Question about KitchenAid KUDS24SE Built-in Dishwasher
KUDS24SEB3 - can't start cycle properly
Our d/w has been working fine, up til today. Now, when I start a cycle, the progress LED lights up under 'CLEAN', and the dishwasher whirrs for a few (~ 5?) minutes.
No water seems to be entering it.
Any tips?
Thanks.
I just had the same problem. I finally pressed Rinse Only and it started to fill. Without canceling, I depressed Normal, and it seems to be going through the proper cycle now.
Posted on Nov 12, 2008
  • brin366 Jun 14, 2011
    Starting with Rinse only worked for my machine too - not sure yet if same process will be necessary every wash. THANKQ!!!!!
I have a MW512 5.5 kg top loader, I started a load just a moment ago and after a couple of seconds a repititious beeping sound occurred and a couple of lights flashed at the same time and now I can't...
Ok starting from the spin led light as being number 1 each led light that goes backwards through the wash progress led light indicator is doubled in value i.e. 1,2,4,8,16,32,64,128 and 128 being the longwash led light indicator. Add the value of the lights together that are coming up when it is beeping and that will give a single number that is a fault code and will then be able to tell you what is wrong with it then.
Sep 21, 2011 | Fisher and Paykel Washing Machines
When I start my LG WM2101HW washer, the spin light
sounds like a clitch under warrenty would call them out so you dont void warwrnty
Dec 06, 2009 | Washing Machines
LEQ2152ES 2005 dryer shuts off when start us pushed
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 14, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Clean light flashing 7 times. Can't start the machine
The cleam light blinking means that the unit was not able to reach a proper heated wash cycle. Either your heating element failed orthe actual sump/pump motor system has failed. Check the element in the botton and see if it looks broken anywhere. If you can see a broken spot, you will k now that is the trouble.
Good Luck!
Oct 20, 2008 | KitchenAid 24 in. KUDS02FRSS Stainless...
Stuck in Progressive Scan Mode...please help!
There should be a switch on the DVD player that is makred 'progressive/interlaced.' You need to flick this switch til it says interlaced, as obviously your TV cannot view progressive signals. It may be on the back of the player, or under a flap on the front.
Feb 04, 2008 | Televison & Video
Wash cycle not working...
Kerbri, it sounds like your pressure switch could be the culprit. Under the top console the switch will be on the left side. There will be a clear tube that runs from the tub to the switch. Take another piece of tubing about the same size in diameter, disconnect the tube to the pressure switch and connect the tube. Blow into the pressure switch and see if the washer starts agitating. If so, replace the pressure switch.. Another thing to check would be the harness to the motor, make sure it is on tight. Good luck
Jun 26, 2006 | Kenmore 23022 Top Load Washer
Dishwashers Logo
221 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
