Question about Nokia 6300 Cellular Phone
Nokia 6300 When turning my nokia on it falshes twice and turns itself off. The battery is fully charged and this is the second time its happned?? can I retrieve all my phone numbers in the phone bank and or can this be repaired ?? Thanks
  • t_marfori08 Sep 19, 2008
    it flashes twice then turn off
When i turned the tone set up for the profile of my china nokia phone (6300) it turned off and my tone set up is not functioning. but other programs are all doing fine. what will i do?
Posted on Sep 19, 2008
Nokia 6300 won't turn on or charge, battery is dead
It probably needs replacing. Batteries are generally the first component to go faulty on cell phones. It might be swollen -- this is a clear indication that the battery is useless.
Nov 15, 2012 | Nokia 6300 Cellular Phone
Hi! My screen is white when turn on the phone. When I removed sim and memory card and turn on again, I see fabric black/gray background but can not see menu or any other commands.. Thanks in advance..
It seems to be a corrupted firmware. Nokia allows you to update the firmware over the net. How???
Fully charge the battery, backup the data on the phone, Connect the phone to the PC through a USB cable only. Start Nokia PCSuite and allow a few seconds for the suite to connect to the phone. It will display on the suite that Nokia 6300 is connected. Click on update firmware and follow instructions. When suite finishes, your phone would be as good as new. Restore the data to the phone.
For more info read the following link.
Updating the Phone Firmware (Nokia)
Dec 11, 2009 | Nokia 6300 Cellular Phone
I havnt used nokia 6300 for 3 months , how to recharge battery
Because it has fully discharged, the battery has to be replaced. Try replacing the battery.
Rate this.
Apr 29, 2009 | Nokia 6300 Cellular Phone
My Nokia 6300 is not getting on. I press the power button for long time but it is not working. Battery is also fully charged.
try taking battery out for ten mins if it fails to start up this is a hardwear fault and will need to be sent to a nokia care centre to be repaired
Apr 28, 2009 | Nokia 6300 Cellular Phone
Nokia 6300 wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Apr 29, 2017 | Nokia 6300 Cellular Phone
My nokia 6300 can't turn on.. i dropped it awhile ago, when i checked, it was still okay,,, but when i ran out of battery and tried to charge it, it wont turn on anymore,,, but the blue light around it...
5.Wait 10 seconds.
S
Apr 06, 2017 | Nokia 6300 Cellular Phone
Nokia 6300 incompatibility with Nokia PC suite
You need the latest Nokia PC Suite installed on your PC.
Then do an update of your phone software. Nokia PC Suite v6.85
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don’t unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you’re up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
Mar 30, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 does not boot up when started
Try this:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
Mar 26, 2008 | Nokia 6300 Cellular Phone
Nokia N70 Power Problems
my fone is charged...all of a sudden i switch off and then when i switch it on..all it shows is nokia nothing else...i have a N70 ..please help me
Mar 07, 2008 | Nokia N70 Cellular Phone
Nokia 6300 Cellular Phone Logo
112 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
