Question about JVC XL-R5000BK CD Player
Opc error.. it wont record any source.. - JVC XL-R5000BK CD Player
    Brigadier General:
  • 8,546 Answers
Web search "optimum power calibration error". The manual incorrectly calls it Optimize Power Control on Page 2. It has nothing to do with the source and all to do with the media and how the laser calibrates to it.
Posted on Sep 21, 2011
What does it mean when says opc error on my tascam cd-rw 900sl?
So far as it looks from other information in the works that this problem is caused by defective media. I always use Taiyo Yuden discs and have had few rejections in over 600 discs. Supermediastore is where disc supplies can be had as well as information on the error rates of different media being produced. The complaints recently were due to a bad batch released of hhb brand discs.
Mar 17, 2013 | Tascam Cd-rw900sl Cd Recorder/player
I have a CDR 765 Philips recorder. It doesn't work on recording. The error message is "NO OPC". Thank you
hola
la cdr765 de philips es una grabadora de pc 3610 de philips o hp7200, el opc error es la lente esta mal, compra ina grabadora y cambia los 2 circuitos de la mecanica original de la cdr765 y desmonta la 3640/7200 y ponle los circuitos montas y a disfrutar.
Feb 27, 2011 | Philips CDR765 2-Disc CD Recorder
OPC Error
It implies a media Optical Power Calibration problem (google it). Did you recently start using a different type or brand of disc?
Jun 28, 2010 | Philips CDR775 2-Disc CD Recorder
OCR Error Message
Don't you mean OPC Error?
http://www.mscience.com/faq64.html
If you've just started using a new media brand, go back to what used to work. Philips recommends only their own brand of media....
May 27, 2010 | Philips CDR770 CD Recorder
Cd recorder audio
If you're going to ask for help you should take special care to spell the error correctly. It's only 3 letters "OPC error".
Anyway, what little I could find about it looks like it could be a firmware problem.
Jan 17, 2009 | Philips CDR770 CD Recorder
On my jvc xl-r5000 cd RECORDER , FLASHES OPC FULL ,CANT RECORD.
download the manual from JVC or buy new remote here is the web site to download from. I could read it and post it for you but thought you would like to have a manual for it for yourself. If you still can't figure it out post on this answer and I will reply to it later.
http://search.jvc.com/query.html?style=JCA&col=site&qt=jvc+xl_r5000+manual&x=24&y=3
Jan 14, 2009 | JVC XL-R5000BK CD Player
Power Calibration Error.
first re install your nero .and
A) Power Calibration is controlled by the recorder. Before any write operation, all recorders must do a 15 step power test to determine the optimum power for writing to the CD; this is called "Optimum Power Calibration"(OPC). And during the write, it continues to do this test to get the best write throughout the whole CD; this is called "Running Optimum Power Calibration" (ROPC). This whole process is controlled by the recorder, though initiated by programs such as Nero. There is an area on the inner part of the CD for the test and test data info to be stored. You can use this area up to 999 times.
So, when you receive the "Power Calibration Error" or "Power Calibration Area full" error message, then the cause will be either poor media, poor Power, or a defective Recorder.
POSSIBLE SOLUTIONS:
1) A might enable the OPC on this medium
2) Try another brand of CDR or CDRW media.
3) Also try different power connectors, and for recorders, do not share power with other devices. It needs its own power connector. If this occurs with an External recorder, the power source in the chassis could be the cause. Take the recorder out of the external chassis, and connect it internal, as a test.
4) Try different configurations, such as taking the CDROM to the Primary IDE bus as Slave, and have only the recorder connected to the Secondary IDE bus as Master.
5) Send the recorder in for Service.
Here is the direct Link: http://www.nero.com/en/632181809668074.html#23
I Hope this helps,
Feb 12, 2008 | Ahead Software Nero 6.0 (60045) for PC
Marantz cdr300
try turing off opc in menu see if that helps use hi end meadia only memerex i like
Jan 18, 2008 | Marantz CDR420 CD Recorder
OPC ERROR
how would I go about fixing the lazer problem with this issue of OPC Error when I push record. Sometimes when I use a lens cleaner, it will records some cds and then the error shows up again. Any help, Thanks
Dec 04, 2007 | Marantz DR-6000 CD Player
JVC XL-R5000BK CD Player Logo
166 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
