Question about Sony Ericsson Walkman W810i Cellular Phone
Keys have stopped working suddenly
Hi.. my number keys 1,2 & 3 navigation downkey , and answer key on left top corner of keypad have stopped working ..
how do i resolve it..
  • cierababeesX Oct 27, 2008
    i have the same problem but its all my keys 0123456789 its really annoying
  • Aladdin Minic
    Aladdin Minic May 11, 2010
    Do the keys feel the same as pressing the 456789*0# keys?
  • 61 Answers
Return the phone for a new one if you have insurance on it.
Posted on Sep 22, 2008
    Brigadier General:
  • 7,752 Answers
Take the phone and have the keyboard service or replaced to fix this problem
Posted on Sep 20, 2008
Can't get past lock code
Laptop computers have the advantage being portable and self-contained, but among their drawbacks is a keyboard without a separate number keypad. While for most applications number keypads are unnecessary, they can be useful for data entry. Laptops sometimes provide a number keypad by giving certain keys double duty, allowing them to enter numbers rather than letters when a "Number Lock" setting is turned on. Number Lock, however, can get turned on accidentally, or enabled by an operating system by default, which can really mess up your typing. If typing "M" ends up displaying a "0" on your screen, Number Lock is probably the problem.
Try to locate the function key. On a T-series ThinkPad, it's in the lower left hand corner. It should be labeled "Fn," and the lettering may be blue, green or red instead of white. If your laptop lacks a "Fn" key, use the "Shift" key for Step 3 below instead. Locate the key labeled with "NmLk". On a T-series ThinkPad it shares a key with "ScrLk" which sits on the very top row between the "PrtSc" and "Pause" keys. On other IBM laptops, the "NmLk" key might share a key with "Delete." While holding down the "Fn" key or the "Shift" key, depending on your model, press the "NmLk" key. This should turn off Number Lock and restore your keyboard to its usual state. Number Lock on an IBM laptop is a "toggle" setting. You can turn Number Lock on by following the same steps.
b>
Feb 05, 2013 | IBM ThinkPad Computers & Internet
When i type the letters on my keyboard, the numbers show up instead. i don't know how to revert the system or functions back to normal. i must've accidentally pressed a button to change the characters when...
Sounds like the keyboard is in NUM LOCK mode
They keys map like this:
7 8 9 = 7 8 9
u i o = 4 5 6
j k l = 1 2 3
0 . = m .
Look for the NUM LOCK key on your keyboard.
Typically, you press the FN key (lower left corner) and the NUM LOCK key (typically towards the upper right) together to put the keyboard back into regular mode.
Apr 21, 2011 | Twinhead DURABOOK N15RB Notebook
The numbers 1-3 on the keypad wont work
Warning
In the keyboard test (below), make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the beginning of the post and skip to the last part For Repairs )
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the diagnostic tests.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Release the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterward you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a high pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.-
For repairs
You can also try this site. They do repairs on most models, except the newer ones.
Jun 03, 2010 | HP 48gx Calculator
How do i turn off the alarm on the samsung jack
While in standby mode, press the left soft key for Start
Select Organizer
Select Alarms
From the Alarm screen, highlight Wake up alarm (1)
Press the left soft key for Edit
Press the OK key to check a box, then enter the time for the wake-up alarm, using the keypad
Press the OK key to check the boxes for the desired days of the week
Highlight Tone, using the navigation keys
Select a melody for the alarm Tone, using the navigation keys
Highlight Snooze, using the navigation keys
Select a Snooze time interval, using the navigation keys
Press the left soft key for Done to set the Wake-up alarm
Note: You can set up to 3 different wake-up alarm times, but not on the same day
Nov 26, 2009 | Samsung Jack Cell Phone
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Keypad buttons ( navigation keys only) not working
Both navigation keys and number keys stopped working
any ideas
Aug 18, 2008 | Nokia 6500 Slide Cellular Phone
I need to remove a # from the rejection list
go to - menu-> settings-> application settings->  call->  all calls->  auto reject-> (scroll one down) reject list->
[on the reject list uncheck number you wish to remove from the reject list. ]
-this is the most accurate answer, trust me.
Jun 18, 2008 | Samsung Cell Phones
Navigation keys act like menu access/confirm key
get to the security options and set factory defaults the code is 00000000 eight zeros
rate me
Jun 08, 2008 | Samsung SGH-ZV40 Cellular Phone
Help needed on N95 8GB
This problem is from your keypad Ic, Possibly it is working automatically. You need to change Keypad IC and then software re-install.
May 12, 2008 | Nokia N95 Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
57 people viewed this question
Top Sony Ericsson Cell Phones Experts
Sandeep Shenoy
Shehu Pro
Shehu Pro
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
