Electrolux W355H won't wash, error 08E
Machine starts in normal way, rinses powder from fist tray, starts cycle, but as soon as cycle 2 supposed to be started, machine stops with error 08E- "increase in water temperature is is below parameter set". Powder still remains in tray 2 dry .
What should I check first?
  • jackdz
    jackdz Sep 17, 2008
    PS: When selecting modes in manual, e.g. "pre-wash", "main wash", "rinse"- everything works OK. Error appears on the screen on automatic mode at the moment when program has to jump to another step of cycle. Seems to be program error?
4 Suggested Answers
TheMobilian
  • 8205 Answers
SOURCE: LG front loader empties softener tray and
LG frontload washer service guide
Posted on May 13, 2010
SOURCE: washing machine wont fill with water-hoover performance 1100
check that the water inlet pipe is not blocked. it does have a filtewhich can get blocked with lime scale.
Posted on Jul 24, 2010
  • 3287 Answers
SOURCE: which of the 3 dispensers
You can read the manual here.
In short page 15 describes the chambers as follows:
  • The chamber marked "I" is the prewash detergent.
  • The chamber marked "II" is the main wash detergent.
  • The chamber marked with a flower like icon is the fabric softener.
Page 14 describes how to prepare for your first wash by running it without clothes for the very first time to remove water left inside from the factory during testing. Do not skip this important step! You only have to do this once.
I hope this helps & good luck! Please rate my reply. Thank you.
Posted on Apr 06, 2011
Testimonial: "this was so helpful and 'to the point' whereas other web sites gave me a roundabout course and couldn't even print the text. thank you"
  • 9 Answers
SOURCE: washing machine seems to not fill up with water or come through to wash the powder out of the draw.
control board issue
Posted on Mar 29, 2012
Why my washing machine will start the wash cycle but will not spin or rinse?
the drain pump is probably blocked or overheating, when it starts beeping which lights are flashing reading from right to left e.g. 1,3,5 also what is the model number?
Aug 17, 2014 | Fisher and Paykel Washing Machines
I have a Whirpool FL AWM285 800. Half way through any cycle it stops ( usually before it is supposed to pump out or rinse any water ) by turning the dial it it starts again but stops again when it has to...
CHECK TO MAKE SURE BOTH HOT AND COLD WATER ARE WORKING.IF IT TRIES TO FILL WITH COLD WATER LIKE FOR A RINSE CYCLE AND NO WATER COMES IN, IT WILL SHUT DOWN. THIS MAY ALSO EXPLAIN THE POWDER NOT DISPENSING.WHERE THE HOSES CONNECT TO THE BACK OF THE MACHINE THERE IS SCREENS YOU CAN CLEAN.GOOD LUCK!
Jan 15, 2010 | Whirlpool AWM8143 Front Load Washer
My Haier HW-C1460TVE-U washing m/c keeps giving (CLrF) ERROR Code
Anyway, my machine shows an error code "clrf". I just spoke to someone at Comet, and apparently this means there is too much foam in the machine. The machine will then refill with water and try to rinse it out, but if after that the machine still has too much foam in, then it will stop the cycle. Hence why my clothes are still wet (although I'd not realised they weren't rinsed properly either!).
I have not been using excessive amounts of washing powder, and usually use powder tablets or the liquid tablet sort, so they are a set amount and I don't do anything daft like stick 6 tablets in! I find it ridiculous that this would cause a problem with the washing machine, as I've used them perfectly fine with other washing machines.
Anyway, the advice from Comet was to keep trying different washing powders until i find one that foams less.
Jan 07, 2010 | Haier Washing Machines
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
Put washing powder in tray ,machine doing wash but leaving large residue of powder
Don't put the powder in the tray. Select you wash cycle, let the water run into the washing machine, then add the powder.The powder should dissolve before you put your clothes inside the machine. Let the washing machine fill up to almost half way and add clothes. This should stop the clothes from getting the residue powder on it.
Mar 23, 2009 | Whirlpool Washing Machines
Washing machine starts by itself
going through to the next wash not na normal function, perhaps the machine is advancing to an extra rinse cycle?? this EXTRA RINSE will start after the normal wash is complete, i would check your dial settings perhaps some one has mistaknely switched extra rinse "ON". if htis os not tyhe case the n i would jave to blame a faulty timer mechanism and you would need to replace the timer
Feb 15, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Descale
With the selector buttons find Descaling and press OK
This process takes about 35 minutes
1. Empty the water tank, drip tray and grounds container.
2. Insert tray and grounds container, refill tank with with 0.5 Lt. of water and add descaling agent (not the pill or powder used for clean cycle) to tank. Make sure its completely dissolved.
3. Place a container or cup under the steam wand large enough to hold 0.5 lt.
Display says Descaling and press OK
4. Press the water button
Display says Descaling in Progress
after the descaling agent is exhausted
Display says Empty Drip Tray and Spent Grounds
5 Also remove rinse and refill the water tank to Max line
6. Press the water button again
after the machine stops
7. Empty the drip tray and spent. ground container and replace
Display says Rinse Press OK
Display says Appliance Ready
In essence go to Descaling Press OK and follow the directions as they are displayed.
Aug 02, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Washing Machines Logo
846 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
