Question about Asrock P4i65GV Motherboard
Motherboard how can i test that my mboard bad or good???and can u tell me is this mboard hav a light or not.???pls help
    Sergeant:
  • 320 Answers
There is no way to test the motherboard without connecting to cpu. You can't test the motherboard until and unless you connect it to the pc. If you want to test the display, audio, graphics you have to connect each device and see. Every motherboard has got a green color light in it. When the power is on the light will glow. Thank you.....
Posted on Sep 17, 2008
Hiya. i hav a sony kdl32l4000 that wont turn on. all i get is a blinking green light. pls help
The blinking green light is a self-test diagnostic code. Please tell me how many times it blinks in between each pause so that I can tell you what the problem is.
Sai.
Jun 02, 2011 | Sony KDL32L4000 32 in. LCD HDTV
I hav problem with my back light screen..
it will cost you around 760-780$
pls rate the solution
thankyou for using fixya
Feb 19, 2009 | Dell (8N816) Motherboard
Mothrnoard
First thing to check here is the connection make sure everything is still properly connected, if after checking it and still no light it only means the motherboard is dead and already needs a replacement, because if the power supply is bad the fan shouldn't spin if its the problem...
Hope that helps...............
Sep 17, 2008 | Asrock P4i65GV Motherboard
MOTHERBOARD PVCLE266M-L MERCURY V3.0A------ HELP HELP-------
The first board may be bad; the detection of input devices is done by chips other than the uProcessor.
The second board may simply be controlling the fan speed according to need and when first powered up, the processor isn't hot.
Aug 28, 2008 | Computers & Internet
Pc is dead
is the power switch wire hooked up in the right place
Jun 03, 2008 | Intel Desktop Board D850GB Motherboard
Hi melnavz,
Hello Mayfield.
Since that your computer is still booting. the processor, memory is good. The only problem you encountered is cannot hold the time when you totally unplug the unit to the wall. iN that case, maybe something wrong with your mboard. maybe there some connection or jumper that was unnoticeally remove which make the battery open circuit. Please refer to the manual of the maboard for some jumper setting.
melnavz
Mar 14, 2008 | ASUS P5RD1-VM Motherboard
No display
hi
if you known about your all SMBS, RAM ,, PROCESSER, & HD Are all ok
  1. chack your ram then clean your ram slot
  2. smps ok
  3. about me your screen is black
  4. chang your bios battery 1st
  5. you use any video card...
Mar 03, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
4 seconds long beep
I think that either you have a bad power supply or it is not connected properly. I suppose it could also not be supplying enough power.
Try disconnecting all of the connections to the Motherboard and reconnecting them. Make sure they seat properly. Try a new power supply. You can get a good one from Newegg.com
Jan 26, 2008 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
Motherboard or Hard Drive problem
Testing mother board:
1. remove memory:
if the mainboard produce long beep means good.
if not that is bad.
2. if produce long beeps then insert the memory.
3. if same happen.hear long beep. then clean or replace memory.
If your are sure evething is ok in the mboard; then you can test your drive:
Hard drive test:
1. first fixed well all the connection bet the HDD.
2. if work then ok, if not then,
3. replace other IDE cable/ sata cable and fixed well again.
4.if still thesame; then
5. examine your HDD , the circuit maybe shorted.
Jan 11, 2008 | Dell Inspiron 6000 Notebook
Asrock P4i65GV Motherboard Logo
150 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
