Roper RS25AEXLQ Side by Side Refrigerator Logo
Posted on Sep 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The frige works fine, but the freezer has stopped freezing. It's cool but won't freeze. It's also hot to the touch beside the door.
Anonymous
Level 2:
President:
  • Expert 3,773 Answers
  • Posted on Sep 21, 2011
Anonymous
Expert
Level 2:
President:
Answers
3773
Questions
Helped
609507
Points
163
This is a common problem when the compressor is beginning to go out.
The freon high side tube from the compressor runs between the doors on its way to the
Evaporator (cold coils)
When every thing is normal the line is suppose to reduce the amt of moisture at the doors
but when the freon is restricted (whether in the condensor or capillary tube) its not normal
any more. It begins to build up high head pressure thus the extra heat between the doors.
The most common cause of this high head pressure is restricted flow of the freon thus causing the compressor
to pump against the restriction thus building up high heat.
The most common cause of restriction is caused by the insulation on the motor wire windings inside the compressor breaking off and traveling with the freon to the capillary tube
(very small opening) and restricting the flow thus causing the compressor to work much harder thus
causing more heat at the doors and compressor.
Not much you can do about that
Compressor failure is imminent!
Its possible that the back has been removed from the ref thus causing the problem
Also check condensor fan to see if it is running and clean condensor coils if they are dirty
Good Luck!
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
1helpful
RF265AARSXAC The freezer is not freezing.
looks as evaporator fan is working. have you ever clean condensor under the fridge. possibility it is pluged with dust and not allowing compressor to cool down.
Also check the fan at the back of the fridge beside the compressor. see if it is working
2helpful
2answers
Daewoo FRN-U20IA top of freezer compartment won't freeze
It was the fan at the top of the freezer that had stopped working after 3 years, therefore the freezing air wasn't getting to the top of the freezer. From the inside, unscrew light unit and unclip, pop out two circular discs at top and unscrew one screw. Unscrew 2 more screws and prise the back panel off. (Arrows mark the clips). Pull off fan, take out motor, replace (keeping rubber bits) and push back fan with a bit of nail varnish on spindle. Put everything back together. Turn on, depress door light switch and after 30 seconds fan should rotate. You can buy a fan on eBay or from www.4daewoo.co.uk for about 40 pounds.
It freezes but won't stop
as long as the compressor is running on your freezer the longer the fan runs has to too cool the compressor . . .thermostat problem
Jan 11, 2013 • Boating
Fridge won't cool but freezer working fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
1helpful
Our freezer seems to be working fine, however, the fridge part doesn't seem to be cool at all
all you have to do is defrost the frige the freezer sometimes will freeze up with ice in the back of freezer where the air flows into frige
Frige not cooling, freezer is fine
its the problem of defrost timer.due to this the cold air from freezer section is not getting in to refrigerator section and its getting warm.check out the defrost timer.located beside the compressor at the back lower side of the unit.the cost of new defrost timer is near to $40.and you can get it from
www.repairclinic.com
thanks.
6helpful
3answers
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Fridge is hot while freezer works fine
Defrost for 24hrs with doors open, turn back on it will then work ok. Regards Advisor
Bottom Freezer working but not side!
Typically the freezer air is circulated into the frige area to provide cooling. If the circ. fan is not working or the air ducts/channels/dampers are blocked with ice, food, etc. then no cool air will get from the freezer to the frige area. Check all the air channels and to see if the dampers are open along with the circulation fan running. The diagrams at the following link should help you see inside better. If your lower circulation fan is running then you likely have an air return/supply channel blocked with ice and will require an old style defrost (unplug unit and leave doors open for 24 hours to melt ice, etc.). If the fan isn't running then that needs to be replaced. Air channels can freeze up if a door is left open slightly overnight or other moisture enters the freezer/frige. http://www.partselect.com/MultiModels.aspx?ModelNum=ER6AHKXPQ&searchTerm=&RefineSearch=0
Top Roper Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
