Question about Kenmore 54701 Dehumidifier
Dehumdifier won't drain
Bought my mother (who lives in another state) 35 quart 54701 model and hooked up so it would drain with a hose into shower stall. Her basement flooded where she lost manual. She needs dehumidifier to dry out basement. It apparently runs but won't drain in hose (have to empty manually)- I'm trying to figure out what the problem is 'remotely' from another state. Please help. Thanks. Rich
You just need to get the water flowing and start the siphoning process by taking out the water bucket while it's full of water and raising it up high enough to start the water flowing. Once the water starts flowing, you can put the bucket back and the water will keep flowing (by capillary action). If the bucket empties completely, you may have to do it again periodically to get the water flowing again.
Posted on May 17, 2009
I have an Energy Star 54701. Turned on, 35 % humidity set, hose connected and ready to drain in sump hole, bucket connected. set for 6 hours. No water is draining from hose or into bucket????
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 02, 2011 | Soleus 30-Pint Dehumidifier
Turned on for 6 hours bucket in - hose connected - set for 35 % humidity. No water draining from hose or into bucket?? Please assist.
heatman101
Sep 02, 2011 | Kenmore 54701 Dehumidifier
The 54701 Kenmore Dehumidifier runs and sounds normal, fan running, compressor on. However , it doesnt collect any water whether a hose is connected or just the bucket. No icing up or any weird noise...
Yes, if the compressor needs to be recharged, a service technician can do it.
In the meantime, try lowering the humidity extraction level to 35%. You may have the extraction level set to high.
Hope this helped you. Thanks for choosing FixYa.
Aug 21, 2011 | Kenmore 54701 Dehumidifier
Need to connect the drain hose connected, how I do it?
Hi, I'm attaching an image where you will find all the instructions for attaching the hose. Please reply if it helps. Good luck! Ash3fabec3.jpg
Jul 25, 2010 | Kenmore 54701 Dehumidifier
Water leaks out of the bottom of the humidifier and the bucket does not fill up. The water just leaks out.
Based upon my experience with the same problem on my Kenmore 54701 last summer: The condensate water collects in a plastic pan below the coils. This pan has a single drain hole where the water flows down into the bucket. When I suddenly found water puddling on the floor instead of in the bucket, I opened up the unit, and I found that the collection pan's drain hole had become blocked by "bioslime". I cleaned out the goo from the drain hole, and the problem was solved.
Apr 22, 2010 | Kenmore 54701 Dehumidifier
Tank fills up but connected to hose FDL70S1
I had the same problem. It seems that you need to add another hose washer to the drain hose that connects to the dehumdifier. I wasn't able to tighten it enough by hand to keep it from leaking. BE CAREFUL ! ! The plastic connector in the dehumdifier is just that PLASTIC so don't try to overtighten with a pliers, etc... I still get a minimal amount of water in the bucket but only have to dump every 4-6 weeks, if even that.
Jul 24, 2009 | Frigidaire Dehumidifiers
Uggg, mine did not come with the drain hose. Any ideas?
I have the same model and bought a clear plastic hose at Home Depot, and drain it into a nearby bathtub. I don't have the size handy but just measure the diameter of the hose fitting, and make sure the hose has an inside diameter to match. Some stores sell hose by the foot; I bought a prepackaged roll.
Jun 26, 2008 | Maytag M7DH65B2A Dehumidifier
Goldstar Dehumdifier - draining through hose not working
Check the connection where you attached the hose. It may be plugged or covered by a plastic film from when it was molded.
Jun 09, 2008 | Goldstar DH304 Dehumidifier
Kenmore 54701 (70 pint) dehumidifier stopped running
the lowest setting for % of humidity is 35% on that unit... sounds like with all the other errors that the IC board is bad (the Control circuit board behind the displays)
Nov 25, 2007 | Kenmore 54701 Dehumidifier
Connecting a drain hose
Most units have a drain connection, either on the machine itself, or in the collection pail. These connections usually fit standard garden hoses.
Jul 05, 2007 | Maytag M3DH30B2A Dehumidifier
Kenmore 54701 Dehumidifier Logo
625 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
