Question about Pioneer Audio Players & Recorders
Pioneer SG-530 making audio crackling sounds when equalizer turned on.
2 Suggested Answers
  • 979 Answers
SOURCE: Pioneer SG-9500 Equalizer Power Led Replacement?
A generic LED will work just fine. Be sure to match polarity...accordianman
Posted on Mar 09, 2008
  • 5 Answers
SOURCE: I have a Pioneer SG-540
I use the sg 540 equalizer for cd and tuner. (I have two of them) I also use the sa 940 to power my sound. On the tuner input of the amp, i used standerd rca cables and connected it to the output of the equalizer. then i connected rca cables from the input of the equalizer to the output of the tuner. this only works when the top equalizer button is pushed on. hope it works for you.
Posted on Jul 21, 2009
Im having trouble hooking up my equalizer to my Pioneer audio/video multichannel receiver vsx-814
Looking at the back..bottom right corner is CDR/Tape in and out. Connect the in on the eq to the out of CDR/tape, connect the out of the eq to the in of CDR/tape.
You should then be able to use the CDR/tape monitor button to switch the equalizer in and out.
Sep 25, 2014 | Pioneer Audio Players & Recorders
How do you connect a home pioneer graphic equalizer sg-9 to a sansaui r-7 receiver?
Use the tape monitor loop. Connect from the TAPE REC output on the receiver to the INPUT on the equalizer and from the OUTPUT on the equalizer to the PLAYBACK input on the receiver. YOU can then switch the equalizer in and out using the TAPE MON switch. I think the Model Seven had two tape loops, so just keep everything on the same loop.
Aug 03, 2014 | Audio Players & Recorders
Crackling and scratching
Your speaker may be blown take out the speaker that is hooked up and attach another one a house speaker would even work, and i bet your speakers are blow if not check the wires and make sure you have them connected properly if not check the wires going to the harness and to the speaker and if not i think the radio is fried you can also take a long speaker wire take radio out the dash and run it to the speaker if it does still the radio is fried take it back before 90 days is up!
May 29, 2013 | Pioneer Car Audio & Video
My speakers are all connected right and when i push the on button nothing turns on, no sound nothing, can you tell me whats wrong
as you said you connected it right. first plug it, second turn it on, third touch the input if theres a crackling sound, if theres not, audio ampli has defective.. a local thechician like me can fix the problem
Jun 19, 2010 | Logitech X-530 Computer Speakers
PROBLEM WITH THE AUDIO OUT CHANNEL
It sounds like you may have a bad cable. The most common place for a small gauge cable (such as RCA, TPS, XLR, etc) with metal connectors to fail is in the stain relief which often fails to live up to its name. An easy way to check this is to grab the cable near the connector and wiggle it. If the sound crackles and changes volume levels suddenly then you may want to try a replacement cable. If the replacement doesn't help, you should use a contact cleaner such as "Blue Shower 2" that is approved for electronics use. Make sure your mixer is switched off and disconnected from its power source before using any cleaners to avoid any risk of electric shock. Apply the cleaner to all exposed output connectors on the mixer. Hope this cleans up your output prolems
Jan 19, 2010 | Pioneer DJM-600 Silver Professional DJ...
Dell Inspiron 530 + Vista music sound popping crackle
check you speakers or try reinstalling the sound drives
Dec 20, 2008 | Dell Inspiron 530 Desktop Computer
I have a Pioneer SG-540 stereo Graphic Equalizer that only works in the right channel, but more importantly puts out a large amount of excess humming moise and other unwanted sounds when the controls are...
Jul 18, 2008 | Audio Players & Recorders
Mar 09, 2008 | Audio Players & Recorders
Pioneer deh p7500mp
definitely a heat problem. There is a chip (or set of chips, perhaps audio output chips) that work fine when cool, but when they are hot they start to fail. Common problem with IC's. Heat is not a friend of these devices. Time to get it repaired or get a new one, depending on cost of course. Also, do you have an amp attached? Perhaps the amp is the device with the failing IC's.
Aug 09, 2006 | Pioneer DEH-P7500MP CD Player
260 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
