Question about Sub-Zero Refrigerators
Sub-Zero freezer 600 series - flashing 'vacuum condenser'. I've taken the vents off and cleaned areas, however, the message light does not come off. And the freezer has formed ice on the back walls.
Our is doing the same thing, except we do not have ice forming on the back of the freezer. We were told by a refrigeration repair company that if ice is forming on the back of the freezer then the compressor is bad.
Posted on Sep 22, 2008
My freezer drawers are very warm All food defrosted smells horrible even after cleaning. Should I clean condensor, temp is not cooling?
It is likely the condenser fan is not functioning, or the condenser is dirty. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Jan 01, 2013 | Sub-Zero 700 Refrigerator Freezer...
Freezer not getting below ) degrees vacuum condenser message keeps flashing
The condenser is the 'radiator' located under the unit near the compressor. If it's clogged it will cause this. Make sure, also, that the fan at the condenser is operating.
If you've not yet cleaned the condenser, do so with a vacuum both sucking, and then blowing, to clean it well. BE READY FOR A DUSTY MESS!!
Jun 17, 2011 | Sub-Zero Freezers
My 632 is flashing EC 40. What is the problem?
Here's a list of all error codes for the 600-series Sub-Zeros.
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
EC40 = Excessive Freezer Compressor Run
Mar 24, 2011 | Sub-Zero 632 / S
The ice cube indicator is blinking
From the manual:
The Control Center monitors refrigerator and
freezer temperatures as well as the ice maker
system. If there is a temperature or ice maker
problem, you'll be alerted by a flashing
SERVICE indicator light. This same SERVICE
light will also flash if the condenser needs
cleaning. Before calling for service, please
check and see if your condenser area needs
cleaning. Refer to Condenser Cleaning,
page 22.
CONDENSER CLEANING
In all Built-In models, the condenser is located
behind the grille. First, remove the grille. Then
using a soft bristle brush, vacuum to remove
dust and lint from the condenser. NOTE: To
avoid bending the condenser fins, be sure to
vacuum in the direction of the fins (up and
down). Clean the condenser area every three
to six months.
CAUTION
Before cleaning the unit, shut the electricity
off at the control panel. When you
clean the condenser, wear gloves to avoid
injury from the sharp condenser fins.
Failure to clean the condenser could
result in temperature loss or mechanical
failure or damage.
Mar 14, 2011 | Sub-Zero 650 / O Bottom Freezer...
Can you assist with this problem? The freezer of my Sub Zero model #690 is not freezing hard enough and a light blinks that says "service" next to the temperature control button. I don't have a...
Dear claymier,
I'm sorry to hear that your unit has a 'Service' indicator flashing. This message is displayed when the unit has had to run for an excessive period of time. This means that your unit is having difficulty cooling and as a result is running more often than normal.
My first suggestion would be that you turn off your unit and clean your condenser. Cleaning your condenser on a regular basis will help keep your unit running efficiently. While your compressors run, air is drawn through the condenser area where dust and/or pet hair can collect. Our recommendation is to vacuum this area at a minimum twice a year. Failure to do so could result in temperature loss, mechanical failure, or damage. Turn off the unit when you clean the condenser. This will reset the 'Service' indicator.
You will find instructions on how to vacuum your condenser in your Use & Care Manual. We also offer a video that provides clear instructions on our website, which you can view by following the enclosed link:
http://www.subzero.com/livingkitchen/lifestyle/videogallery.aspx
After trying this, if your unit is still having problems keeping temperature or if the service light has come back on, I would recommend that you contact a Factory Certified Service company. To find a Factory Certified Service Company in your area please use the link below. Enter your zip code, select 'Service, Repair and Parts
Jan 31, 2011 | Sub-Zero 690 Side by Side Refrigerator
Vacuum condensor light flashing and the refrigerator won't get colder than 51 degrees.
The light is indication a problem with the condenser coils being covered with dust/dirt and cannot dissipate the heat energy absorbed by the system in the evaporator coils (freezer). Or the condenser fan is not running. Clean the condensor and/or check the fan.
Nov 12, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero--Vacuum Condenser Signal Won't Turn Off
The vacuum condenser indicator keeps flashing on and off. I did vacuum the unit, the the indicator lights keeps flashing on and off. How can I reset it and keep it off?
Thanks,
Rob
Aug 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
601R sub zero vacuum condenser notice
Your problem might be serious enough to warrant a repairman's visit. But this was my experience: An official Sub Zero repair company in NYC told me this: If the "vacumm condenser" light keeps flashing after you've opened and cleaned the condenser grill, then either pull out the plug for the Sub Zero refrigerator or turn off the circuit breaker (or fuse) in your house that leads to it, wait for some minutes and then turn back on. It is NOT enough to turn off the unit using its own internal on-off switch - it has to be totally disconnected from the AC. I did so, waited 15 minutes, turned back on, and it worked!! I had vacuumed the condenser grill twice but the "vacuum condenser" light kept flashing AND the refrig would go bonkers if set below 38. Now the flashing warning is off and it's down to 35. Great !!!
Jun 27, 2009 | Sub-Zero 601R
Vacuum condenser light of sub zero 650 is on - how to clean it
We recommend vacuuming your condenser every 3 - 6 months. Cleaning the condenser is important for the overall operations of the unit including cooling functions. A dirty condenser may lead to warm temperatures in the refrigerator and freezer. It may also cause the unit to run excessively. It may contribute to condensation or frost inside of the compartments. If the condenser is not cleaned properly it may even cause premature failure of mechanical components in the unit. Condenser Cleaning - All Models Before cleaning the unit, shut the electricity off at the control panel. When you clean the condenser, wear gloves to avoid injury from the sharp condenser fins. Use a soft bristle brush and vacuum to remove dust and lint from the condenser. To avoid bending the condenser fins, be sure to vacuum in the direction of the fins, up and down. Clean the condenser every three to six months or sooner if you have pets. 600 Series Framed and Stainless Steel louvered grilles: First remove the grille screws located at the bottom of the grille. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. Overlay Panel Grille: To remove, lift up then pull out at the bottom and down to release from its mounting bracket. Remove the two black screws in the lowest louver of the grille. Tilt the bottom of the grille out and away. It will release from the top of the grille. Model 601RG Stainless Steel Grille: Remove in a similar fashion as the overlay grille panel. 700 Series All Units: At the bottom of the unit, remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 400 Series 424/424FS At the bottom of the unit, remove the screws holding the kick plate. The condenser is located behind. 427/427R: Remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 430: First remove the screws located at the bottom of the grille. NOTE: These screws (Phillips head) are accessed with the door open. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. 200 Series 245, 249, 315W Remove the kick plate at the bottom of the unit, giving you access to the condenser area.
May 30, 2009 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
521 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
