Question about Sony KV-27S10 27" TV
Sony KV 27S10 TV
Picture too wide at top and bottom, narrows to correct width at center, juts back to the left at very top one inch. Unable to determine if it is in pincushion or deflection circuit because I don't have a crosshatch generator. Checked all associated electrolytics for leakage - tested good. One interesting thing - damper diode D501 (RGP02-17) is reading at .9 volts on the fluke diode test instead of nominal .4 to .6 volts. Anybody got a clue?
3 Suggested Answers
  • 18 Answers
SOURCE: Sony MODEL KV-2585 TV
You have your information incorrect, Q is not the designation for diodes, Q657 would be a transistor. First give us the correct number for the diode and how do you know it is shorted?
Posted on Aug 16, 2007
SOURCE: My sony Tv picture has shifted to the left
My tv is no picture but they have sound & power
Posted on May 07, 2008
White flare top left of screen sony bravia ldl-52W3000.
The capacitors at the main power supply regulator board should be checked and replaced. If you are not familiar with electronics, do not attempt to repair! Whether you suffer fatal electrical shock! Instead, contact the nearest service center!
Jan 20, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony KV-32FS12 32" TV what is the weight on this TV set?
It weighs 165 pounds. Also, Width: 31.5 inches. Height: 27.88 inches. Depth: 23 inches.
Nov 28, 2009 | Sony KV-32FS12 32" TV
Sony KV-27S10 has intermittent tuner issues. moving the cable connection on the back of the set sometimes clears the picture.
This was a common problem with the Tuners of these models. The replacing of the Tuner should fix the Problem. You may be able to order it from Sony.
Here is their Customer Service Number.
1800-222-Sony
I hope this helps,
Skyassoc
Oct 27, 2009 | Sony KV-27S10 27" TV
Sony KV-27S10
is it vertical problem or retrace lines can you tell
Aug 06, 2008 | Sony KV-27S10 27" TV
Apr 29, 2008 | Sony KV-32FS13 TV
34XBR800 No width setting
The Sony manual can be downloaded here for free
http://www.mediafire.com/?ixd49edyyam
ID codes from manual:
KV-34XBR800
KV34XBR800
0 ID0
89
1 ID1 255
2 ID2 239
3 ID3 107
4 ID4 203
5 ID5 243
6 ID6 126
7 ID7 25
Mar 22, 2008 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Blue vertical lines
Yes...your light engine/optical block is shot... 1500 dollars.
Jan 25, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Picture deterioration
Your whole problem my freind is dryed up capacitors. You should go, if you have the technical ability to replace these capacitors, to http://servicemanuals.net, download the schematic diagram, and start replacing the waveshaper capacitors in the vertical drive circuit.
Sep 23, 2006 | Sony KV-35V35 TV
Televison & Video Logo
158 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
