Question about Bosch Refrigerators
I have a fridge freezer (can't remember exact model) however we seem to get a small puddle of water at the bottom of the fridge section (front left as you look at it to be precise) although the fridge seems to be working OK and we have defrosted it since the problem began it is still happening..??
    President:
  • 1,462 Answers
Check if there is a gulley on the back wall of the fridge with a drain hole in the middle. if so, this drain may be blocked. poke something flexible down the drain till water flows away freely
Posted on Sep 17, 2008
Every few days I find a small puddle of water near the front left corner under the freezer of my TFH22JR.
Guys, . . . small puddle of water on the FRONT left side?? Y'know, . . under the FREEZER door??!? Maybe check the John Guest quick connect/disconnect fitting at the bottom of the freezer door just behind the front cover. It may not be fully connected, or may have a seal worn-out.
Apr 12, 2014 | GE Refrigerators
I( find a puddle of water on floor at front left hand corner on freezer side..I took the freezer drawer out and found ice build up under it ,could this cause my problem.. this happened about every 24 hours...
The problem with your refrigertor is that the defrost drain is plugged up. After you get the ice buildup out of the freezer section you will have to locate the drain system. It is in the back of the freezer at the very bottom.It needs to be cleaned out. Hope this at least leads you in the right direction.
May 27, 2011 | Maytag MSD2756G Side by Side Refrigerator
Water leaking from bottom
Between your freezer section and refrigerator section there is a draintube that allows water to flow from the freezer to the fridge during defrost. You will need to remove the rear wall of the freezer to access the freezer part and the center console of the fridge if one is there. Once you have determined that tube is cleared of ice you will need to continue tracing where the water flows which is usually at the top of the fridge section in the rear center. It goes out the back wall there. Make sure thats all cleared and pour a small cup of water in the freezer part to be sure its clean. Observe the water flow all the way out of the tube to the lower part of your unit into the drain pan which is located at the very bottom or in the rear on top of the compressor.
May 22, 2010 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
My Fridgidaire Professional series refrigerator has a puddle of water in front of it about once every other day. The puddle is around the front on the freezer side of the fridge. What can I do to fix this?
Drain line in the freezer section is clogged, needs cleaning. There is a small drain pan on the bottom of the rear wall in the freezer. It is covered with ice. Defrost or remove ice, and get to the drain hole. try flushing with hot water, if does not help - clean mechanically on both sides of the drain line - in the freezer and in the back of the fridge, where it comes to the drain pan near condenser/compressor.
Oct 16, 2009 | Frigidaire Professional 26 cu.ft....
Water leaking from bottom of fridge (freezer) onto floor
This is a very common problem and has several reasons that may cause the problem. I have a lot of information that covers the different ways that this takes place and hot to to resolve the problem all on one page. So read the complete page and choose the part that most fits your refrigerators condensate overflow. Thanks, Sea Breeze
Click on link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 16, 2009 | Kenmore Refrigerators
Water in the bottom of the fridge
Hi, The drain in the freezer section is plugged. Please get me a model# so I can see the exact model and instruct you on repairing this problem. Some models require an after market drain heater to put in.
I can help you through this.
Vic
Jun 13, 2009 | Kenmore 64179 / 64172 / 64174 Top Freezer...
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Kelvinator fridge
The freezer defrosts every day. the puddle is from that. It is supposed to go into a pan at the bottom and evaporate. You need to look at the pan and determine if it has a hole or the drain hose is leaking somewhere.
Feb 09, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Refrigerators Logo
128 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
