Question about Electronics - Others
Pen Drive have purchased a pen drive 1Gb Moser Baer. but after couple of days i am not able to copy any data or not able to format it.
  • ranjan_bhoi Jan 18, 2009
    i have 1GB moaserbaer pendrive, when i insert it to my laptop its showing
    USB device is malfunction, USB device is not recognise
  • 75 Answers
Try with other computer...then also it doesn't get work,replace it if u have warranty for tat
Posted on Sep 23, 2008
2 Suggested Answers
Orbixx
  • 133 Answers
SOURCE: Pen Drive writet Protection
The first thing to do is try it in a different computer to see if you get the same problem. Flash drives, as far as I've seen them, have no option to enable write protection unless you have it specifically set like that in your operating system. If it works on a different computer, you can safely put it down to a problem with your computer and not the flash drive. On an off-chance, check for any sort of slider on the flash drive (like on floppy disks) - if there is one, toggle it and try again. Good luck!
Posted on Sep 07, 2007
The Pen drive is detected in PC but no data is shown. Not able to open the files in the folders as it is shown that data used is 0 bytes and available is 0 bytes. Please solve
This is what you should do to sort out this problem:
Put the pen drive in to a different computer that the pen drive works on and copy all files and folders off of the pen drive on to the computer. Then you must right click on the pen drive in "My Computer" and click "Format", once the pen drive has been formatted, replace all of the files and folders on to the pen drive and it should now work.
Thank you for using FixYa! Have a nice day an please remember to rate this solution.
Warm regards,
BearWeb
Jan 09, 2010 | Transcend (589307) Media
Disk is write protected
first insert your pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
Jun 27, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Cannot open my usb-drive (pen drive or external storage device)
did u check same flash drive into another computer????.. if prob remains then may be some prob ...... u can try it try to navigate through folder option in left panel......... and enter into the content....
if it wrks nt for you then report me............
Mar 30, 2009 | Electronics - Others
Pen drive is not working properly
try to replace the unit.
it is possibly faulty.
also you should note that pen disks are not as reliable as hard drives.
Jan 23, 2009 | Electronics - Others
Pen Drive is Not able to write the data
i had purchased a pen drive of Moser Baer AZ-601USB device. previously it was working good, but since last 3 days i could not open my pen drive..it asks for formattin. i have formatted it , but after that it says your pen drive is write protected. so i could not open and use my pen drive....
so plz solve my problem to open my pen drive.
Dec 20, 2008 | Electronics - Others
How to format a pen drive?
I know about this problem and the solution.
First, you should know your pen drive is infected with a virus. You can't usually repair it, you'lll just have to format it, and I'm getting to that.
Now, Before you format the pen drive, you might want to preserve some files in the drive?
Instead of trying to view the pen drive by double clicking or right click=>open TYPE the ASSOCIATED DRIVE LETTER at the RUN DIALOG BOX (start=>run)
Eg:
If your pen drive is assigned to drive E:
Start=>Run
Type "E:" (without quotes) and hit enter.
It should open.
Now you will probably see some weired .exe file, probably named fun.exe. That's the virus. You just cant delete it. BUT you can copy the rest of the imprtant files to your hard drive.
TO FORMAT
Start=>Run
type "cmd" (without qoutes) and hit enter
type "format/x E:" (without qoutes and mind your spellings and spacing. REPLACE "E:" with the associated drive letter of the pen drive)
Hit enter.
Hope my info fixes your problem,
Thanx for using fixya.
Sep 30, 2008 | Fuji (MAP3367NP) 36.7 GB Hard Drive
Moser baer 4 GB pen drive is not working
i have 4gb moserbaer pen drive when i inserted it in to the Xp system it give the message "Insert disk"
plz. solve this problem.
Aug 05, 2008 | Computers & Internet
Pendrive write protection removing
Hey, the transcend pen drives usually have a small switch on the side of it, ie to turn the write protect on and off, usually a small lock symbol on it, the problem with unreadable files names etc, could be a corrupt partition, i would suggest formatting the drive as long as you aint got any important information on it,
All the best
John
Jul 27, 2008 | Computers & Internet
Moser bear pen drive
i purchased a 2GB moser bear pen drive. neither it open not shows any type of indication.
Nov 07, 2007 | Electronics - Others
i have a best solution of this..u can format pen drive....by autility........u can download from this link...."" http://www.box.net/shared/9hgp81ndgs "
Sep 07, 2007 | Electronics - Others
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
