Question about E-Machines eMachines Monitor E15T4
My monitor says no signal
My monitor worked fine whan i went to bed i got up and tried to turn it on the light turns blue and the screen will say no signal then it returns to standby mode.
  • tabitha0701 Sep 24, 2008
    I'm in the same boat, i went to turn on my computer and it powers up, then the E shows up, next thing you know, it displays "no signal"!!! and no matter how many times i did a hard turn off or unplugged it and reconnected it to, it didnt work. same display every time. What do i do?
A friend gave me this computer because he got another and was tired of messing with this one ... he says he turned it off one night and it would never boot back up , sso i had a new 160 gig hd which is the same that was in it and i installed it thinking this would be a quick fix......... i reformatted with xp pro which is what i had put on this machine a couple years earlier and it was fine....it reformatted just fine and now the monitor says no signal....so i hooked the monitor up to another machine and the monitor is fine ....im stumped , any help would be appreciated.....i even removed the hd and put it in another machine and it worked great even with the monitor... got any clues?????
Posted on Oct 01, 2008
    Scholar:
  • 97 Answers
You'll need to check the cable connections and the computer that it is attached to. The monitor may be going into standby mode because the computer went into Suspended/Hibernate mode. Try restarting the computer. If you're unable to do this, try a hard power off and then try to turn it back on.
Posted on Sep 17, 2008
Hi there. My monitor has been working fine up to yesterday. I have all connections plugged in and i turn on the monitor and then the ACER sign comes up and then it says No Signal. and then the blue light...
Your monitor is fine, the problem lies with your computer. Your monitor is not receiving the POST signal from your computer. I suggest you remove your computers graphics card and plug your monitor cable into onboard graphics, then power up and see if the monitor gets a signal. If it does then it means that your graphics card has stopped working. If you still don't get signal then I suggest you take your PC to your local computer shop and get a qualified technition to have a look at it just in case the motherboard is damaged. You can also try out your monitor on another system just to be sure.
Feb 12, 2011 | Acer X233H 23" Monitor
Blank Screen
Common problem in monitors are bad caps in the power supply, that is the first place to check, look for bad caps with bulging top/bottom, see example of failed VIEWSONIC monitors due to bad caps here (worst case will be bad lamps): http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can help you further.
Feb 06, 2010 | ViewSonic VG2230WM LCD Monitor
Viewsonic VG2230wm 22 Blank screen
Look for bad caps in the power supply first, see example of failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you furhter.
Feb 06, 2010 | Relisys RLT1720 17" LCD Monitor
Not able to turn it on. for no apparent reason the screen was black after setting overnight. The pilot light was on. tapped the space bar a couple of times thinking the computer would wake up and desk top...
I have the same monitor & just had same problem. Did you find a solution to your problem? This is the second time my monitor has done this. The first time I had problem i unplugged it and disconnected it from pc. Plugged it into power source and blue pilot light came on then went off. I did see the LG logo on screen before it shut down. After several times doing this and pressing the power switch repeatedly it seemed to reset and recognized it was not receiving a signal and indicated this. I then reconnected monitor to pc and all appeared to work fine for several days. Now I again have same problem after sitting over night.
Dec 02, 2009 | LG W2252TQ Monitor
Screen
Just turn the monitor off and on,,it should cure the problem,,also,,,tap the space bar on your laptop,,,,also,,you may want to change your settings on your laptop to prevent it going into sleep mode, or standby state,,which is what is causing this problem with your monitor.
Jan 19, 2009 | Hannspree HANNS-G 19" Widescreen Monitor
Hanns g JC199D will not turn on, comp is on, try to turn monitor
no signal indicates a couple things... i suspect your computer isn't even booting up. reboot the computer while tapping the F8 key.... you should see writing on the screen... boot to safe mode. after it sucessfully boots up... reboot again... should be fine.
Robert
also is that an add on video card ?
Dec 18, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
I hooked up my new acer p191w to my dell laptop 1525.HELP!
Not sure what the problem is, but I would suggest pressing the Fn+F5? There is a function key that toggles from dual screen, just the laptop screen or just the monitor. Hope that helps..
G'luck
Nov 11, 2008 | Acer Computers & Internet
Proton pltv 32 no signal
I have the same problem. It seems the tv is switching from composite1 to composite 2 source.
Jul 09, 2008 | Protron PLTV-32 Television
E-Machines eMachines Monitor E15T4 Logo
369 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
