Question about Dell PowerEdge 4600 Server
The server doesn't boot and when I accessed the container configuration utility - clicked manage containers; my RAID 5 (136.7GB) container is dead and has 2 missing members out of 3. The 3rd one is 68.3GB is detected. I'm trying to setup win2000 again; Where I can get the SCSI HD Drivers (manufacturer supplied hardware). Thanks.
  • 2 more comments
  • wahba Sep 17, 2008
    Hello
    This is what I got from utility:
    PREC 3/Di, Controller #0
    SCSI id (for the 3 hard drives) is: MAXTOR ATLAS10K4_73SCA
    Then is SCSI id #7: PE/PV 1x8 SCSI BP
    Thanks..
    Before proceeding with this remedy, I just have 3 points to share with you;
    1) The hard disk is detected in the BIOS
    2) During my attempts to discover the problem; I temporarily changed the BIOS setting into "no RAID"; when rebooting the system I noticed that the light of the middle drive (in slot #1) remained green and did not turn to orange. I put back the BIOS as it was before.
    3) The container status (accessed by Cntrl-A) shows status "dead" with two members missing.
    Now; do you think that I still need to download the SCSI controller card driver as part of windows 2000 repair procedure or there is another way to rebuild the broken RAID-5 array?
    Thanks.
  • wahba Sep 18, 2008
    Steven,
    Here is what I did so far:
    1) Created a floppy that has the PREC 3/Di Controller driver from the link that you sent me (that was a non-bootable floppy; I did not get why you mean by using a bootable floppy since I will be setting up windows from CD’s and the floppy capacity will not accommodate drivers + booting files)
    2) I Started the WIN2K setup, pressed F6 to feed the controller driver; it recognized the driver and I proceeded.
    3) The screen flashed and I got an error: Disk I/O error status 00008001; however the setup continued
    4) I request a fresh installation; it showed me that I have 139GB hard disk (which is correct) and as usual asked me to press “Enter” to install; but underneath the volume size there was a message; “Can not access the partition”
    5) Since I had no other option; I just pressed enter and I got a stop error KMODE_EXCEPTION_NOT_HANDLED *** address …..etc
    My questions are:
    1) Why I got the above sequence of events?
    2) Shall I delete the RAID-5 container 1st before proceeding further?
    3) Assuming that there is one damaged hard drive; can I at least use the other 2 with mirroring? What are my options if there are two damaged? Are they really damaged or I missed something?
    Many thanks in advance,
  • wahba Sep 19, 2008
    Steven,
    I was able to reinstall Windows 2K again; many thanks to your support. As you mentioned before; all data were lost; but never mind since I keep some relatively good backup (even though not very updated). Thanks again.
    One small issue left; after I completed the installation; I did not find the TCP/IP protocol added and accordingly; I’m not able to add the old sever static IP address. Upon checking the device manager; I found that the network adaptor: Intel 8255x-based PCI Ethernet adaptor (10/100) is already defined; however there are two undefined device marked as “?!”; those are: Other devices/Ethernet Controller and another one within the IDE ATA/ATAPI controller group: Secondary IDE channel.
    Please advice me how to add the TCP/IP protocol and to add the above two devices.
    Note: I did not yet add any service packs.
    Regards,
    Scholar:
  • 95 Answers
You can download the drivers here:
http://support.dell.com/support/downloads/driverslist.aspx?os=WNT5&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=PWE_FOS_XEON_4600&hidos=WNET&hidlang=en&TabIndex=
However, due to the many configurations available in the PowerEdge server 4600, there is no way for me to tell you exactly which controller driver to use. You will probably have to make a boot disk to feed the driver to windows 2000.
Comment back with specific controller model numbers, and maybe I can direct you to the correct download.
Steven
Posted on Sep 17, 2008
  • 2 more comments
  • Steven Parker
    Steven Parker Sep 17, 2008
    then your system uses an Adaptec PERC3/DI SCSI controller card. You can download the correct drivers at the link I previously provided, and selecting SCSI RAID Controllers (8) in the list at the bottom. Then, you'll want to select the second option called Adaptec - Driver and follow the instructions to make the boot floppy.
    Steven
  • Steven Parker
    Unfortunately, RAID-5 is only fault tolerant of a single drive failure. If you're missing two drives from the three total, you've lost all your data. Had you only lost a single drive, you could have rebuilt the data. You might want to consider purchasing a spare drive in addition to the two drives you'll have to replace as it will automatically use the fourth drive as part of the RAID should a single drive fail. This will give you fault tolerance to two drives.
    There are a couple of places you can send the hard drive for data retreival, however it's quite expensive. In the range of $2,000USD to $3,000USD. If you want to try this, the company is named ontrack.
    But since you've lost the data on the drives, it's time to just reinstall. Make a driver boot floppy, and reinstall server 2000.
    Sorry you lost your data, but best of luck to you. Comment back if I can help with anything else.
    Steven
  • Steven Parker
    Steven Parker Sep 18, 2008
    According to microsoft's KB31192 article shown here, you should remove the zip drive from the computer when installing the o/s.
    Also, I would recommend destroying the RAID-5, and recreate the array before installing the new o/s if you haven't already done that. However, I'd also recommend running a hard drive check on this server since you've already lost data once from these drives. I assume you already did this and probably replaced the bad hard drives, but maybe not.
    In reference to earlier, yes you do not have to create a bootable floppy, but rather a standard floppy for the drivers (which you already did, good job).
