Question about Sharp CD-BA2100 CD Shelf System
Sharp BA2100 3 CD mini component system - NO DISC
With cd's in the tray, it cycles thru 1, 2, 3 looking and then displays NO DISC
  • Stu Berman Sep 17, 2008
    Dan,
    Thanks for the suggestion
    What is the easiest way to get to the optics. Do I need to take it apart to get to the optics?
    Thanks again
    Stuber
  • 4,234 Answers
This is a relatively common problem when the optics get dirty. If you can reach the lens, try cleaning it using a cotton swab and alcohol. Don't bother with the "cleaning discs" available as all they can do is bruch off the dust. These lenses sometimes get a smoke or dirt film on them that the brushes can not celan.
Keep us posted.
Dan
Posted on Sep 17, 2008
  • ABRsvcs Sep 17, 2008
    I haven't done one of these in a while, but I think that if you remove the side panel, you can get to the optics. You don't need a lot of room, all you need to do is to reach the lens itself. I can look up this tonite, I just don't have the manual with me and I'm on the road at the moment. If you can't easily get to the lens from the side, let me know and I'll update this tonite. Updating this will place it into a "recent" queue so I can find it quickly.
    Thanks,
    Dan
Cd tray will not open er cd11 code
Just talked to customer service at Sharp because I had same problem with my CD trays getting stuck and would not open even if they had cd's in them. He walked me through resetting the cd system. First have unit plugged in but in standby/off. Then press the open/close button, the stop button and the CD button all at one time(beside holding unit still to keep from sliding) till the display flashes CLEAR ALL and then let go and turn unit on and see if it solves your problem. It solved mine but I did write down instructions to make sure if it happens again I can use it again. Good luck, Helen
Jan 03, 2014 | Sharp HE CDDH950P Mini System
Cd component not working
Hi Bearo
Here you can find an online manual,
And here the specific troubleshot section.
When you say the tray dosent open, is there a CD inside, or is it empty?
Jan 02, 2008 | Sharp XL-ES50 CD Shelf System
I CANNOT GET THE CD DRAWERS TO OPEN ON MY SHARP MINI COMPONENT SYSTEM MODEL CD-DK890N
Chances are the loading mechanism is out of alignment. Very hard to realign this mech. even the manufacturer just replaces the entire mechanism when repairing.
Dec 08, 2013 | Audio Players & Recorders
I need a FM antenna X 1 (92LFANT1535A) for Sharp Mini Component System model CD-DK890N
Try these web sites:
http://search.aol.com/aol/search?&s_qt=sb&q=Sharp+mini+cd-dk890n+parts&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
http://www.partstore.com/Model/Sharp/Sharp/CDDK890N.aspx
Jan 20, 2013 | Audio Players & Recorders
I have a Sharp CD-DK891N Mini System. The 5 tray CD system will not play any CD's, there isn't anything stuck in any of the trays. How do I get the CD 's to play??? Any help would be appre
Get a CD cleaning kit and follow instructions, if no change the laser pickup assembly will need to be replaced, far cheaper to buy a new player.
May 12, 2012 | Sharp Audio Players & Recorders
Sharp cd-bp1200w cd carriage will not open power is ok display ok . cds locked inside!
On my sharp CD-BA 1200 most cd's do not run. It is the problem that has recently occured. Kindly suggest solution.
Mar 14, 2010 | Sharp Multi-System Mini Component System...
My radio
I have this system
Not working right now
gstudeny@comcast.net
Mar 29, 2008 | Sharp CDBA3100 Remanufactured Mini-System...
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Sharp CD-BA200 MIni Component Stero System
I've been messing with mine because it says no disc and I messed it up so it started saying this error. Unscrew the screws around the top (4 screws) and slide off the top cover. The small black rectangular box that sits over the eye/laser can be removed carefully by compressing the clips. Then the cd tray can be removed. I figured out this error was coming up because I had the tray out of alignment... so try to see if that's the problem with yours... also the eye itself slides (the entire mechanism it's on... slides away from and towards the place where the cd sits to be lifted and read) and it should be as close as possible to the area that lifts the cd. Sorry if this isn't making sense... trying to explain in the best way possible. The tray being out of alignment causes that error though.
Dec 15, 2007 | Sharp CD-BA200 CD Shelf System
Sharp CD-BA2100 CD Shelf System Logo
307 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
