Question about Gemini Sound Products EQ-300 Home Equalizer
Gemini Sound Products EQ-3000 equalizer
I have a Gemini EQ-3000 equalizer and a onkyo tx8522 av reciever and a onkyo dual cassette deck and a mp3 player hooked up but I need the equalizer to work with the mp3 player I have it working with the dual cassette deck but thats it.I need the equalizer to work with both.
  • 682 Answers
Please connect as the following-----1-mp3 out-----to cd in in your receiver.
2-receiver rec out (tape put)----to equalizer in.
3-equalizer out----to tape in in receiver.
Posted on Sep 22, 2008
Need help hooking up a vsx-8400 reciever to onkyo eq-240 And a onkyo ta-rw303 cassette deck .thanks
Hello, please contact Onkyo/Pioneer product at 800-229-1687 option #3. Thank you, Onkyo USA
Apr 16, 2017 | Onkyo Audio Players & Recorders
On a kenwood KR597 reciever, where do i hook up my KE597 graphics equalizer. Also must i remove my DP-R797 cd player to hook up my Maeantz PMD520 Cassette deck? Finally divorced
If you only have one set of tape in/out connectors, then hooking up two tape decks and an equalizer is going to be difficult. You could hook the "tape out" to one tape deck, that tape's output to the second tape, and the second tape's out to the equalizer, connecting the output of the eq back to your receiver....
Nov 01, 2014 | Audio Players & Recorders
I need to know how I can hook up my Teac EQA 5 equalizer to my Sansui AUD 9 power amp.. I lost the manual to the E/Q
It is very easy, you don't need a manual for this. The EQ line in and Line out get hooked into the record out and Tape in of one of the tape loops on the Sansui amp. Record outs go to EQ in and the EQ out goes to tape play.
Oct 10, 2013 | Sony TC WE435 Stereo Dual Cassette Deck...
Ok I have an Onkyo HTS8409 Network A / V Home Theater System - 7.1 Channel, and dvd player and want to know how to connect a equalizer technics sh-GE70 but i dont have a cassete deck
Equalizer is connected in between the deck and the reciever. Deck into the input of the equalizer, and the out of the equalizer goes into the tape input on the reciever.
Sep 26, 2013 | JVC TD-W118 Single Cassette Deck
Hookup soney duel tape deck to onkyo equalizer
If you are trying to equalize the sound from one half to the other ... you cannot, unless there are separate INPUT and OUTPUT jacks on the back. Otherwise you will need a second cassette deck.
Sep 23, 2012 | Sony TC WE435 Stereo Dual Cassette Deck...
Hookin equalizer to tape deck and recever
The equalizer I have seen have Line in, line out, tape in, tape out and that is how you utilize a unit like this. The line IN goes to the receivers tape record out. The line out goes to the receivers Tape play in or monitor, The tape deck hooks to the equalizer. The record or input of the tape deck hooks to the EQ record out, the Tape decks output hooks to the EQ's Tape in connectors. All these are stereo so there are left and right sides which you need to keep consistent. Red on a cable means Right, the white or black on cables mean Left or the top RCA connector on most equipment.
When playing back a tape the tape monitor is turned on with the receiver and left on. The way you record on tape from any source of the receiver is to select that source and it should go to the equalizer. Then the deck should record that source. To play a tape of the deck hooked to the equalizer then just press the tape monitor button on the EQ otherwise the Equalizer will just act as a loop and equalize any signal source that is coming from the receiver and the tape monitor on the receiver should stay on most of the time. Some equalizers have two tape inputs so you would hook another deck to that input and the owners manual of the equalizer should say how to select buttons to transfer tape signals from one to the other. If you master the concept of inputs and output of audio equipment then this hookup becomes another easy thing to do.
Sep 22, 2012 | Sony TC WE435 Stereo Dual Cassette Deck...
I have a Crest Audio V900, a set of Bose 901, a Gemini EQ-3000. Do I need a PREAMP? Or can I hook up the Crest AMP to the Equalizer?
You could use the EQ but it won;t sound as good as it will with a pre amp and also could make it a bit trickier when adjusting the volume and getting it to sound right.
Mar 10, 2012 | Crest Audio Audio Players & Recorders
I have been using 901 speakers and eq with onkyo tx-8522 av. but now when i turn on tape 2 monitor on, the sound become very weak, even i turn the volume to the max. when i turn off tape 2, the sound come...
Qualifier: I have 901's in a 7.1 setup and have written many posts on Fixya regarding how to do it right.
NEVER USE MAXIMUM VOLUME FOR ANY PURPOSE UNLESS THE RISK OF ACCIDENTAL SPEAKER DESTRUCTION IS A ACCEPTABLE.
ONLY now it does that? "VERY WEAK" as in attentuated somewhat or is it signal leakage, effectively silence? How is the EQ wired in? Check its own Tape Monitor button.
If you DO NOT have a separate amplifier for the 901's the EQ will affect EVERY speaker and we know that is NOT desired.
If the EQ is in a Tape Loop of a modern AVR and you activate the loop two things will happen: 1) the 901's will sound better and the rest of the speakers will be at risk from excessive amplitude at the extremes; 2) any digital source will be disabled.
Jul 10, 2011 | Bose 901 VI Main / Stereo Speaker
How to hook up equalizer to the amplifier
always remember source, amp, then speakers. ex: cd to eq to amp to speakers and it goes: out from cd player into eq, out from eq into amp, out from amp into speakers . hope this makes it easier for you.
Jun 23, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
Gemini Sound Products EQ-300 Home Equalizer Logo
348 people viewed this question
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Don Hart
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
