Question about GE Washing Machines
GE Model GBVH5140H1WW
Washer is about 10 months old, used daily. No problems until the other day, during a wash, the main water pump for the house blew its breaker and of course we lost water pressure. Had to restart the washer. Since then, the washer will stop during rince cycle, and also noticed it does not agitate during rinse. It fills with water, completes wash cycle, drains, spins, then goes into rinse cycle, fills with water, then without agitating, the drain motor kicks in, runs for a while, then the washer shuts down, door lock off, start button flashing. Will not restart on its own, even when left for hours. If you press start, it will continue. Sometimes, clothes not as dry as they should be. Cleaned drain pump filter, it had nothing in it anyhow, which I thought was odd after 10 months. Tried removing power from washer for a few minutes, to possibly re-set any electronics that may be scrambled, still the same problem. Any ideas? Suspect brains are scrambled...I know mine are...
5 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Posted on Mar 13, 2008
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it.  Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
Posted on Jun 02, 2008
SOURCE: Kenmore 80 series washer model #11092587210
My washer won't work after we moved it into a new house, and I found a fuse in the floor beside it but couldnt find anywhere it would go. Is the fuse from the washer?
Posted on Nov 02, 2008
SOURCE: doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Posted on Jul 30, 2009
SOURCE: My GE front loading washer Model WCVH6260 does not
This has happened to us also. Our machine is 27 months old. I just had a non-GE repairman out and he showed me the mutilated belt. I was wrapped around the pulley. He said that the pulley had to be out of wack in order for this to happen because the belt looked in great condition (besides being in 3 pieces). Then the metal wheel (don't know the official name) is now warped and had gouged 3 grooves into the cheap plastic outer tub. So badly that it went thru to where the water is. So NOW, I have a big piece of scrap metal in my basement. I need a new outer tub, pulley, belt and at least 2 hours of labor. So a bill of 4-500$. I think GE can take this hunk of metal! But of course, GE has to send out their service man to inspect it. So I have to pay another service fee. They need to scrap this model and possibly others. What a waste of a whole lot of money. NEVER again.
Posted on Oct 20, 2009
1+ year old GE wjre555ok2ww washer won't release the wash water during spinning. How can I fix that?
Small things get into the electric pump. I removed coins and shoestrings from the pump in the past. They are easy to take apart and clean up. Rarely do they fail.
I have a video and service manual for your Hydrowave Machine HERE
Mar 04, 2011 | GE WJRR4170BT
Hotpoint washing machine model vbxr1090b2ww leaking from bottom of unit
Here are some solutions.
Hope this helps you...Jim...Please leave a comment...Thanks!
LEAKS ALL THE TIME Is your GE washer leaking all the time, even when not in use? If so the problem is the fill hoses or the valve. Look behind the washer to see if water is coming from the hoses. If not, take the cover off to the control panel. Once off, you should see if the water valve and if there is leakage - it needs replacing (if it is leaking). This is the most popular water valve for GE top-loading washers made after 1995 and the part number is WH13X86 Order Here. show?id=6bjnatppuce&bids=92089.1&type=10. Note that some models have a water valve with more than two coils. In this case, you will need to order the valve by model number at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 Buy Fill Hoses Here. show?id=6bjnatppuce&bids=92089.1&type=10
LEAKS DURING FILL CYCLE Is your GE washer leaking during the fill cycle? If so the problem may be in the valve. Follow instructions above, only this time start the fill cycle before looking at the valve.
