Question about Car Audio & Video
I have just brought a GMD8400M PIONEER MONO BLOCK CAN YOU SEND ME THE DIAGRAMES ON HOW TO INSTALL IT.
    Scholar:
  • 96 Answers
Http://www.pioneerelectronics.com/StaticFiles/PUSA/Files/GM-D8400M_OwnersManual1128.pdf
thats the link to the owners manual enjoy.
if you ever want to upgrade to a higher quality amp let me know, for about 300$ i could have gotten you into a 2000 watt RMS mono block class d that is competion grade.
for a 600 watt like what you have i coulda gotten you into it for about 210 - 225
and for the same amp that you bought i coulda done for about 200
pioneer decks are really nice but the amps are only low to middle end grade.
Posted on Sep 17, 2008
GM-102
You could hook up speaker wires from radio directly as it has a converter built in. If you are using an aftermarket radio it has RCA jacks. So not needed.
Mar 08, 2014 | Pioneer Gm-102 Car Amplifier 2 Channel /...
Power light flashing
This means it is blown. Whenever the power light flashes on any amp it is blown or something else is wrong with it. Most likely its blown. You can blow am amp by hooking it up to a powerful sub and blaring it, or just overheating it. Hope this helps. This can usually be fixed as well
May 07, 2013 | Pioneer Gm-d8400m 1200w Max, Class D Mono...
I have 2 Pioneer TS-W3002D4 12 In and a Hifonics Brutus BRZ1200.1D D-Class Mono Block what's the best wiring
you need to wire each sub down to 2ohms then wire them together like the one in this pic http://m.seimg.net/product/img/subwoofer_wiring/2_subs_DVC_4_ohm_mono_variation2.jpg witch will give you 1ohm so you will be getting every bit of power that amp has but you should get a bigger amp for thos speakers
Mar 24, 2013 | Car Audio & Video
I have 2 pioneer 6x9 400w, pioneer GM 6500f 760w amp and a kenwood KFC W1012 sub, how d i get the best sound from these?
pioneer gm 6500 is a 4 ch amp rated at 60w-4 way to small of an amp to run your sub. UNDER-POWERING your sub is more likely to damage spkr than over-powering. my advice,get mono-block to run sub
Jan 04, 2013 | Pioneer 6X9 5WAY 400W SPKR Car Speaker
Ihave a gm-d84004m 1200 watt amp whatsize amp wires should i use
if you are talking about the power and groung use atleast 4 gauge for the subs i usually use 10-12 gauge
Jul 10, 2010 | Pioneer Gm-d8400m 1200w Max, Class D Mono...
800 watt pioneer mono block blue light comes on then goes off
sounds as if u have a short going on somewheres maybe a loose gound wiredo u have the gain set to hi.check all connetions..check sub connections a sub short will put your amp in protect mode
Sep 01, 2009 | Pioneer 800W Class-D Mono Amplifier With...
Protection mode on my amp
YEA CHECK THE OHMS ON THE SUB TO MAKE SURE THEY MATCH UP TO THE AMP JUS SOUNDS LIKE THE WIRING IS OUT OF PHASE.
Jun 15, 2009 | Pioneer GM-7200M Car Audio Amplifier
NO REMOTE TERMINAL ON PIONEER GM1200 AMP
does it function properly with just the power and the ground?If so try using a ordinary fuse breaker(switchable on/off) and mount it in the cabin of the vehicle where you have easy access to it and can shut it off and turn it on when you need to- Its not necessary to have the remote lead connected to it if it functions well without it.
May 29, 2009 | Pioneer Gm-d8400m 1200w Max, Class D Mono...
Head unit
If the display goes out then it is possible the flex cable is broken. Return it to Rockford for repairs.
Jun 19, 2007 | Rockford Fosgate RAV DVD1 Car DVD Player
Car Audio & Video Logo
96 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
