Question about HP Computers & Internet
Hi and good morning... Here we go... I'm trying to load XP on a d530c/p2.4 PC it appears to load but then switch to "DO NOT TURN OFF COMPUTER DURING THIS PROCESS" the system then locks at this point and remain there. I have tried loading from HP restore cd's and other cd with XP on but the system keeps returning to the above message in quotes. By the way HP idea is to reseat the memory slots, no use. david.deleon@banca.mps.it
    Sergeant:
  • 300 Answers
Open the computer and see if things are getting too hot.
Overheat durring install is common.
Az.
Posted on Sep 17, 2008
Need to download dell sata drivers to install windows xp
Do you the install disc.put it your cdwriter.let windows start from it and loading files.choose then to repair the computer.if that do not work but it should.try CMD in safe mode.as Admistrator write. SFC /SCANNOW it will tell you if it is any corrupt files as you think good luck mike.
Apr 02, 2013 | Dell Dimension 3100 PC Desktop
Tip
How can I restore my PC?
<span><span> <p><span><span>If Windows is running (and you are logged in as administrator), choose <b>Start </b>&gt; <b>Programs</b> &gt; <b>Accessories</b> &gt;<b> System Tools</b> &gt; System Restore. Select "Restore my computer to an earlier time" and click click the Next.Now last checkpoint and click Next. <b>System Restore</b> message may appear - click OK. Now click Next on the confirmation page and the latest Windows XP configuration is restored. If you can not get Windows XP to start, press [F8] at boot and select "Last Known Good Configuration 'to load the latest <b>Windows XP</b> restore point loaded</SPAN><span></SPAN><span></SPAN><span><span></SPAN><span></SPAN>.</SPAN><span></SPAN><br> <P style="TEXT-ALIGN: left; TEXT-INDENT: 90pt; MARGIN: 0cm -16.7pt 0pt 0cm
on Feb 14, 2011 | Computers & Internet
Hi, While trying to install xp blue screen appears. "Driver_irql_not_less_or_equal" stop error 0x000000d1....usbport.sys problem. cannot go on. could you please help me Mualla
Drivers are not loaded. I expect it is confused or you are installing XP on a non compatible machine.
You don't mention the make and model.
Jan 06, 2011 | Computers & Internet
My computer wont turn on it red lights instead of green
there is a possibilities that the motherboard has a problem? usually it gives a beep code to indicate the problem.. you can also check the Memory (RAM) on you pc. try to reseat it. then try to open it again. If that still doesnt work, you can call the Manufacturer of your computer if you still have a warranty for it.
Cheers!!
Aug 19, 2010 | HP D530C W2K PRO
Hi Good Morning....RAM is upgraded to 512MB ( 256
Ive seen a lot of Pentium 4 computers sell on ebay for less than $50 so no i wouldnt bother repairing. Cheers from Scott
Jul 13, 2010 | Dell OPTIPLEX PIII-450MHz 128MB 6.4GB...
My uncle's hp compaq d530c will start up show windows starting then comes a black screen with white wording saying that you want start up normally? you press yes it takes you back to the windows xp trying...
Turn the computer off and then disconnect all the external devices like (printer,usb devices etc)connected to the computer along with the cable for the internet .Then disconnect the cable for power that would be right on top at the back panel of the computer tower and with the power cable disconencted press and hold the power button for atleast 30 seconds.Turn the computer on if it takes you to the desktop then it means that there is some external device that is causing the computer not to come up to the desktop so find which deveice has gone bad check it by conecting one device at a time.
Next thing that you can try is turn the computer off and then when you turn the computer on or as soon as you press the power button to turn the computer on start tapping the F8 key repeatedly until you get a black screen that says advance boot menu option .Then used the arrow keys on the keyboard and then hit enter,select the operating system and then when you get the log on screen select administrator .If it takes you to the desktop then you can try doing a restore by going to start?all programs ?accessories?system tools and then system restore ? select the date when you think that you r computer was working fine and then click on next next to exit from the wizard.Should fix the issue .
If it takes you to the desktop and the restore does not work then go to ?start?run?type in msconfig?when the system configurtation utility page loads up the go to the startup tab click on disable all?apply ?go to the services tab?disable all?apply and ok to close the page and then restart the computer.If it takes you to the desktop then go to msconfig click on enable all for startup ,restart the computer .If it boots up normally to the desktop then there is a service unders services that is causing the problem,so we need to isolate the service that is is corrupt .Select a group of services and the restart if it does not boot the computer to the desktop then there is one service among the group that is not letting the computer boot up so check one service at a time and check .Once the faulty service is found let it be unchecked will not be a problem.
If the computer does not boot up to the desktop then without wasting time on any trobleshooting steps recovery needs to be done that takes the computer back to its original factory settings.To do this instead of the f8 key tap the f11 key till you get the screen that says system recovery ?click next until you get the screen that has advance option ?click on it ?select destructive recovery ?click next the recovery will start and the computer will be formated (whatever you have added after you bought the computer would be lost ).If the recovery does not work this was then it needs to be done from the recovery disks and fot that you call call HP...
all the best.....
May 20, 2010 | HP Compaq d530c PC Desktop
On a hp/compaq d530c after loading restore and os the second time it reboots to finish the restore it hangs and the drums still beeting.have you seen this.tried 3 sets of restore and os disks 2 hdd system...
if ur trying to use the System Recovery Disks.. let me just tell u .. it will take atleast a minimum of 2 - 3 hours.. can take even more than that depending upon the type of softwares that were shipped to ur computer when u purchased it.. so thats normal.. let me know if it resolved ur issue or u still need help regards, Guru:-P
Mar 08, 2010 | HP D530C W2K PRO
Rocstor external hard drive does not appear in my computer win xp although message it was installed when I connected the usb port
Good morning! first, make sure your external hard drive is properly connected to the USB port, then try to start / restart your computer again, automatically the computer should recognized the attached external HDD. best regards.
May 02, 2009 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
