Question about Empire DV-215 Direct Vent Natural Gas Heater
B vent configuration of direct vent propane heaters
Is there any technical or safety reason why an Empire direct vent heater cannot be set up to vent its waste gases into a metalbestos chimney, b vent style,(inner exhaust pipe) while getting its combustion air (outer intake) from inside air? This effectively has it operating like a b vent unit. The only concern I can come up with is the usual one: Is there adequate ventilation in the structure to supply fresh air for combustion? There is just no wall space in this structure to allow a vent to pass through the wall, but there is a metalbestos chimney, ready to accept a single wall adapter and reducer for the heater's 4" exhaust vent. Comments on this off-label installation idea? No b vent heaters of this size are commercially available.
  • 1,420 Answers
Yes, the design of the combustion chamber is limited at how much fresh air and combustion air can enter it. If you lengthen the venting, you will be causing more restriction and there will not be enough natural air movement to make it work. It will start, run for a minute or two and poof out. Not to mention you will be circumventing it's UL rating and if you sell your home with it installed, you are liable for any fatality or damage. Do you want to risk that? Don't even think of doing it! There are "Box" heaters out there sized from about 5,000 Btu's on up to 100,000 Btu's. Check the web.
Posted on Sep 19, 2008
Pilot won't stay lit on mr heater vent-free propane heater
if it is direct vent chances are it has electronic pilot.. it does not have a standing pilo and match size upt. if in fact it did have a buning pilot there is a part called thermocoupling. it will look like a 1/8 in. copper wire coming out of the bottom of the gas valve and goes right to the pilot. anywhere from 10 in. to 20in.. unscreew nut at gas valve pull out from pilot area [ it just clips in at pilot] take it to any home center
Nov 25, 2012 | Kitchen Ranges
Need an electrical diagram for an empire WFA 35s wall heater. It is at least 30 years old. Thanks
Unfortunately, Empire Comfort Systems hasn't made that wall heater in years. Never the less, you may get lucky by calling Empire direct @ 800-851-3153 and ask for Technical Service. Maybe one of the old timers can help you out.
Jan 16, 2011 | Empire Heating & Cooling
I have an empire wall heater that was converted to natural gas how do i convert it back to propane?
you will need a propane conversion kit designed for that particular model heater.
which would most likely consist of a heavier spring for the gas valve and orifices for the burners depending on how many burners you have.
Most all gas heaters come thru the factory set up for natural gas and most have a kit available for conversion to LP (Propane) You will also need a manometer or a gas pressure tester to check the incoming and outgoing pressures from the green (2ndary )regulator outside your house to the gas valve inlet side,usually 11 to 14" WC( water column) pressure( static) 14" being MAX!!
Outlet pressure with burners running 10-11" WC approx. This info should come with the conversion kit if available. If you are not comfortable working with gas then find someone who is, for safety reasons.
Jan 31, 2010 | Reddy Heater RLP100 Portable Forced Air...
How to change gas orfice to propane glass smokes up. soot
Is this unit originally set up for natural gas? If so, the burner oriface and the gas valve need to be retro-fitted to propane. This is something only a qualified service technician should attempt as an incorrect retro-fit could cause an explosion resulting in someone getting hurt or even killed.
Nov 09, 2009 | Empire Hight Efficient Direct Vent Wall...
How to change the orfis from propane to gas on a empire 40,000btu
what is the model # for the furnace. You are going to have to change the pilot orofice and gas valve for natural gas also.
Oct 30, 2009 | Empire Hight Efficient Direct Vent Wall...
Propane heater goes out after heat cycle
I've seen excessive draft draw the pilot flame away from the thermo couple when the burners light so when the burners shut down so does the pilot.
Feb 08, 2009 | Coleman Propane Forced Air Heater...
Light soot around propane fireplace vent
burners burning yellow , in complete combustion , blocked air ways to burner , it needs a service soon as poss
Dec 22, 2008 | Empire DV-215 Direct Vent Natural Gas...
Procom fireplaces
Empire makes a wall heater that is direct-vent that looks similar to vent- free wall heaters. Here is a link to a website that sells their products... http://www.mastersalesonline.com/empire/index.html. I am not sure of the prices you will need to call the on-line store. I hope this helps you.
Jul 08, 2008 | Procom ML300TBA Heater
Empire Wall Heater(propane) won't stay lit
You have a crack in your heat exchanger and it is sucking in products of combustion. Replace the heater. OR there is a blockage in the intake or exhaust vent. GET IT FIXED OR REPLACED!
Dec 05, 2006 | Empire GWT-25 Wall Mounted Panel Heater
Empire DV-215 Direct Vent Natural Gas Heater Logo
577 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
rudyjoe
Level 1 Expert
vance jones
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
