Question about Epson LX-300 Matrix Printer
Printer setting when give print the printer types only HEX DUMP also i can not get printer setting from that printer
    Scholar:
  • 162 Answers
The manual is here: http://files.support.epson.com/pdf/lx3pii/lx3piiug.pdf and the information is on page 15
Posted on Nov 29, 2008
How do I reset dcp-8045d hex dump mode
Probably the easiest way to turn off the Hex Dump mode would be to reset all printer settings. There should be a reset menu that will allow you to reset the printer to factory defaults. After which it should recognize the new ram and print normally.
Apr 02, 2015 | Brother DCP-8045D All-In-One Laser Printer
It states 'hex dump' on my printer and I don't know what it means
A hex dump is a list of hexadecimal numbers (base 16 numbers) of probably the contents of the memory.
This Hex dump is generated when the computer comes across a computer problem and can help Microsoft determine the cause and fix if this is sent to Microsoft.
Mar 13, 2011 | Office Equipment & Supplies
Printronix P5005B printer printing garbage after configuration
If using RS 232 serial communications, verify that host and printer settings match. Baud Rate, Parity,Stop Bits, 7or 8 bit word length. Example 9600,8,n,1
Or make sure it is not in hex dump mode.
Sep 24, 2010 | Printronix Line Matrix P5005B Printer
I am sending raw data to the printer. Where to find ESC codes for different control ops
This feature allows experienced users to see exactly what data is
coming to the printer. This can be useful in finding software
problems. When you turn on the hex dump function, the printer
prints all commands and other data in hexadecimal format, along
with a guide section to help you find specific commands.
To use the hex dump feature, follow these steps:
1. After you make sure the printer is off, open the cover.
2. Hold down the FEED button while you turn on the printer.
3. Close the cover.
4. Run any software program that sends data to the printer. The
printer prints “Hexadecimal Dump” and then all the codes it
receives in a two-column format. The first column contains the
hexadecimal codes and the second column gives the ASCII
characters that correspond to the codes.
Hexadecimal Dump
1B 21 00 1B 26 02 40 40 . ! . . & . @ @
1B 25 01 1B 63 34 00 1B . % . . c4 . .
41 42 43 44 45 46 47 48 ABCDEFGH
❏ A period (.) is printed for each code that has no ASCII
equivalent.
❏ During the hex dump all commands except DLE EOT and
DLE ENQ are disabled.
5. Open the cover to set the printer off line, so that it will print the
last line.
6. Close the cover and turn off the printer or reset it to turn off the
hex dump mode.
PLEASE CHECK THE LINK TO GET THE ESC CODES:
http://www.mit.edu/~vona/MSim/vona/terminal/VT100_Escape_Codes.html
Hope this helps u ..............
Feb 21, 2010 | Epson TM-T88III Thermal Printer
DCP 8045D Display says Hex Dump Load - What does this mean - How do I get rid of it
I resolved the " Hex Dump Mode" problem
Step1: switch off power
Step2: press and hold Stop/Exit ( Red Color Key ) switch on power supply .......
now no " Hex Dump Mode" problem
Jan 19, 2010 | Brother DCP-8040 Copier
Hex dump sheets instead of printing
This often will occur if the wrong drivers are installed. Try uninstalling and reinstalling your printer software.
good luck.
tony
May 18, 2009 | Epson AcuLaser™ 2600N Printer
Can't print from bottom drawer, will only print from tray,
There are at least three possible solutions. The first two are simple the third is fairly complicated unlr=ess you can read a hex dump of a print file. 1) Use the front panel "Paper Menu" to select the tray. 2) Check the driver settings to make sure the driver is set to "Auto" or the correct tray. 3) Set the driver to "Print to File". When prompted to name the print file, name it "tray_fail". If you do not know how to read this file, send it to me at janddgasrepair@verison.net and I'll be happy to take a look at it and see I I can correct the problem. Don
Jan 16, 2009 | Lexmark Optra S 1855 Laser Printer
I have a brady label machine 2461
Hex dump mode is mostly used for trouble shooting of the printer. To exit the hex dump mode, enter the Diagnostics menu / Hex
Dump Mode and select ‘Disable’. Exit the menu, save changes and
return to the ‘READY’ mode.
Dec 07, 2008 | Brady 2461 Thermal Label Printer
Epson LX-300 Matrix Printer Logo
169 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
