Question about ButtKicker BKA1000-4A Amplifier
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the time, any solutions?
  • ben_sharman
    ben_sharman Apr 12, 2013
    Hi. Yeh i've just started experiencing the same. im using my Buttkicket on my PS3 console connected up with 5.1 Logitech Z906 surround sound system. it work fine the other day then went to play on my racing simulator today and the light stayed organge. Couldnt not get the light to go green and it was less then 24hrs since i last used my simulator and it was working fine. Can anyone advise on how to solve this problem?
  • 3,289 Answers
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Posted on Sep 20, 2011
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
The sensor light are different colors
The sensors are seeing something directly in line with the beam between the 2 sensors, or your sensors are not aligned so they point directly at each other.
Jan 12, 2013 | Craftsman Sears Liftmaster Garage Door...
Why won't the orange light turn off on my canon ip100 printer?
possible soution
check printercartridge and scan print alignment paper
setting option have mentinanceoption use mentinance option
May 19, 2012 | Canon iP100 Portable Inkjet Printer
My C355Bee amplifier will not switch on. The power light stays on orange and won't switch to green.
This is usually called "protect mode". See the link below for an explanation. If the unit remains in this condition even after disconnecting all speaker wires, it likely will require service. Please update this if you need further information.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
May 29, 2011 | NAD C355BEE Amplifier
I lost my manual to my duracell instant jumpstart . Just wanna know to properly recharge my unit.
I'm having the same problem where it won't take a charged. If you left it with a dead battery for say 6 months, it probably ruined the battery. You should have a charger for house current and car voltage charger. I guess your dead in the battery like me. I'm taking it to Battery Plus to check it out. It only had a 1 year limited warranty. Good Luck.
Oct 30, 2010 | Duracell ® Instant Jumpstart System
Stereo wiring harness need to the colors and what they do? for a 1997 mercury mountaineer
cannot find 97 but found 98. Do these match?
1998 Mercury Mountaineer Car Audio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Light Green
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6? x 8?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): Dark Green/Orange
Right Front Speaker Negative Wire (-): White/Light Green
Car Audio Rear Speakers Size: 6? x 8?
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Oct 16, 2010 | 1997 Mercury Mountaineer
Xbox won't power up, orange light is on the power brick
Are you using a plug and play kit? if so disconnect it, mine does that sometimes, if thats not the case comment me,I would write them all down but I am getting a bit fed up with writing lots of solutions to problems and getting no response from the person I give the time to help.
Feb 13, 2010 | Microsoft Xbox 360 Console
My presario 6000 starts, but then it turns off after about 10 sec
do you know how 2 remove your memory? sometimes computers go crazy like this when you dont clean it regularly try 2 remove memory clean the slot with a brush as well as the memory. then put it back and see what happens. worth a try...
Jan 28, 2009 | Compaq Presario 5000 PC Desktop
Car stereo wiring (1993 Ford Taurus GL)
My guess is that ford did not change that much in a year.
1994 Ford Taurus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Yellow
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: Orange/Blue
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Pink/Light Green
Left Rear Speaker Wire (-): Dark Blue/Orange
Right Rear Speaker Wire (+): Pink/Light Blue
Right Rear Speaker Wire (-): Tan/White
Jan 13, 2008 | Car Audio & Video
ButtKicker BKA1000-4A Amplifier Logo
2,338 people viewed this question
Top ButtKicker Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a ButtKicker Audio Player and Recorder Expert? Answer questions, earn points and help others
