Question about LG Televison & Video
When i first try to turn on my LG flat screen it turns itself of immediately. It then switches itself on and off in rapid succession in a kind of continous loop.
  • LG Master
  • 5,138 Answers
Unless you do TV repair take to repair shop.I would first look for defective capacitors on boards and like so many others poor solder connection can cause alot of problems.
Posted on Sep 17, 2008
Hello My 60PK550 TV started to turn itself of every 5-10 minutes, I switched it of at the power point and waited, now when it is plugged in and turned on at the power point it immediately tries to turn...
check first the psu unplugging the Y-sus from it if the voltages stay on then you have a Y-sus failure if the psu keeps closing then its most likely the psu itself or your main board
Aug 16, 2014 | LG 60PK550 TV
Samsung 46 inch keeps turning on and off immediately by itself
Most likely the power supply capacitors. you can identify them by their bulging tops.
Jul 22, 2014 | Samsung LE Televison & Video
LG plasma turns off and on by itself while making clicking sounds
Probably the power supply is failing. The clicking sound means the power supply is trying to turn on but can't.
Dec 19, 2013 | LG 60PC1D 60 in. Plasma Television
LG TV KEEPS TURNING OFF
Kindly do not keep attempting to turn it on, as you are likely to spoil some other boards/parts/components of the TV. Look for any loose contacts in power out let, RC jack, cable and socket. In order to ensure, it is not caused by the input device, connect a DVD player
and see. Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 21, 2012 | LG 50PC1DR 50 in. Plasma HDTV
How do i reset the projection lamp timer?
Hello
Press the "Power" button on the TV remote to turn the TV on. Press the "Display" key. Press "5," followed by the "Vol+" key, followed by the "Power" button. Wait for the service menu screen to appear on the screen. This could take anywhere from a couple of seconds up to a minute or two.
Press the "Jump" key three times in rapid succession. Press "2" nine times in rapid succession
Press "3" once, followed by the "Mute" key, followed by the "Enter" key. Wait as the screen flashes momentarily.
Press the "Power" button on the TV to exit the "Service menu" and turn the TV off.
Mar 15, 2011 | Televison & Video
The tv immediately turns itself off after i try turning it on. it doesnt matter if i use the remote or turn the tv on manually. It just makes the noise as if its turning on and then immediately switches...
Hi, The TV is shutting down because there is an internal fault, there is more likely a panel that needs replacing or a few faulty components.
It's more than likely repairable.
If it's under warranty contact your dealer for repair or replacement.
Feb 10, 2011 | LG 60PS60 60 in. Plasma HDTV
When I turn the tv on, the green power light comes on and then immediately turns off, (light goes red). No image or anything comes up on the screen. Never had any problems before this. Checked all plugins....
Use the remote to switch problem,if it's not works,I am sure the power board problem
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Jul 06, 2017 | LG MU-42PM11 47 in. EDTV-Ready Plasma...
Tv shuts off immediately after turning on
Does it shut off shut off, or is there audio present after the lamps shut off? When you shine a light to the screen do you still see picture kind of?
If still see picture, it's inverter/power supply or CCFL bulbs itself. If no picture, completely off, it's DEFINITELY the inverter/power supply.
Sep 30, 2008 | Televison & Video
Televison & Video Logo
Computer Repairing
Computer Repairing
