I need to frequently clean the inside of my Acer 5610-4534 laptop...I have never disassembled one before; can you help me to get it open?
    Sergeant:
  • 300 Answers
Insert a small flathead screwdriver under the keyboard bezel and carefully lift it up. Continue releasing plastic latches and removing the keyboard bezel with your fingers
Be careful, on some models the bezel might be connected to the motherboard as it shown on the picture above. If you accidentally pulled the cable, connect it back. It is not necessary to disconnect the keyboard bezel from the motherboard in order to remove and replace the keyboard, just put it aside so you can access the keyboard screws.
Remove three (or more) screws from the top of the keyboard. Carefully lift up the keyboard from the laI need to frequently clean - 2e7bf96.jpgr />
The keyboard connects to the motherboard via a flat ribbon cable. Before you pull the cable from the connector, you&rI need to frequently clean - ad447a7.jpge to unlock the connector.
The image above illustrates how to unlock the keyboard connector. Carefully move the connector lock 2-3 millimeters up and after that pull the keyboard cable. To install the keyboard, follow the above mentioned steps in the reverse order.
FixYa !
Az.
Posted on Sep 17, 2008
My acer aspire notebook 7736Z-4412 won't turn on. I have tried taking out the battery and using the adapter but it still won't turn on?
yes boss pl remove ur battery n start only ac supply if ur laptop on or not if run ur battery defective or not run at ac ur laptop ac supply ac to dc converter circuit problem pl send my address solved n send u
May 26, 2014 | Acer Aspire One PC Notebook
Way to slow down the z5610 acer fan? it runs loud after 2 years.
http://computershopper.com/desktops/reviews/acer-aspire-z5610
A) Needs to be opened up. Needs to be cleaned out inside.
Two years? Bet it looks 'scary dirty' inside. After you have cleaned out the inside, donate the 'Gunk' to local mice. They can use it for a condo. (I would charge them rent)
B) Processor may need old Thermal Paste replaced. Clean top of Processor, and bottom of finned Heatsink, and PROPERLY apply fresh, new Thermal Paste.
Primer:
Air is used to cool the inside of that All-In-One desktop computer. The Processor and graphics chipset, are the two hardware components that give off the most heat.
The finned Heatsink, and Processor Fan, are the two cooling components for the Processor. When they get clogged with 'Gunk' over the years, the cooling capacity drops -> tremendously.
The Processor fan sensor, senses that the Processor is too hot, and speeds the Processor fan up. Also BIOS speeds the computer case fan/s up.
Could also be that the bearings for the fan/s are bad. Replacement fan, or fans are needed.
Acer Aspire Z5610 All-In-One disassembly,
http://www.youtube.com/watch?v=f7vpJTdmMAg
ONE THING HOWEVER Karl, to work on this All-In-One you need to wear an ESD wrist strap, and have it's alligator clip connected to a good ground source.
This is just like working on a LAPTOP computer, NOT a desktop.
Average example,
http://www.radioshack.com/product/index.jsp?productId=2103245
(And of course unplugged from power)
Need guidance in cleaning, and replacing the Thermal Paste, just post back in a Comment. I will guide you.
Regards,
joecoolvette
Oct 08, 2012 | Acer Aspire All-in-One Desktop PC - Silver...
My acer aspire 4930 laptop shut down frequently while working
Hi
Maybe you are using this laptop for a quit a long time now without cleaning? you need to clean the exhaust fan. As the thermal protection shuts down the system once the temperature reaches its limits. Cleaning the fan will solve the problem.
Aug 01, 2011 | Acer Aspire 4930-6862 Laptop
The power board has no power how do i open the unit and repair it
If you need to ask "how" to disassemble your laptop, I recommend that you STOP and instead take it to a qualified technician, for professional trouble-shooting and repair, because there are no "end-user-replacable" parts inside the laptop.
Jan 23, 2011 | Acer Computers & Internet
Unit is plugged in but not reading as plugged in. Cord works fine on a 2nd acer aspire 5532
The power jack inside the computer is open - maybe a loose solder connection inside. It will need to be disassembled to repair.
Dec 19, 2010 | Acer Computers & Internet
My acer aspire 5315 shuts off suddenly and won't restart till it wants to. I replaced the battery, no difference....what's wrong?
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced
Oct 22, 2010 | Acer Computers & Internet
To know how to disassemble my acer aspire one 532h-2588 net book, it keeps overheating and shutting down,so i wish to disassemble it to clean out all the dust in it. please help.
Here's the complete disassembling procedure...
http://erkinson.altervista.org/acer-aspire-one-532h-aggiornare-ramhdwifi-smontare-lcd/
google translate it
Jul 07, 2010 | Acer Computers & Internet
Rollerball on Wireless mouse keeps getting gummed up. Cleaning done frequently but need to open mouse to get inside cleaned ?
The Apple wireless mice aren't made to be disassembled, not even by techs. If you disassemble it to clean it, you must glue it back together.
The best way to clean the rollerball is to remove the batteries and roll the ball upside down on a cloth soaked in alcohol. Be sure to roll the ball alternately depressed and not depressed for the best cleaning, and roll it in all directions.
When this no longer works, you can either attempt to clean the ball yourself at your own risk, or purchase a new mouse.
Nov 25, 2009 | Apple Computers & Internet
Need to remove and cleankeyboard
Your keyboard may need cleaning, but disassembling a notebook or laptop may cause you more problems when you try to put it back together. Without the proper training on that specific model, I'd advise against it.
There is a protective membrane on the keypad to keep dust and moisture out of the interior.
If it under warranty, opening it up will void it.
If its malfunctioning, an external k/b is an alternative.
But, disassembling it up is a can of worms you don't want to open.
Best regards
Mike
Oct 03, 2009 | Acer Extensa 4620 Notebook
How do I get the back off My Acer 5620 laptop. The CPU fan does not seem to be spinning and it keeps shutting down. I've pulled about 30 screws out of it and the thing doesn't want to split.
hi im josh in cebu phils.may i help you? friend if the cpu fan stops spinning the air inside and the processor heats up easily thats why it will shut down.you need to replace the fan of the cpu to avoid further problems to occur. in removing the screw it will not be disassembled easily because it has a safety bracket lock.to make it open you need to look frot he weak spots and you split that side until it opens the whole unit. thats all good luck hope i helped you.
Feb 26, 2009 | Acer Aspire 5610 Notebook
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
