If you mean the shifter is getting hard to move, its probably the shift linkage sticking, try a couple squirts of pblaster or other penetrating oil. If the motion of the vehicle is getting hard to drive in reverse and drive the torque converter may be the issue.
Have you just replaced the clutch? Taken out the transaxle, and put it back in? Are you sure transmission was in good condition before this? If so, review your procedure carefully to be sure you got it all back right. Watch the slave cylinder while someone depresses clutch. You should see the little plunger move slightly out and move the clutch lever back. The lever moves the release bearing inside bell housing into contact with the pressure plate. If slave cylinder doesn't move at all, try bleeding again. The plunger has to move when clutch is engaged. I'm not sure what you mean by "will shift but won't go into gear". You mean it's actually going into a gear position and car won't move? Or it won't go into any gear, period. As if you had no clutch?