    Steven
  • Steven Parker
    Steven Parker Sep 19, 2008
    Networking should have been installed if it detected your network card. If however it did not detect your network card at startup, then you'll need to add drivers. Just download the drivers from dell's support site, and install the right ones on your server. The easiest way to determine the correct drivers for your system is to head to support.dell.com, and enter your service tag number. This should redirect you to the correct drivers for your server. Afterwards, you can install your server appropriately.
    Best of luck, Steven
My dell poweredge 2600 wont load up
  1. Can you access the Bios configuration on boot by pressing F2? Check the setting
  2. By load up do you mean your server software does not boot? use F10 on post from the utility partition main menu under Run System Utilities.
  3. Is the server working with RAID? Press CTRL + R and check the RAID
I am not going to say check all the cables because I am sure you will have already?!?
Aug 21, 2013 | Dell PowerEdge 2600 Server
Enable RAID system
use this guide, this is fo the embedded sata raid controller that comes standar with the ml150 g5.
Enabling SATA RAID functionality in the BIOS Setup Utility: 1.Boot the server, and then press F10 to enter the ROM-Based Setup Utility (RBSU).
2.Go to the advanced tab.
3.Enter the IDE configuration or hard disk configuration.
4.Change the ATA/IDE configuration to enhanced or SATA controller 2 enhanced (if not available then use enabled mode).
5.Configure SATA as RAID or configure controller 1 as RAID.
6.F10 to save and exit.
7.Reboot the server.
8.During post f8 will now show up for the embedded SATA set up.
•Creating the RAID volume.
1.Enter the embedded SATA setup by pressing f8 during post.
2.Enter the array configuration utility.
3.Enter create array.
4.Create the raid volume as desired.
5.Save and exit.
i hope it helps you!!!
Aug 11, 2010 | HP ProLiant ML150 G5 Server
How to configure raid utility on server 2003
Click on start then click on run
type in compmgmt.msc
once you have the computer management screen up.
click on disk management.
now you have the disks listed.
here you can right click on the disks and select the utility accordingly.
revert if you need any more clarification.
Jul 21, 2010 | Microsoft Windows Server Standard 2003 for...
PERC 3Di one drive is failed how do I remove and replace without losing the container?
Replacing the drive does not remove the container on the RAID controller. If the drive has failed, and you had a RAID 5, simply replace the drive. If you had a RAID 0, your data is lost. Replace the drive, and start over.
Jun 24, 2009 | Dell PowerEdge 2500 Server
The aid hard disk in the containers cannot be found by the system
MAYBE YOU LOST YOUR CONFIGURATION BUT DO YOU SEE THEM UNDER PHYSICAL VIEW IN THE CONTROLLER BIOS?AS IT BOOTS DID IT REPORT THE CONTAINERS OR NOT POWER DOWN UNPLUG POWER CHECK THE CABLE ATTACHES TO THE BACKPLAIN, POWER UP,,,,,,GO INTO THE [PERC BIOS UNDER MANAGED CONTAINER VIEW .(A EASY WAY TO CHECK THE CABLE IS ... IF YOU HAVE A SPARE DRIVE YOU CAN PLUG IT TO THE CONTROLLER MAKE SURE TO PUT POWER TO THE DRIVE IF YOU SEE THE DRIVE WELL THAT ELIMINATED THE CABLE)
GOOD LUCK
Apr 01, 2009 | Dell PowerEdge 4400 Server
Raid configuration
When your system boots up you should see an option to access your raid controller if not or if your system doesn't see the controller at all you will have to download the utility software from IBM, but you need to be careful any change you make in the configuration of the disks will delete all data on your drives. This is non-recoverable loss. The utility has help and is fairly easy to understand.
Mar 24, 2009 | IBM eServer xSeries x226
Scsi raid with battery backed memory for pweredge 2550 server
if my memory serves me correct i think this server uses a onboard (3di) card it is set in the bios to use the raid configuration, under integrated devices .make sure this is so ,as it boots press f2 key to enter.If this is so exit.next step is to shut the machine off pull the drives away from the backplain not completly out. Power up if it starts laoding the raid configuration,once the scan is complete it will give you a container not found error,now here is what you can do go in i think its control m or r,anyway look at the configuration and what raid you set it up for.write down the drive number 0-etc.ok the next move is the raid key a little device that sits on the motherboard beside the raid dimm reseat this,now you may want to replace the raid dimm or if you have a exact match for troubleshooting purposes you may try this.
Good Luck
Feb 05, 2009 | Dell PowerEdge 2550 Server
Upgrade IBM Xseries 346 Server
You can add drives to the array through the scsi management software, then you can extend any dynamic partitions that don't have the OS on them. I don't think you can extend the array if it contains the OS. You may need to use the disk management utility in windows to make the partitions 'dynamic disks' before you can extend the data partitions
Aug 21, 2008 | IBM xSeries 346 Server
Run Compaq Array Configuration Utility
Hi Foambob,
Try all means to get a smartstart CD.
Normally new version will be able to use on older hardware , but no guarantees.
I have always found it easier to use smartstart CD auto mode.
You can also do the install and then run ntssd to update all the drivers etc., but I don't recommend it for novices. Use the auto mode , it takes longer but safely and surely.
Good luck
May 21, 2008 | Compaq ProLiant 5500 Server
Dell PowerEdge 4600 Server Logo
1,237 people viewed this question
Alun Cox
