Question about Asrock P4i65GV Motherboard
Mothrnoard hi,i have a problem when i on my power the cpu fan is running but motherboard light is off and not boot.plss help me ..is my mboard dead?? pls help me..and give some solution ...
  • bhattacharje Sep 17, 2008
    but the fan is running...pls help
  • 6,487 Answers
First thing to check here is the connection make sure everything is still properly connected, if after checking it and still no light it only means the motherboard is dead and already needs a replacement, because if the power supply is bad the fan shouldn't spin if its the problem...
Hope that helps...............
Posted on Sep 17, 2008
  • Mark Gil
    Mark Gil Sep 17, 2008
    Yes the fan is running because of the power that is coming from the power supply , so it only means the power supply is good and the motherboard is the one that needs a replacement, that also hapen to me and I change the power supply just to know the board is really the one bad....
Computer won't do anything, keyboard does not light up, screen is blank
So there is not so much as a BIOS message on screen? Any beeps?
If there is no life at all, you have a CPU/motherboard failure. This may be direct or indirect (e.g. no power to MoBo). Check your connections.
Otherwise, your boot device may not be operating. This is usually a dead or disconnected HDD. Check that it is plugged in. Does it get warm? Can you feel any vibrations from it? It should spin even if your cpu is dead but MoBo is alive.
Oct 26, 2012 | HP Compaq Presario SR2038X PC Desktop
Continuous beep and the systems is not coming up {boot}
Hardware problem:
* dead RAM
* dead video-card
* RAM not fully "seated" in its slot(s)
* video-card not fully "seated"
* dead fan on top of the CPU/heatsink.
* failing power-supply.
Jul 12, 2011 | HP Compaq dc5100 Small Form Factor PC...
HP P4SD, its running good with 4 gb RAM, P4 3.0ghz, and a couple sata hd. The problem is the fan output voltage, i havent been able to read the output chassis and cpu cooler pins voltage cause i can find...
"i can find my dmm?" did you mean CAN'T?
"its clearly off", what is off?
the fans are 3 pins,2 are power, one is RPM tachometer.
"it all works fine", so you can boot and run any OS, ?
"the voltage reads +12vdc", where, at fan or PSU?
the fans run off 12vdc, they are DC motors (from outside fan)
if the fan runs slow at 12vdc the the fan is bad or is a low RPM
fan, as some are, bigger fans run slow, for less noise.!
first is the CPU fan it must run full speed, if not the CPU will overheat in seconds and ALL CPU shut them selves (by there selves) this way. so CPU fan is first. what does it do... there....?
then BIOS screens. GOT BIOS UP? and running? with, ESC key pressed>.
let me guess your symptoms
1: PC dead. will not boot.
2: BIOS dead.
3: all fans DEAD,.
4: power switch works and all PSU voltages read right, (seems not)/?
5: if the PSU power wire reads right(DMM), matching the side sticker voltages, and the CPU is dead, the MOBO is dead, or CPU is toasted.
here is a modern PSU, sticker.
see 5 to 10 power lines, see them. all must read correctly
if a fan is dead, then its dead if 12vdc is present on the fan power pins.
Apr 28, 2017 | HP Asus Motherboard P4SD-LA Socket 478...
No beep,no boot
make sure you seated the 24pin power supply and the 2nd power supply firmlly if not replace your power supplyif still dont work your MBoard is damage
Sep 22, 2009 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Power to everything but CPU fan and case fan - won't boot
Hi this is tech crazy
The solution to the problem is as follows
The main reason for CPU fan overworking or not working is due to the load we put on the syatem while operating.So,the first reason for fan not working may be due to the SMPS malfunctionality.Better check out for it.The reason if fan is working but Overworking is due to viruses is system.So go in for format
Hope this solution helps you
Please do rate me on the above said solution
Feb 04, 2009 | Intel Motherboard
Not booting but RAM,processor,SMPS ,HD are fine.
Check without Video Card, Processor , Memory and beeps are coming
If no then this is motherboar issue, I had the similar problem. So went to the local repair shop and got the power capacitors replaced,
Jan 29, 2009 | Asrock P4i65GV Motherboard
Motherboard
There is no way to test the motherboard without connecting to cpu. You can't test the motherboard until and unless you connect it to the pc. If you want to test the display, audio, graphics you have to connect each device and see. Every motherboard has got a green color light in it. When the power is on the light will glow. Thank you.....
Sep 17, 2008 | Asrock P4i65GV Motherboard
Pc is dead
is the power switch wire hooked up in the right place
Jun 03, 2008 | Intel Desktop Board D850GB Motherboard
Asrock P4i65G Motherboard
If the CPU is dead the problems can be
  1. no power
  2. no fans etc or
  3. power, no beeps (errors)
If the Ram is not compatible it would be constant beeping.
With the board in, and power supply 20pin + 4pin Pent 4 power attached,(#2 and #7 of motherboard layout) remove power cord from power supply.
CLRCMOS0 allows you to clear the data in CMOS. The data in CMOS includes
system setup information such as system password, date, time, and system
setup parameters. To clear and reset the system parameters to default setup,
please turn off the computer and unplug the power cord from the power
supply. After waiting for 15 seconds, use a jumper cap to short 2 pins on
CLRCMOS0 for 5 seconds. Remove the jumper. Remove heatsink and fan from CPU. disconnect cpu and reseat it. Re-install heatsink and fan. Plug in the power cord. Try to boot up. If it still does not boot and (no power, no fans etc.) problem would then be cpu is fried.
Jun 02, 2008 | Computers & Internet
No monitor output, no booting screen appears, no sound in the motherboard
Try your processor to the other computer that is working with the same CPU socket to prove that is working. If the processor work to the other computer it slightly proved that the mboard is dead, but sometimes processor hang-up on the mboard try to install back processor to suspected MB, there is a 20% guarantee solving the problems.Otherwise if the processor not working on the other computer something wrong with your processors. may this help.
Dec 10, 2007 | EliteGroup ECS P4M800-M Socket...
Asrock P4i65GV Motherboard Logo
74 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
