Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
D52w20b turn on green light comes on few sec then shuts down can you help?
  • RCA Master
  • 5,138 Answers
Look on Deflection board see if capacitor 150 is open on top 2200uf 16 if so replace it and the two near by it 220uf 35volts other wise order new deflection board cost verys 125.00
Caps are Green with gold writing on them.
Posted on Sep 17, 2008
"Still no power". After replacing cp114, cp120, cp130 and cp 135 on my RCA D52W20B, when powered on the green comes on along with a high pitch sound making several attemps to power on before completel
The whine is a short somewhere---+ and - are marked on the board for each cap if it is polarized---usually the - will have a shaded white mark on top of board--if you got one in backwards it can explode......
Apr 13, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20B F013C30N4 when turned on the image it green
Does the set continue to play normal except for the green being too pronounced ? Or does the set turn bright green with curved lines then the set shuts down? Let me know and I will assist you.
Oct 15, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA model# D52W20B When I turn on the power the green power light will come on for a few seconds, go off, come on and go off again and stay off.What might be causing it to shut down? Thanks for any help. ...
yes u may have a problem with the power supply , bad capacitor on the power supply 2200uf at 25volts , thats the only cap with this value , it's right on the power supply
Dec 08, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
PSP will only power on about 10% of the time...
Just send it into to sony or buy another one sorry bud......
Oct 07, 2009 | Sony PlayStation Portable (PSP) Console
Power button lights up3 times then shuts down rca d52w20b
SORRY but only you can decide when enough is enough to waste repairing the dinosaur and move on to a more dependable unit .
Oct 08, 2017 | Akai PT5492S 54" Rear Projection...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Feb 15, 2008 | Mitsubishi WS-65313 65" Rear Projection...
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony proj tv,sound,green pict few seconds then shuts down
could be three different things.
1. could be the crt itself as a tube with dfective phosphure wil do this
2. could be the vertical ic on the crt board
3. could be the focus pac.  located in front of tv with 6 adjustment knobs on it.
Oct 06, 2007 | Sony KP-41T65 41" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