If your washer overflows with water during fill cycle your problem is the water level control or the water valve. If you must cut the water off from the house plumbing to stop the water then there is no need for testing, just replace the water valve. First, you need to turn on the washer. The washer should start to fill with water, now cut the washer off and on repeatedly (note to yourself whether the water turned off every time). If it does cut off every time you cut the washer off, then it's most likely in the water level control. If it keeps running after you cut the washer off then, the water valve is bad and needs replacing. (Note that the valve can stick intermittently so it still may be bad if it passed the test) Water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
If the water valve doesn't stick in the first test then you need to check the water level control. First, remove the front of washer (insert butter knife between the top and the front pushing on the clips) then look on the side of the tub and you should see a tube attached to a box. Remove the tube (make sure all the water is out of the tub) look in the tube to see if is stopped up. Often it will stop up near the end. If it is, you can clean it out with a toothpick. Once it's clean, reinstall it and your washer is fixed. If the tube is not stopped up reinstall the tube. Now set the water level control on the lowest setting and start filling the washer with water. If the water stops when the tub is approximately half full (this varies with every model) turn it up to the next level (you may have to reset it). Repeat until the tub is full. If at any the water level gets above the last row of holes in the tub, unplug the washer. If the water stops running when you unplug the washer, replace the water level control. If the water doesn't stop, turn the water off at the wall then replace water valve. Water level contorls and water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 . LEAKS DURING WASH Is your GE washer leaking during wash? If so the problem is the tub seal (seals around the transmission where it goes through the tub), drain hoses (including the tub to pump hose) or the pump. First take the front off the washer (insert butter knife between the top and the front, pushing on the clips) then start the fill cycle. Now start watching until you see a leak. If the leak is coming from the tub seal, the transmission needs to be replaced (note that changing the transmission is expensive and takes special tools, so you may consider replacing the washer). If the leak is coming from the drain hose or the pump you need to replace it. If you don't see it leak at all, your soap may be the problem. To check this fill the washer with water and the amount of soap you normally would use. Then start the washer and watch the tube coming from the left back of the tub (the overflow pipe). If soapsuds come out of the overflow pipe then try cutting down on your soap or switch to another brand. This may fix your problem. These parts can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
LEAKS DURING PUMP OUT Is your GE washer leaking during pump out? If so the first thing you should look at is the drainpipe (to your house plumbing). Fill the washer with water, and then turn it to spin and start it. Now while it's pumping, look at your drainpipe if water backs out (it may not back unless you have soap in the tub), then the problem is in your plumbing. If it doesn't, follow the same steps as above in "leaks during wash." Only this time watch for leaks during pump out as well.
Feb 13, 2011 | Hotpoint VBXR1090B Top Load Washer
Samsung Front load washer Model# WF209ANW/XAA Serial# W0BX54AS601558A Bought from Lowe.s only three months ago. Have been using about thirty days when problem started. Problem: NF code. I have to...
Had similar NF error code problem with Samsung WF209ANW/XAA model: removed top panel via 2 screws at back of washer. Found that black sensor tube to water level sensor had vibrated loose and so sensor was not sensing water level in tub. Reclipped tube to sensor - solved my problem....unfortunately I had already ordered and paid for a new water level sensor $26 - due to advice provided by Samsung Tech Phone Support. Would have been nice if they asked me to check the sensor tubing first..as part of the troubleshooting procedure...!!
Jan 31, 2011 | Samsung WF328AA Front Load Washer
GE Profile WPRE6100G Top Load Washer how do you bypass lid safety switch? Unit pumps but won't spin.
worst washer I ever owned how do you bypass water level so you can wash a comforter man I am so disappointed with this GE Profile energy saver if I can't move the water level up I'm going to put it out along the road a trash day and it's only 4 months old
Dec 19, 2010 | GE Profile WPRE6100G Top Load Washer
Will fill but not wash or spin
Does the motor run?  Does the water get pumped out at the end of wash cycle or during the rinse cycle or when you turn the dial by hand to the end of a cycle?  If the water gets pumped out then the motor is OK but the clutch is not working.  If the motor is not running then that is the problem.  If the water fills and then nothing happens (the dial does not turn by itself) the timer is bad.  If the timer is bad but you turn it by hand the other actions (wash, rinse, etc. should work indicating no problems with motor and clutch).
May 30, 2009 | GE WBSR3140DW Top Load Washer
Washer machine not draining water
The GE serviceman repaired my machine approximately 40 minutes. I paid $189 for the issue to be resolved in 5 minutes. This is no exaggeration.
The serviceman arrived at 2:50pm and finished at 2:55pm. It took another 5 minutes for me to write the check and he was gone.
My recommendation is...
- Purchase the GE service plan prior to calling GE to repair the service. A 1-Year service plan is $40 and 2-Year is $75. It costs $99 just for the serviceman to come to your house.
- Fix the issue yourself. Of course, this only applies if you are handy. I am handy and I tried to fix the problem myself. I just couldn't figure out the location of the access panel.
