Question about Evesham Computers & Internet
I would like to install more RAM on an evesham desktop PC. There is no tech support now - how do I determine what spec RAM to buy?
  • esorted Sep 22, 2008
    I have started a new thread now - I didn't see this 'Add a Comment' box, sorry!
  • 449 Answers
What Ram u are using SDRAM? DDR? or DDR2?
try to open ur desktop cpu casing then and there is a label in the memory if it is a SDRAM? or DDR? or DDR2?
put the exact memory!!! read if it is SDRAM? or DDR or DDR2
if it is different it my cause damage to your motherboard
Posted on Sep 17, 2008
  • 441 Answers
You need to check that on the momery installed on your computer or if you can find the brand and model of your motherboard(mobo) you can find what memory you need by going to the manual of the mobo (you can go to the mobo's website and check the manual, it will list the compatible memory module fo your mobo).
Replace power supply
It should work provided the components do not draw more than 400W.
If the wattage is exceeded these switch mode power supplies usually automatically shut down.
I recommend you install a switch mode power supply over the 420W rating.
Aug 14, 2012 | Evesham Axis PC Desktop
I wanted to get my acer aspire T180-UA381B upgraded, and I know very little about computers, how much and what kind of ram should i put in to make it run fast
Based on your memory specs below the maximum RAM that you can install in your computer is 1GB
DDR2 SDRAM and you can get 1GB RAM for like $15 -$ 20. 1 GB DDR2 SDRAM is what you need to buy.
Your Memory Specs:
Installed Cache Memory: 256.0 KB
[close] Installed RAM: 512.0 MB RAM, or Random Access Memory, is the place in a computerwhere the operating system, application programs and data in current use arekept so that they can be quickly reached by the computer's processor. Theamount of RAM you have affects how quickly you will experience your computerworking.
[close] Installed Video Memory: 512.0 MB
[close] Max Supported RAM: 1.0 GB
[close] Number of Memory Slots: 4 x 240 Pin DIMMs
[close] RAM Technology: DDR2 SDRAM
Feb 11, 2011 | Acer ASPIRE T180-UA381B DESKTOP PC
How do i increase ram in my evesham notebook model no8615
go to a store or online store such as best buy or radio shack and purchase laptop ram (1gb, 2gb, 4gb, etc.). on the bottom of your laptop remove the ram panel and switch the ram so you have more ram.
Jun 27, 2010 | Office Equipment & Supplies
I want to increase ram, what do I get
First, you have to find out the max of ram that you can add to your pc. Then go to the website and run a test where it will tell you what memory and how much you can add. If you decide to purchase the memory and after you recieved , open the case and locate the empty slop where the memory is going to be install. It should be the small slots not the white big ones. Then carefully open the case from the memory and then put i on the slot of the pc. Turn the pc on and then see if it recognize it
May 24, 2010 | Systemax Tiger (SYXS-DC-1000) PC Desktop
Memory for computer
Hi, that machine will take DDR266, DDR333, or DDR400 RAM according to the Tech Specs. All the RAM in this class uses the same form factor, so they're interchangable on motherboards, but the higher speeds run faster. You can find the specs here:
May 13, 2009 | Balance CP4401 PC Desktop
Conflicting information about maximum memory allowed
Your problem is not so clear. I guess you are having a P-4 with MSI Mother board. Almost all motherboards that support DDR 333/400 can support up to 2 GB of memory.
It is always better to buy brands like kingston.
Sep 12, 2008 | Evesham Axis PC Desktop
The correct RAM update for an Evesham Evolution 2600 Si Desktop computer?
try this crucial run it and it will tell more about the ram whats installed and the max you pc will hold. ,(note you do not need to buy the ,memory from here )
Apr 24, 2008 | Computers & Internet
Dell Dimension 8250 Memory Question
Computer Memory Information Upgrade Questions Troubleshooting Memory Diagram Upgrade Help Buying Tips · Memory definitions. MEMORY ABCs. Memory, which is commonly referred to as RAM
Installing PC computer memory Additional information and help with isntalling PC computer memory. ... Installing a PC computer memory. Question:. Installing PC computer memory.
Determining type of hardware within computer Reference, Issue / Question. Memory, Information and help with computer memory. CH000149, How to determine system resources / RAM available?
Buying tips on computer memory. How much memory should I get? This question really depends on the type of computer user you're and what type of programs you plan on running on the computer
Determining what type of memory to use in a memory upgrade. Determining what type of memory to use in a memory upgrade? Question:. Determining what type of memory to use in a memory upgrade.
E-mail CHID: 5683
Good Luck read and follow instructions will find your answer.
Good Luck, Please dont for get to Vote/Thank You.
Dec 20, 2007 | Dell Dimension 8250 PC Desktop
Computers & Internet Logo
91 people viewed this question
Top Evesham Computers & Internet Experts
Simon Clarke
Level 1 Expert
Lakshman P
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
