Question about MSI PM8M-V Motherboard
My pc restarts when i plug in usb
Its not a faulty cable and all 6 ports do it. have tried it on other pcs and it work. what can i do
    Filmmaker:
    Uploaded 5 video answers.
  • 95 Answers
Hi
It sounds like it could be a clash between two IO adressess. You'll have to check in Device manager to see if there is two or more devices that is trying to use the same address.
Posted on Sep 17, 2008
Dell Precision T1500 beeping 6 times and will not boot up.
Remove whatever USB cables in the front USB ports below the DVD. Then try starting it should work. If not remove USB from the rear one at a time. Once it restarts replace USB cables into ports.
Mar 11, 2013 | Dell Dimension 3100 PC Desktop
Tip
Using Zyxel P-600 from two PCs
to use Zyxel router/modem from two pcs for internet usage : it has two ports 1 is USB 2nd is Rj-45 connector LAN port
connect it with one pc via USB cable and connect 2nd via LAN port using Cross cable then its one DSL connection from two PCs.
i am using it and it working good.
on Apr 20, 2010 | Computers & Internet
I have been told the I need a "fire wire" port to transfer video on my Sony TRV460 camcorder to my pc. I was supplied with the ubs wire with the camera, why isn't it working?
USB and firewire cables are completely different and are not interchangeable. A firewire cable is rarely supplied with a camera and 99% of the time you have to buy one. They are available are most places that sell computer gear.
The camera will have a 4 pin socket and most PCs use a 6 pin socket. If your computer has a 6 pin socket you require a 4 to 6 pin firewire cable. Firewire is also called IEEE1394 or iLink.
Jun 29, 2011 | Sony Handycam DCR-TRV460 Digital Camcorder
I have a jvc gr-d33 and am trying to transfer mini dv to dvd through my laptop toshiba satellite l355. on my jvc i have the 4 pin dv and know it has to transfer through firewire but on my toshiba i dont...
I'm afraid that there is chatter on the forums that these Firewire to USB convertors don't work properly with video cameras. That doesn't mean you can't try it, of course.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. If you have a Windows desktop PC, you can fit an add-on Firewire interface card. This will come with a driver for the card. No help on a laptop unfortunately.
Nov 20, 2010 | JVC GR-D33US Mini DV Digital Camcorder
HI,I AM TRYING TO CHARGE MY BLUETREK MINI THROUGH THE LAPTOP WITH THE USB CABLE BUT SEEMS TO ME THAT THERE IS NO COMMUNICATION BETWEEN BOTH.ALSO I PRESS THE BUTTOM ON THE UNIT AND THE LIGHT BLUE AND RED...
unplug usb cable from your laptop
restart your laptop
plug USB cable in diffrent ports available
Still if its not charging then follow these steps :
1. Right click on My Computer
2. Click on properties
3. Click on HARDWARE tab
4. Click on Device Manager
5. Click on USB ROOT HUB
6. Uinstall USB ports one by one
7. Restart your laptop
Then try to charge your BlueTrek Mini
Apr 29, 2010 | Computers & Internet
I followed the instruction but can't seem to connect to the internet, do i need a separate modem or is the one in my regular computer enough. i have belkin G wireless router. i have tried everything....
If you are trying to connect wireless you will need a wireless card. Routers are very peticular about the way they are set up. Unhook everything turn everything off and reboot computer, and run the software disc that came with the router. Plug the dsl into the the Blue colored port or Wlan then reboot computer and then plug cable into computer. This should work.
Nov 21, 2009 | Belkin (F5D7633UK4A) Wireless Router
Sansa view is no longer recognized when plugged into USB port
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
Sep 07, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Hi, I have brand new Canon MP140 3 in 1. I am getting the error message &cannot communicate with scanner. Cable may be disconnected or scanner may be turned off. Check status. scanner driver will be...
1. If you are connected correctly (via a USB cable), first be certain that the cable is snug on both sides (PC and Canon MP140).
2. If still a problem, remove the Canon MP140 icon from Printers and Faxes.
3. Then, disconnect the USB cable.
4. Restart your PC and log into Windows.
5. Connect the USB cable.
6. The PC should recognize the Canon MP130 and ask for a driver.
7. Install the driver.
If #6 does not happen, your USB cable could be faulty or may be a problem with USB port or your Canon. Move USB cable to a different USB port on the PC. Replace the USB cable. Try to install the Canon on a different PC to test.
Hope this helps.
Aug 11, 2009 | Panda ANTIVIRUS ED PLT 7.0 1YR 26-50...
MSI PM8M-V Motherboard Logo
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
