Question about Philips Televison & Video
Philips t.v. no.26PFL5522D/05 No digital picture. Analogue works OK.DVD works OK. T.V Arial used for this TV & a portable TV. The digital works OK with the portable but not the philips which did until yesterday Have tried the analogue/digital mode to switcth between both still no picture.
5 Suggested Answers
SOURCE: Toshiba 57WT29B Rear Projection.
NEW SIGNAL BOARD
Posted on Sep 03, 2007
ctf1800
  • 4402 Answers
SOURCE: philips rear projection tv 43pp8545 no picture sound ok
do you get a blinking read light?
Posted on Dec 14, 2007
  • 121 Answers
SOURCE: Hi guys, don't know if
yes, hdmi will give you better results..
are you running hdmi to hdmi connection on tv from cable box?
if so, that is correct but as for the dvdr, what tv port are you connecting it to? i would use another hdmi cable for the dvd too for best picture resultif it's an option on your dvd.. you should have multiple input outlets on your lcd with 1-3 options for input devices via analog or hdmi.. so analog is not hdmi--hdmi is digital so it switches to the hdmi resolution when you turn it on..
let me know how it goes and if i was helpful involving resolution.. helpful feedback is appreciated.. thanks, d
your dvd player should be set to a different
Posted on Feb 27, 2008
SOURCE: DVB not working on panasonic
Check the arial cable - not just the connections. Problem noted was due to an inferior cable that was not up to the job. It also ran alongside a central heating radiotor and pipes - not a good combination apparantly!
Posted on May 05, 2008
  • 520 Answers
SOURCE: My new TV is set for cable. I do not have cable, I have an anten
Sansui TV's come from the factory set for CABLE. If this is a HDLCDVD320, you will have to go into the menu to change the signal type to AIR, then run the automatic search to program in your channels. Their free customer service line is 800 289 0980.
I hope this helps.
Posted on Dec 31, 2008
LITE ON HD-A740GX ONLY HAVE DIGITAL SIGNAL HOW DO I TUNE IN CAN I TUNE IN
You must connect a digital TV box between your arial and your Liteon, so the arial cable goes into the digital box, and use a SCART cable from the digital box to the Liteon. Then record using the SCART input on the Liteon. Another SCART cable can be connected from the Liteon to your TV, so you can view what you have recorded.
Apr 30, 2012 | Lite On HD-A760GX DVD Recorder / HDD...
Philips 26pfl5522d/05 TV Channel issue
Just been on Philips Forum and there is a possible very simple solution. Press and hold the MENU button ON THE TV for about 20 secs. This should factory reset TV and allow storage/retrieval of channels to the '8k' store. See this page for more detail:http://www.supportforum.philips.com/en/showthread.php?1366-26pfl5522d-05.
Now I have to ring my Dad who has exactly this problem!
Apr 03, 2012 | Philips Televison & Video
We are experiencing a problem with the sound on a flat screen Philips tv (model 26PFL5522D/05). The sound is really fuzzy. The tv is connected to free sat but the problem is still there when playing Dvds....
You should try to eliminate any physical cable issues by swapping the audio stereo cable from DVD to TV with another set and see if it persists when playing DVD. If the sound is fixed then it might be some bad cables you have. If it still sounds fuzzy, and your TV is still under warranty, I would consider calling Philips for customer support.
Check your manual to see how you can reset the settings back to default if at all possible.
Mar 03, 2011 | Philips Televison & Video
My Philips remote stopped working. 42PF7421d/37
my philips tv remote stopped working after i tuned a simple remote to it! so now my origenal remote will not worl model no. 26pfl5522d/05
Dec 31, 2009 | Philips Televison & Video
How can I get an analogue signal on my LG3000 32in LCD tv? Digital input is fantastic, but no idea how to obtain analogue. Input is connected to a community arial and other residents get analogue with no...
According to the manual I looked at, this TV has only one antenna input. This means that analog is available if you let the TV do a full autoprogram of memory. It might take it several minutes to complete, but once its done you should have analog and digital if available. If you were looking for analog channel 5 then you would just enter 5-0 but digital channel 5 would be 5-1.
Nov 12, 2009 | LG 32LG30 32 in. LCD HDTV
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
RCA - 4228ASPDP - 42 inch Plasma - Audio Problems
Usually you would connect the SKY box to the DVD recorder and the DVD recorder to your TV, check you installation guides for setup instructions, which should show you a preferred layout diagram,
Sep 27, 2007 | Televison & Video
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
