CD/DVD missing there's an exclamation mark on my device manager
  • 37 Answers
1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list. If you are prompted for an administrator password or confirmation, type your password, or click Continue. 2. Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM. 3. In the right pane, right-click UpperFilters, and then click Delete. 4. Click Yes to confirm the removal of the UpperFilters registry entry. 5. In the right pane, right-click LowerFilters, and then click Delete. 6. Click Yes to confirm the removal of the LowerFilters registry entry. 7. Exit Registry Editor, and then restart the computer.
Posted on Sep 18, 2008
    Sergeant:
  • 300 Answers
That means you have a missing driver.
The solution is to load the missing driver.
Use PC Pitstop to help you determine which driver is missing.
Az.
Posted on Sep 17, 2008
Missing my DVD CD rom
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard.
If this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and typeregedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computerOpen My Computer and check to see if your CD or DVD drives have returned.
You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Mar 10, 2014 | Gateway Computers & Internet
Hi all , my computer drive d icon and name has changed to CD Drive D and when i try to open it it it gives msg of "Please insert a disk in to drive D" , i think one 1 missed up with computer managem
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Mar 16, 2013 | Dell Computers & Internet
I have a sony all in one desktop pc pcv-f11m but the dvd-cd is missing. what one do i need for this?
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps.
Dec 07, 2012 | Computers & Internet
USB CD/DVD does not read
if you are referring to a usb drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope it helps
Jun 16, 2012 | Dell Dimension 9150 (DIM915MIN) PC Desktop
My dell optiplex gx1 cant read both hdd and cd rom pleas help me
Go on your desktop and right-click on the "My computer" icon and go to its properties
Then go to "Hardware" Tab and then go to "Device Manager"
In the Device manager, notice any yellow question mark or exclamation mark especially on the CD Drive. Right-click on it and choose update driver. The the driver installation wizard will take you through the process. When complete, restart the computer and try if its working. Do the same on the USB component in the device manager. This should solve you out of that, It means the CD Rom drivers as well as the USB are corrupt or missing...
If this does not work then consider using any software that scans your computer and reveals to you the drivers missing on it.
If this does not work, i think you just have to re-install your Operating system
Aug 22, 2011 | Dell OptiPlex GX1 PC Desktop
My cd\dvd rom will not read or write compaq presario cq51251t on device manager . shows an exclam.mark in yellow triangle but windows says the driver is up to date
Hi Friend,
Just remove the device with exclamation mark from device manager and restart your system. When your system restart again, automatically, it will detect the new hardware and install it properly.
Thanks,
Shiva
Dec 18, 2010 | Compaq Computers & Internet
Dvd driver shows yellow excclamation mark error code 41computer novice any simple suggestions would be appreciated
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
Because of this error, the drive did not show up in My Computer and the customer was unable to burn CDs or read any CDs.
I uninstalled the drive from Device Manager, rebooted the computer, and the problem remained, so obviously it appeared to be a registry issue that I would have to solve. If you are receiving this Code 39 error and your CD or DVD drive is missing and has a yellow exclamation mark in Device Manager, I hope this information is useful.
To solve this Code 39 error, follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot
your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone
Regards,
Pp
Dec 02, 2009 | Computers & Internet
When I try to resstall a DVD drive I get Windows
If you are receiving this Code 39 error and your CD or DVD drive is missing and has a yellow exclamation mark in Device Manager, I hope this information isTo solve this Code 39 error, follow these instructions: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
useful.
Aug 11, 2009 | Computers & Internet
HL-DT-ST DVDRAM GSA-T40L ATA DEVICE has run problem error code 39
1. Using Device Manager
To fix this error, first try to update the driver from the Device Manager. To open Device Manager, right-click My Computer on your Desktop, and then on the Hardware tab, select the Device Manager button.
In the Device Manager window, identify the CD or DVD drive item (with Yellow exclamation mark), right-click on it and select Update Driver. Follow the screen instructions to update the device driver and restart your PC.
if can't try this:
2.To fix the error by editing the registry, perform the following
steps:
1. Exit and close all applications currently running on your PC.
2. On Start > Run type Regedit and press the Enter key.
3. Next, navigate to the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
4. Delete any of the following registry entries if they exist under this key:
* LowerFilters
* LowerFilters.bak
* UpperFilters
* UpperFilters.bak
5. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
6. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
7. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
8. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone
Jan 02, 2009 | Computers & Internet
How to fix code 39 err
I was fixing a computer the other day and ran across the following error in Device Manager on the CD-ROM drive.
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
UpperFilters
LowerFilters
UpperFilters.bak
LowerFilters.bak
Another possible CD/DVD issue you may want to investigate
How to Correct Missing Copy to CD option in My Pictures in Windows XP
Oct 18, 2008 | Computers & Internet
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
