Question about NetGear RangeMax NEXT WNR834B Wireless Router
Problem w/ WNR834B router and Open iConnectAccess621 modem
Hi, I bought the stated wireless router today and connected it with my Asus laptop running Vista Ultimate. After plugging in and running setup, it would get to the stage that said "now make sure both are turned on, plugged in as show in diagram and then press ok" or something like that, so I pressed ok, and it errored to "cannot find connection".
I moved/retried the cords as it said, but haven't got any results :<
I tried manually configuring the modem before it entered the wireless router, but it just keeps getting stuck like my broadband modem isnt sending a signal at all to my router! help :<
  • 1 more comment
  • JonoRob
    JonoRob Sep 18, 2008
    Thanks, that was one of two problems =D the other was an IP conflict with the original modem, but a firmware update auto-changed the IP, thanks mate! :)
  • JonoRob
    JonoRob Sep 19, 2008
    Hmmm.. another problem... it seems I can only have one laptop connected at a time b/c of the MAC address. Any way I can change it so all 4 laptops can connect?
  • JonoRob
    JonoRob Sep 21, 2008
    Ermmm... not really ><
    The router has 4 ethernet ports, but I'm not using any of them, I've got all 4 laptops (3 of them not mine) connected via wireless. I can get 1 laptop using the internet by using *its* MAC address, but none of the others seem to be able to connect to the internet.
    Is there a way to get a "dynamic MAC" address or something of the sorts so tthat when a signal is sent to the wireless router from a laptop, it will send that to the modem with the laptop that sent the signals MAC address? This is just my thinking, but its sort of what I need, :S. Bit confuseed ><
    Thanks for any help in advance.
    Scholar:
  • 95 Answers
If you previously had your computer connect to the modem, and are now trying to plug in the router, you'll probably have to clone your pc's MAC Address. See one of my first posts in my username account history for a more detailed process.
Steven
Posted on Sep 17, 2008
  • Steven Parker
    Steven Parker Sep 19, 2008
    I think you're experiencing some other issue than a conflict among MAC addresses. By asking your router to clone your pc's mac address, you've only made the router look the same as your pc through the internet. On the local network (the connection between your pc's and the router) your router will use another, seperate MAC address.
    To me, it sounds as if you've got some wires mixed up. Maybe you can snap some digital camera pics and upload them here to see what's not working right.
    Steven
My laptop connect to wireless modem (asus AM604g) and after 30 - 60 min hang wireless and i must reset my modem to connect again. What is problem thank you.
Please make sure that the router and the not placed need to any electromaganetic source or any heat source. The modem/router should be placed in well ventilated area and if possible on a wooden surface. The wireless hangs becouse the modem/router gets heated up.
Jul 01, 2010 | ASUS WL-AM604G Wireless Router
Asus WL 520gu can't connect internet
1, connect your wireless router with cable to your laptop,
2. Login into your Asus-WL520gu and setup your wireless how you want it to run." do not bother with putting your username settings in there"
3. In your Asus-WL-520gu after setting up your wireless turn the DHCP off in it.
4. Now connect the cable that you have connected to your laptop to your router instead of your laptop.
""You should now be able to connect to the wireless with your settings. and connect anything ells you want to the other 4 ports on the back of you wireless router"" note: do not connect anything to the WAN port as it is used for DSL modems; and not Routers with ADSL modem.
when connecting a router to a router - the one that is connecting you to the internet needs DHCP turned on because it is the one that will be giving you IPs and Gateway settings - the other router such as wireless router after setting it up needs its DHCP turned off - other wise you will have 2 routers trying to do the same thing with ip's and gateways. And you should never connect a modem router to the WAN port as it is a modem router and NOT just a DSL-modem. The WAN port is intended for DSL-modems only. Not only consumers but also many technicians make that mistake
Aug 23, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
Bought a new laptop; want to connect it to this modem via wireless
is your pcx1100u cable modem is not wireless ready? only router have a wireless lan... buy it...
Jun 16, 2009 | Toshiba PCX1100U High Speed Cable Modem
Connected to the internet, but cannot browse any webpages
i think u have soem firewall isse in router also try to reset router then check .
reset switch in back side of router.pres it for 10 seconds .then it reset to defaults.
Mar 28, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
Trying to connect asus netbook to wireless connection
If you open your Network window from the start menu, at the top you will see "Add a wireless device". Follow the instructions and this should get your wireless connection with WEP key add. (When you select your router, you will need the WEP key at hand. You can get this by going to the web page of your routers IP address.) Good Luck.
Feb 09, 2009 | ASUS Eee 4G Notebook
No wireless
try to chage the type of security in u r router ...that would fix
Jan 08, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Cannot connect wireless device
If you have the correct wireless security and the laptop wont connect wirelessly, the best thing that you can do here is to access the router setup page and change some wireless settings on the router like the wireless channel , I advice you set the wireless channel to 11 then after that try to connect your laptop again to the wireless network and by the way change also the SSID or wireless network name of the router....
Nov 04, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Hi there, I just bought a netgear Rangemax next wireless router WNR834B with RANGEMAX™ NEXT WIRELESS N USB 2.0 ADAPTER – WN121T with no installation CD and i have connected the router to my modem and its...
Get the driver for the WN121T from the NetGear webset and install it before pluging the adapter into the notebook. Use a wired connection on the notebook until you have the drive downloaded.
Jun 19, 2008 | Computers & Internet
Loss of connection
This problem is mainly cause by the router firmware, so I advuice you to contact Netgear and ask them to update the firmware of your router to resolve this problem that you have....
Apr 21, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
NetGear RangeMax  NEXT WNR834B Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
