Question about Xerox DC470ST Color Copier
IT WONT WORK
THE MACHINE HAS BEEN TURNED OFF FOR SOME TIME, WE HAVE NOW RELOCATED IT, IT TURNS ON BUT THEN SAYS PRINTING FAULT, PLEASE CALL FOR ASSISTANCE> WE HAVE ANOTHER XEROX AND WE USED TO PUT A CODE INTO THE PAD , ANY IDEAS WOULD BE MUCH APPRECIATED .
SIAN X
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Xerox Master
  • 1,362 Answers
Here is how to print the fault codes.
http://www.office.xerox.com/support/dctips/dc99cc42.pdf
Not sure if it tells you how to clear or to call Xerox with the codes and know what is going on.
Good luck
Posted on Sep 17, 2008
How do I fix my fax machine so that it does it's job. By that I mean how can I make it print and fax?
First .is the machine in an error state on the display?
2nd. You MUST use the line lead and adaptor that the machine came with for the tel line. Others just wont work and you may get a dial tone but it wont receive as it wont detect ringing current.
As for not printing, does it make any sounds when you send it a print job or print a report from the keypad? Did it work with its previous owner? To reset the unit you have to enter the following on the keypad within 3 seconds to get it into the maintenance mode. Press *2864* that's star2864star. When it says "Maintenance" then enter 01, it will then go back to maintenance. Now press 55 to reset the scanner. When back in maintenance again the press 02, when back in maintenance again press 99 to exit it. All should work now and it will be as it was when it came out of its box. If this does not work then it has a circuit board fault and wont be worth repairing. Its a very very good machine. As an ex brother engineer I can say it was their best machine.
Jan 21, 2015 | Brother IntelliFAX 4100 Laser Fax
Hp psc 1401 printing slow problem
Reset and relocate the productA power reset drains power from the product and returns the product to the same settings after restarting. To eliminate any potential power deficiencies that might hinder a successful alignment, HP suggests you move the product to another location and plug the product directly into a wall outlet. Follow these steps to reset and relocate the product.
  1. Press the On/Resume button to turn on the product.
  2. With the product turned on, disconnect the power cord from the back of the product.
  3. Relocate the printer to a different power outlet, preferably an outlet in a different room.
  4. Plug the power cord directly into the wall outlet. Do not use a power strip, extension cord, or surge protector. CAUTION: Do not reconnect the power cord to the back of the product at this time.
  5. Load letter or A4 size unused, plain white paper in the tray.
  6. Reconnect the power cord to the back of the product.
  7. Press the On/Resume button to turn on the product. The product automatically prints an alignment page.
Oct 13, 2009 | HP PSC 1401 All-In-One Printer
My HP scanner in my all in one wont work
I called HP and they told me that the reset for this is unplugging the power cord from both ends and waiting for a count of 60. At first this worked but each time the power goes out in our home, the next time I turn it ion, it does this and tells me there is a scanner error after trying to initialize. Keeps running back and forth somewhere inside and not clicking in. Unplugging and counting no longer work. One day I fooled with it all day and it finally stopped. Now power went out again and it's happening all over again! Very frustrating. Can anyone help?
Oct 07, 2009 | HP PSC 2210 All-In-One InkJet Printer
Samsung washing machine F1245 control panel stuck??
I have Samsung/korea-SW905Washer.When power is switched on the Fault-'1E' appears. what could be the reason.( narrate list of control component failure).
Bought in the year 1996 at India ( voltas mega washer top loading-7.5kg) and working till last month.
after few wash cycles the machine stopped at aforesaid indication and it is not functioning due to above fault indication'1E'
provide me remedial measures or electronic control board circuit.
May 29, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
Turned off my printer and now it wont turn on
If you can't see the lights on the panel it might be the power adapter or the connection at thre printer itself
Feb 11, 2009 | HP Photosmart C4180 All-In-One InkJet...
Samsung washing machine - no power
checked internal wiring and found that when the machine went out of balance the counter balance on the top of the agitator drum had squashed the power wire against the the top rib of the frame causing the wire to short circuit and blow the power fuses to the house.
rejoined the power witr and relocated it above the rib frame so as to eliminate any further possibility of this happening again.
I believe this is either a design fault with the machine or it was incorrectly installed at the time of manufacture
Sep 05, 2008 | Washing Machines
INDESIT WI101
hiya
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Indesit W 123 Front Load Washer
Buttons don't work
Hi, please try to turn the machine off. If the machine wont turned off using the power button, unplug the power cable. Wait for 10 to 15 sec. then turn the machine on. Try pressing the menu or setup button. If that works thats good but if not you may need to call the machine manufacturer for service.
Tirzo
Jun 12, 2008 | Samsung SCX 4521F All-In-One Laser Printer
System Fault
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Jan 29, 2007 | Xerox DocuColor 12 Printer
Xerox DC470ST Color Copier Logo
120 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
