would go real low and then come back , not sure it this is related. Thanks
  • ec3de Sep 18, 2008
    I did not see any corrision or fluid on any board, sincde the error code in diags is 2-4 which the service manual indicates is a vertical adjustment failure , what can I do to fix that problem and what is a vertical adjustment failure, thanks again for you quick response, have a great day.
    Novelist:
    Champion:
  • 203 Answers
2 common things that cuase this problem. The first is a fluid leak and I think of this first because you had a audio problem and now you have a dead set. To look for a fluid leak take the front off the set and look on the boards in the bottom of the set with a flashlight for fluid or corrosion. The second problem would be the convergence circuit shorted out. To check for this you will need to be able to use a meter. There are 2 pico fuses (F9A04, and F9A05) If one of these are open you will need to change the stk's and the blown fuse. If you donot have a fluid leak and cannot find the fluids, you can post a picture of the boards inside and i will circile them for you. Let me know if you need more help!
Tim Nolan
Posted on Sep 17, 2008
Tv wont power up?
could be buttons,unplug them and try remote, or the convergence ics are bad
http://www.shopjimmy.com/
Aug 25, 2012 | Mitsubishi WS-55807 TV
Mitsubishi VS-70707 rear projection TV
DOES THE LIGHT BLINK IN A PARTICULAR PATTERN?
Jan 31, 2008 | Mitsubishi WS-55807 TV
When you turn on power you hear a click and the green light turns on. Three seconds later you hear another click and the green light turns off.
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and"menu" buttons on front of tv for at least 5 seconds and then release bothtogether.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Let me know what you find and I will assist you.
SD TECH
Aug 31, 2011 | Mitsubishi WS-55807 TV
When i go to turn the tv on the green light go on and then off. i did the coe test error code repeated 10 times
I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again
Jan 02, 2011 | Mitsubishi WS-55807 TV
My mitsubishi television ws-55807 went out while watching it, what can i do to solve this problem?
If power light comes on and then goes off do the self check this set has:
when light goes off and front of set press and hold both the menu and Input (device) buttons in at same time for at least five seconds and release both buttons.
The set will (the power light) blink a two digit error code like, 2 blinks, 2 blinks, a pause and repeat the code several times.
2,2 is most common error code, let me know what error code if any you find and comment here and I will tell you what it means.
The self check is designed to narrow down where a problem is.
SD TECH
Dec 04, 2010 | Mitsubishi WS-55807 TV
TV won"t stay on turns off in 3 seconds WS 55807
Do the self check when power light goes off.
On front of set press and hold both the menu and input buttons for 5 seconds or longer and release both buttons.
Power light will blink a error code like: 2 blinks, 2 blinks, a pause and repeat about 4 more times.
Let me know what error code you find and I will tell you what it means.
If this information told you something rate this solution as very helpful as I do this here for free.
SD TECH
Aug 28, 2010 | Mitsubishi WS-55807 TV
I have no picture or sound when i hit the power button it clicks off
Please do the self check this set has:
When the power light comes on and goes out press and hold both the MENU and Input (also called Device) buttons at the same time for at least 5 seconds and then release both buttons.
The power light will blink a two digit error code--for example--2 blinks, a pause and 2 blinks.
Let me know what error code you find and I will tell you what it means and what may actually be the problem.
I am here to help people.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 18, 2009 | Mitsubishi WS-55807 TV
Mitsubishi WS 55807 wont turn on
SECONDARY POWER SUPPLY IS OUT
Dec 05, 2009 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 Will Not Power On
first off you should replace both convergance IC and check the resisters coming off the output if any of the resisters are bad it will trash the ic on trying to power up.
i would also replace the caps in the DM section
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://chrisandnat.com/projects/blinkingtv/blink.htm
Dec 19, 2007 | Mitsubishi WS-55807 TV
WS-55807 doesn't power on
1) Check all fuse devices in power supply
2)Pc board with transformer possibly defective.............T.
Nov 07, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55807 TV Logo
96 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
