When i start my camera (Olympus Camedia C-450 Zoom) model
it shows card Setup, poweroff or format, when i select format and press ok, message came card error
In playback mode press >ok< select >mode menu< with the 4-arrow-pad, then select >card< then >card setup< then press the PLAY button below the arrow pad. Select >all erase< with the up/down buttons of the 4-arrow-pad and then press OK (the button beside the PLAY button). Confirm by selecting >yes< with the up/down button and press OK button again. It's also a good habit to get into, to format the card after deleting the images (you can also just format the card - that will also delete all photos). To format the card start as above (Mode menu; card; card setup; press PLAY). Select >format< with up/down buttons then press OK. Select >yes< and press OK.
You need to format a card in the camera to erase and optimize it for the camera. Go into the menu and scroll to "format" and follow the on-screen instructions.
At this point it sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the card and it can be used again. Make sure you download all images prior to formatting as once the card is cleared all data is lost.
The problem is that the largest xD card that your camera can support is an M or H 512mb card. The 1gb or 2gb cards are not compatible. The firmware in the camera cannot support memory storage with that capacity. The camera came out before those cards did and there no plans to upgrade the camera to allow those types of cards to be supported.
As far as the 128mb card is concerned if it gets a card error message try cleaning off the gold contacts on the back of the card and reinserting it to the camera. If it still gives an error it may be a problem with the internal card reader in the camera.
Sounds like you will need to format the internal memory of the camera. This will permanently erase all the data from the memory and then you will be able to use it again. To format the memory: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the memory can be used again.
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the picture error message and the cards can be used again.
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect error message and the card can be used again.
