Question about Toshiba e330 Pocket PC
My E330 in water,the touch screen cannot align,how enterinto the system?
Dear sir,
my E330 in water,and the touch screen cannot align,but you know the E330 can use the other key to control,so I want to drop the touch and instead of the hot-key.
the problem is how can I enter into the system and slip the touch test.
I'm eager to make it out.!
Thanks.
My mail:chinesenails@live.cn.
I'm in China.
  • wuchao Sep 17, 2008
    Thanks for your quickly response.
    You know we can use the PPC 2002 system,the first step we have to continue the Align Screen Test,I want to know how to jump the Test and dirctly to the PPC2002 Destop.
    I can use the hotkey to continue to control the machine.
    Waiting for your reply.
  • 4 Answers
The IC(integrated CIrcuit inside your phone is damage since it getting wet.the IC that connect your touch screen and and the main processor is damage,the only way is to change the iC quick possible you can sent to their service center and ask them for tecnical support.i your warranty still not expire,i think they can fix for you..Feel free to ask for their support:)
Posted on Sep 17, 2008
  • bombamy Sep 17, 2008
    mostly we operate PPC 2002 sytem by using touch screen,it is hard to say there is other way to operate by using other key..the IC is quite sensitve compare to other components of pocket PC ..as i said,most probably your ic is alraedy damage..even if you can jump to the dekstop,i don't think you can use it..but if you intend open,you may refer to the manual of E330, i think they write inside..the key to the dekstop..good to fix your phone:)
Rockchip tablet android 10.1 inch manul in English
Featurewise this is pretty much the same as the 7" Rockchip tablet we sell (not the HDMI version) but has a lovely 1080 x 600 10.1" screen, making watching films and youtube that little bit better. Sure you pay more but nothing comes for free I'm afraid.
1) CPU: Telechips 8902 720mhz/1GHZ
2) OS: Google Android 1.5
3) Memory RAM: DDR2 128MB
4) Memory ROM (flash): MLC NAND 2GB
5) Built in MIC
6) Memory Solt: TF Card, Max 16GB Nand Flash
7) LCD Screen: 10.1 inch TFT (1024x600)16:9
8) Touch: Resistive touch panel
9) USB Slot: 30PIN, USB2.0 Max Speed 480Mbps/s
10) Audio slot: 3.5mm
11) DC in: One charging slot
12) Sound effect: Audio build-in 0.5w*1 stereo sparkers
13) Charging battery: 5000 mAH / 3.7V (Li-On rechargeable)
14) Power Adaptor: 220V Input, 5V DC Output, 2A
15) WIFI: CSR / MARVELL WIFI B/G/N 802.11 b/g
16) Support G-Sensor
17) Button: Power key; Front Face:Home button; Side face:Power, Volume buttons +/-, Reset Key
18) Video Format: MPEG1,MPEG2,WMV9, MPEG4-SP,ASF,DIVX,H.263,H.264,RMVB,MOV 1080P
19) Audio Format: WMA,MP3,WAV,OOG,AAC,EAAC
20) Picture Format: JPG,GIF,BMP,PNG
21) Language: English /Chinese /French /Spanish /Portuguese /Italian /German /Indonesian /Vietnamese /Poland /Turkic /Russian/ Thailand/Arabic /Greek/ Malay/Swedish
22) Dimension: 260×118×16.6 mm
23) Net Weight: 885g
Colors Available: Sliver
Type of Packing: Color Box or
visit this link
http://www.rock-chips.com/index.php?do=prod&pid=2 i hope it is helpful to you thanks
Jun 29, 2011 | Cell Phones
How to align screen e755 pocket pc
To align your screen
select Settings, System, Align Screen to ajust the touch screen,
If the screen alignment loses calibration it may not be possible to adjust alignment useing the above method.
In that case the align screen command can be executed by simultaneously pressing the power button and scroll button.
useing the stylus when comanded touch the cross hairs and the Pocket PC will align the screen
Feb 24, 2011 | Toshiba e755 Pocket PC
Alignment of Tocuh Screen Panle of Canon Copier IR-6000/6001
I believe under the aditional funcation screen, you can calibrate the touch screen. Is the screen working at all? Does it look like there is Water on it and you can not wipe it OFF. If so, the display screen is cracked and needs to be replaced.
Apr 02, 2009 | Canon imageRUNNER 6000 Copier
Do you know how to jump the PPC Align Screen Test?
you have important thing inside?If still cannot open..try to connect it trough the usb to the computer..i guess it may open since there is other port:)
Sep 17, 2008 | Toshiba e330 Pocket PC
PLEASE HELP ERROR CODE
The machine's hard drive has died. you will need to get a Canon technician out to replace it for you and to re-install the machine's system software. In addition to this you will also need to reconfigure some of the machines settings such as the address book, as this is usually lost when the hard drive is formatted or replaced.
May 07, 2008 | Canon imageRUNNER C3220 Color Copier
Alignment of screen
at the time of alignemnet tap the + mark at place where it exist. it appears 5 times on screen. centre and 2 on top and 2 on bottom
Mar 28, 2008 | HTC Touch P3450 Smartphone
Touch screen is not responding with the stylus
Try do a hard reset to your device to the deafult vendor definitions, then re-initilize the screen and this should help.
Nov 12, 2006 | Toshiba e330 Pocket PC
Initialize my Pocket PC
When you initialize your Pocket PC, the factory default values are reset to the status as when you originally purchased the Pocket PC e330 or e310. NOTE: When you initialise your Pocket PC, all data stored in the memory is deleted. Your Pocket PC's initially installed programs are not deleted. Before initialization your Pocket PC, remove all storage cards. To initialize your Pocket PC, please follow the steps: Turn off the power Press the power button while pressing and holding the reset switch with the stylus. Then release the power button When a screen appears, release the reset switch When initialization is completed, the Welcome screen appears. Set up the system according to the screen as in the case of startup procedure.
Sep 08, 2005 | Toshiba e330 Pocket PC
Toshiba e330 Pocket PC Logo
186 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
