At the top of the brake pedal is a mounting bracket that holds the pedal in place,, on that mount, and the pedal, is a bushing that goes bad,, the hold down bolt goes right through it, if this bushing is bad, it will allow the pedal to move slightly from side to side, if however if your pedal has a lot of movement,, you need to check the bracket in total, follow the brake pedal up under the dash,, and check the mounting bolts