Solution...
The access panel is on the front. This can be removed in less than 20 seconds. The notches on the access panel is in line with the edging of the washing machine door. To remove, slide in a flat object like a flat-head screwdriver. Wiggle up and down on each side until door comes loose. Lift up door and set aside.
The water pump is on the lower right in the front of the washing machine. If your wash machine has any water in it, you want to use a shop vac to empty it out. The serviceman used a clamp to stop the water from running down. A little water still came out but he used my shop vac to get it up. It was less than a cup full and I had a 1/2 tub of water. Afterwards, he stuck his fingers in the water pump and pulled out the item that was blocking the pump.
Guess what was blocking the pump? The item was my two-month old daughter's sock. He recommends using a washing bag.
Remember this solution is for GE 315 model that is a top load washer. This will most likely work with similar models. I knew my water pump was still working because it hummed during the rinse and spin cycles.
Good luck and I hope this saves you $189 or any other fees.
Nov 21, 2008 | GE WBSR3140DW Top Load Washer
GE WJSR4160GOWW washing machine not working right
hi there,
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
* If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt.
To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it
doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn,
replace it--but be sure to check the pump pulley before you change the belt.
* If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin
and may not function at all. The switch is inside the washing machine main housing near the
door frame. Often you have to raise or open the top or front of the washing machine to get to the
switch. If it's defective, you need to replace it.
If your washer pumps out the water but doesn't spin, check these:
* The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside
the washing machine main housing near the door frame. Often you have to raise or open the top
or front of the washing machine to get to the switch. If it's defective, you need to replace it.
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small,
relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the
motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
* A belt may be broken. Many washing machines have one or two belts. If a belt is broken or
badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing
machine belts are designed with special characteristics not found in automotive belts.)
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper
spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the
clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance
repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor. For agitation
the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to
burn out in one direction and continue to operate in the other. If this happens, you need to replace
the entire motor.
* The transmission may not be shifting properly. Older washers produced by Whirlpool® have a
transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the
unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem,
you may want to hire a qualified appliance repair technician to repair it.
* The spin bearing or basket drive may be worn or seized. These components allow the inner tub
to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during
the spin cycle. Call a qualified appliance repair technician.
For safety, washing machines are made so that they spin only with the lid closed. The lid switch
prevents the spinning action when the lid is up.
* Is there hot water coming through the proper hose? If not, check to see if the screen inside the
water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the
fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so,
completely replace it.
Nov 09, 2008 | GE WBSR3140DW Top Load Washer
It won't drain...
From your description, you could have a problem with one of several things.. You can run a few tests to determine the most likely area that is causing your problem ,,, If possible, can you unhook your drain hose from the drain and use a barrel to cycle water into ? (You can stop the washer any time to empty the bucket... Anyway, try running a wash load ( without clothes) and monitor the water flow... when the washer is pumping water out, you should have a fairly high stream flowing into the bucket. Using a bucket will rule out a clog in your house drain line...and provide d irect means to see how well the system pumps.. If the water is only trickling out during the drain process, then you have one of sveral problems.. The pump is clogged or defective, the supply from the drum to the pump is clogged and not allowing the water to be drawn into the pump or the outflow tube from the pump is clogged or crimped. Any of these problems will require you or a service person to gain access to inside the washer and diagnose the problem. I had a similar problem on an LG front loader and it was the pump itself.. One thing to remember is to use HE detergent for these front loaders.. and a very small amount of that.. Hope that helps...
Aug 04, 2008 | GE Energy Star WCVH6260F Front Load Washer
Washing machine leaks when not in use
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Apr 29, 2008 | GE WWSR3090TWW
GE washer eill not drain or spin.
if the unit is at least 4 or 5 years old, most likely the pump is clogged with the same hair.....that clogs vacuums. you probably can fix it yourself provided you can get to the pump without too much trouble. i'm not familiar with all the brands designs. maybe someone else on this sight can help. if this is not the problem than most likely some of the timers points are burned. if the unit is more than 10 years old and/or the unit has been used unusually alot there is the possibility that the transmission has problems, but that is pretty unlikely. hope this helps.
Mar 05, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
147 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
