I have an Acer Aspire 7520 (new February 2008). Never been able to use number keyboard on right hand side. Really annoying me now! Any quick fix? Thanks.
    Master:
  • 505 Answers
Press the number lock key once than it should work. the key says ((( num Lock )))
Posted on Sep 17, 2008
Non functioning keys due to spilled wine on Acer Aspire 7520-5311
It's most likely done , shut down, remove battery, remove keyboard , try to clean. Replace if necessary. Rarely does liquid of any type do electronics any good.
Dec 15, 2012 | Computers & Internet
Where is the WLAN switch on the Acer EXTENSA 52325
i Found this on product manual..hope this helps.
ACER
Acer (General) - FN+F5
Aspire 1000/1640Z/1690/2012 - Launch Keys above the keyboard
Aspire 16xx (General) the satellite-like launch button above the keyboard
Aspire 2000 Series (less Aspire 2012, See Above) - Button on the Front of the Laptop
Aspire 3005 on the lower right-hand side of your laptop
Aspire 3500 -
Aspire 5612 sliding button on the side of the laptop
Aspire 9302 the blue button on the left-hand side of the laptop
Aspire 94xx (General) the key found below the Lock key
Aspire One, in the lower right corner of the palm rest is a small strip with a picture of an antenna on it. An LED to the right of the strip lights to indicate the wireless is turned on.
Aspire One Series ZG5 -
Extensa 2000/2500 Series - Far Right launch button above the keyboard
Ferrari 3000/3020/3400/4000 - Button on Front of Laptop
Travelmate C Series - Far Left hot key and then choose WLAN from menu that appears
Sep 09, 2011 | Acer Aspire 5100 Notebook
Hi i have got a new keyboard and wish to change it on acer 7520
taken from http://www.batterycentury.com/acer-aspire-7520g-502g25mi-keyboard-p-152819.html
Acer Aspire 7520G-502G25Mi Keyboard Repair and ReplacementAre you considering laptop keyboard repair? You might think twice if you happen to be the lucky owner of a laptop, because replacing the keyboard rather than repairing it could be a lot less expensive. Laptop keyboard replacement on this particular model is very easy and takes just a few minutes. Here is a quick Acer Aspire 7520G-502G25Mi Keyboard repair tutorial with step-by-step instructions. Once you have purchased the new keyboard, all you need to replace the old with the new is a screwdriver and something plastic, flat and thin like a credit card or guitar pick.
Step one: Remove the two screws from the bottom of the computer that are holding down the Acer Aspire 7520G-502G25Mi Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step two: Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the laptop screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the Acer Aspire 7520G-502G25Mi Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire Acer laptop keyboard.
Final step: To insert the new Acer Aspire 7520G-502G25Mi Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the Acer Aspire 7520G-502G25Mi Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
May 16, 2011 | Computers & Internet
HI WHICH KEY DO I USE FOR THE WIFI SWITCH ON AND OFF.FOR THE ACER ASPIRE ONE NETBOOK?
Thank you for choosing FixYa
How to Turn on/off wireless switch of ACER laptops:
Aspire 3500 -
Hope this help!!!
Apr 10, 2011 | Computers & Internet
How do I get the pound symbol on my keyboard ?
If your Operating System is MS Windows, go to Start / Control panel / Regional Settings (or Region and Language for Win7) / Keyboards and Languages then add the English/UK keyboard or simply hold the ALT key and type 0163 from the numeric keyboard.
Mar 04, 2011 | Acer Black Acer Aspire Keyboard...
Number keypad on right hand side of acer travejmate 7520 not working
you must press the number lock key to make them work. (please rate if this helps Thank you)
Dec 22, 2010 | Aspire Acer 7520-5071 Notebook
Acer Aspire 7520 numeric keypad problem
Try pressing the numlock key in the upper right part of your keyboard. Chances are it's turned off and therefore the numeric keypad will not work.
Feb 05, 2009 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
