Question about Nokia 1600 Cellular Phone
Repairing solution 1110 is not charging
    Sergeant:
  • 300 Answers
Bad battery pack
The only solution here is to replace the battery
if that fails
have the unit tested for problems.
Az.
Posted on Sep 17, 2008
Dock red light
Flashing Red Light is not charging and solid red light mean charging the radio battery.
Dec 09, 2013 | Motorola CLS 1110 (1 Channel) 2-Way Radio
1110 how to sold not charging
First Option:Please change The Phone Bettery and charger and check The check The Phone charging
IF Charging Problem will Not Solved So
Secend Option:Your Phone charging IC Fault SO Please change charging IC And charging Problem will SOlved
Jul 22, 2010 | LG Vu CU920 Cellular Phone
I have a nokia 1110 model ,phone is ok but the mic is not working ,what should i do now tell me the solution
If there's no internal problem like circuit or ic issues, your problem will be fixed after replacing the mic. You can get the mic from any mobile repairing shop or from mobile spares shop. There's a specific mic for your model, but if in case, you can't find one for 1110 model, then get a universal mic (small), you'll need a soldering iron with soldering wire and paste. If you now how to use mobile soldering iron, go ahead but if you are not good at it, i would suggest you to get it done from a mobile repairing shop. A small mistake can lead to permanent damage and unrepairable.
Good luck.
Thanks for using FixYa.
Jun 23, 2010 | Nokia 1110 Cellular Phone
When i connect my mobile for carging it show (not charging(stop)). But it show after few second and make a beep. with this mobile show different status of charge level.
Hi, I too have this cellphone, when this happened to me I just bought a new charger and that fix my problem. I would suggest you try first a known good charge for your cellphone and if still you have the same issue, try to visit a cellphone repair center or from nokia care center, because there is already a problem with the charget socket on your cellphone. Hope This Helps
Jun 11, 2010 | Nokia 1110 Cellular Phone
Not charging problem
dear the bettry of 1110 can not be charged by putting in 1100.just the original bettry of both can be charged its own model
May 27, 2009 | Nokia 1100
Water damaged,not charging--nokia1110 my nokia1110 was water damaged.still after that also somehow it was working bit properly.. then LOCAL MODE msg came in and went away after a while. Later when battery...
Guest - you phone needs to be taken to a professional repair store and have the local mode remove...that is a testing mode when unlocking or service the main-board.
akemsl11 - the fuse could be blown on the board for the charging....either buy a new mobile or take it to a repair store close to you to have them service the phone for you.
arkster101 - take the phone to a mobile repair tech and have them service the charging port and fuse on the main- board but i think the board is gone so you should buy a new mobile.
Apr 23, 2008 | Nokia 1110 Cellular Phone
Repair nokia 1110 display please tell me how to fix it.
Yes u r absolutely right, U can say "Sir/Mam, i need a nokia 1110 display", and u just purchase a suitable screw driver and open ur handset and remove bad display and put the new one,, easily. I 'm sure u can do it. best of luck.
Sep 05, 2007 | Nokia 1110 Cellular Phone
Nokia 1600 Cellular Phone Logo
29 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
