Question about HP Office Equipment & Supplies
I have an HP Photosmart C5280 All-in-One Printer, Scanner, Copier. I had a paper jam, which has been removed. However it keeps telling me there is a paper jam and will not work. I have had the back off the top up looking with a flash light and I can see no further jam. is there a way to reset the printer? or some thing more I can try?
  • 4,472 Answers
How long have you owned the printer. If after troubleshooting you still have the problem. It may be the best Idea to have a professional take a look at it. As an issue like this is not terribly difficult to fix by a professional. If you need assistanc locating the nearest authorized service center let me know.
Thanks,
Lee
Posted on Sep 17, 2008
    Genius:
  • 1,142 Answers
Well there is definitely a paper piece stuck somewhere in the printer you have to look into it very carefully, you can use a compress air or a vacuum to blow air into the printer that will blow away the stuck piece.
  • HP Master
  • 6,487 Answers
Try checking this link this might help you in clearing this error message http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00909241&lc=en&cc=us&dlc=en&product=3204464
Hope that helps...........
    Sergeant:
  • 399 Answers
May be the sensor which detects if there is a paper jam or not is slightly moved from its orignal position so it is continuosouly telling that there is paper jam witout any jam.the sensor is located on the back of the printer.slightly tab on both the sides of the printer it may come in its exact position if some thing is blocking the sensor .its black in colour, its very thin, its very delicate.so do it carefully.tapping may help so please try tapping slightly on the printer.
for anything else let me know.
thanks.
  • masterexpert Sep 17, 2008
    just check whether any paper particles hve misaligned the sensor position or is it broken.
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
  • Anand Kumar
    Anand Kumar Sep 22, 2008
    A paper jam might result if photo paper is specified in the
    Document Properties
    dialog box
    but plain paper is loaded in the product.
    Scholar:
  • 148 Answers
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
  • Zander Rovic Ocampo
    Zander Rovic Ocampo Sep 17, 2008
    if you still face the problem then try this:
    1. Check the printer and/or the software to see if "manual
    feed" is selected. If manual feed is selected, the printer may be
    looking for paper in another tray.
    2. Re seat paper. Ensure printer is on-line. Check for paper jams or obstructions.
    3. Likely suspect: paper-out sensor is damaged or broken. Consult a computer repair shop.
    KINDLY PLEASE RESPONSE ON WHICH OF THE ACTION/SOLUTION YOU HAVE TAKEN AND HAD PREFORM...
    KEEP US UPDATED.
    MIZH
    Master:
  • 441 Answers
A paper jam might result if photo paper is specified in the Document Properties dialog box but plain paper is loaded in the product
  • Serwen Bagadiong
    Serwen Bagadiong Sep 17, 2008
    You can also try to open the back tray of the printer from where you feed your paper. Check for the bits of paper which might be jammed in the rollers. I beleive that the paper was stucked in the printer and u tried pulling out that paper in pieces. So don't panic and relax and do the work. check for the bits as those are not allowing the rollers to roll and the printer is thinking that the paper is jammed.
    Hope it helps.
    Genius:
  • 3,422 Answers
HI,
You can first try a hard reset by unplugging all the cords of your printer for 30min and then plug them back in.Let me know the result.
  • Priya darshan Sep 17, 2008
    you need to have the key combo for this one..
    simultaneously press
    cancel and power
    then there will be a prompt in the lcd to enter a key combo
    the key combo is
    grey then blue then green
    after pressing the combo key
    a menu will pop up
    browse that menu until u see the reset option..
    the legends are:
    gray=scroll down
    blue=scroll up
    green=ok
How to fix a carriage jam/
KAREN, OPEN THE PRINTER UP SO YOU CAN SEE INSIDE AND LOOK FOR ANY INDICATION OF A PAPER JAM,,LOOK GOOD COULD BE A PIECE OF TORN PAPER STUCK SOMEWHERE..THANKS
Jan 24, 2016 | HP Photosmart C5280 Printer
Removing paper jammed
Remove read access door and Remove the paper jamming the printer.
Sep 03, 2014 | HP Photosmart 3310 All-in-One Printer...
Paper jamed
Hi
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
HP C5280 printer jams all the time at the same point in the page
More than likely there is a small piece of paper caught between one of the small rollers and the metal frame that hold it. Get a flashlight and look real good.
Aug 07, 2009 | HP Photosmart C5280 Printer
HP Photosmart C5280 doesn't print photo
my steven
u need to chek setting of pritner in pc when u do pritner command it's show pritner propaty this is capple of options like in cd pritner on photo 4x6 also give all setting u have to chek this setting it's help u
Jan 09, 2009 | HP Photosmart C5280 InkJet Printer
My HP photosmart c5280 keeps saying there is a carriage jam. what is this?
Lift the printer cover. undo the 2 screws (torx head). remove the right hand end of the printer casing.
You will see a blavck plastic moulding with a couple of gears (it controls the cartridge cleaning). This is the cause of your jam - it is out of sync. Turn the machine on and watch what happens with this moulding you will see what I mean by out of sync and it can just be gently pushed back into alignment. Once it is ok turn the unit off and then on again and your jam should be cleared. Put it back together again and print away.
Jan 07, 2009 | HP Photosmart C5280 Printer
HP Photosmart c5280
Make sure to check all the way to the right and left inside. I ussually find paper loose in either of those ends. Then check your encoder strip which is the plastic strip that the carriage slides on. This may be dirty causing this issue. Use a soft paper towel and alcohol. Windex is okay to but may leave streaks on it and give same issue.
Dec 09, 2008 | HP Photosmart C5280 InkJet Printer
Hp C5280 Paper Jam error - no paper + component fell apart
I am having a similar problem. An33651759-359a-4c42-a15c-e9b8d80fcfba.jpgyone know where this piece belongs? It came out when I cleared my millionth paper jam!
Sep 09, 2008 | HP Photosmart C5280 Printer
143 people viewed this question
Ben Johnson
