Question about Gigabyte GA-M57SLI-S4 (4719331821180) Motherboard
GA-M57SLI-S4 wont power up !!! what to do !
OK THIS BOARD IS BRAND NEW FROM THE BOX.
Opened the CPU socket lever and inserted the cpu, (has no damaged)
tried to boot it up , but here we go nothing.
seriuosly have no idea, but two thoughts !!!
defective or some how got staticaly electricuted.. on of the two...
  • 1,029 Answers
Hi check the cables from the case to the mother board. They should be marked and the manual that came with the board ,this show you where to connect them on board The std markings are HDD [red led] PWR S [powerswitch] RSW [reset switch] PWR LED [case power light] in most cases check to see if this is correctly connected
To test if there is no fault in the board or power pack. first visualy check the board to see if it shows a red led light when the power is turned on, if not the problem is in the power pack or the wall outlet.
second if the light is on, bridge the pins marked pwr switch on the board with a screw driver and this should start the computer, check the processor and ram if not you have a faulty board.
Posted on Sep 17, 2008
  • Starnley Johnwells
    Starnley Johnwells Sep 17, 2008
    dont forget to rate the solution
Can you tell me why when i put CPU in my computer he give error? CPU is AMD Athlon 64 3400+ 2.4GHz socket 754.My motherboard is socket 754 Gigabyte GA-K8NE-RH. Problem is my computer or CPU?I take CPU...
The motherboard will support this CPU, with the F1 bios.
I can only advise, that IF your motherboard was working ok before you put the new CPU in, it must be the new cpu you bought.
If this is the 1st CPU you have tried, there is a chance the board is damaged
Jun 13, 2011 | AMD Athlon 64 3400+, 2.4 GHz...
I have a Motherboard gigabyte GA-8PE800. when i
The ATX 12v ( 4 pin Connector ) is For The CPU Power.
This could Indicate, either A Faulty CPU.
Or a fault To The Motherboards ( BGA ) or CPU Socket Holder.
Or alternatively, The Actual PSU Itself is Faulty.
You can obtain A CPU Socket Tester from e-bay. And A PSU Tester.
Hope This Helps Mike @ Compurepair.
Oct 16, 2009 | Intel Motherboard
Wont boot
i think the cpu may have a problem with the board or the memeory. either its bad, damaged or incompartible with your system. try out another cpu
Mar 24, 2009 | Gigabyte GA-K8VT800 Motherboard
New Build PC not booting
do you get any onscreen information like a bios screen?
Feb 22, 2009 | Gigabyte GA-M57SLI-S4 (4719331821180)...
Pc won't power up
if you've tried other power supply's and are positive that the power button is connected properly and are getting nothing, no beep no lights no fans, then you got yourself a bad board.
Jan 23, 2009 | Intel Motherboard
Mainboard dead i need super help to prove wrong the people who blame it on me istead of agreeing..
I'd recommend using a known good power supply, a known good PC speaker, and a digital multimeter.
Search for the voltage regulators (usually have a small heatsink attached) and any voltage converters (usually close to some coils of wire wrapped around a ferrite "donut"). Look up their datasheets online, and check the voltages into and out of each of them. If the voltages are okay, listen for any beep codes when powering up. If that doesn't work, consider buying a "Post Card" - Power On Self Test Card. You plug it into the PCI or ISA sockets, and it will show you a numeric code to indicate how far the power up sequence has progressed. Retail for about $20 to $40 CDN.
Sep 17, 2008 | Gigabyte GA-M57SLI-S4 (4719331821180)...
Graphic card
try installing the latest driver of the video card with the second video card removed.. and the monitor attached to the primary video card.
Aug 01, 2008 | Computers & Internet
Gigabyte GA-M57SLI-S4 (4719331821180) Motherboard Logo
390 people viewed this question
Top Gigabyte Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
