Question about Dell 2.8 GHz Second Processor for PowerEdge 830 Server Pentium 4 (DF904) Processor Upgrade
Error i have power edge 830 intel P 4 suddenly a problem is created problem is that when the system boot after booting process a message is appear . " NTDETECT Failed " i am waiting and thanks for solution Abdul Razzaq Bahawalpur ,Pakistan
    Scholar:
  • 141 Answers
NTDETECT is the system boot file. Something has corrupted it. There is no way to boot the system if it can't read this file. If you have the windows disk, boot from that. The easiest thing to do if you have the disk is just to re-install windows. If you do an upgrade over top of itself, you will probably save your data. If you don't have a windows disk, get one.....
Posted on Sep 17, 2008
How do I return my msi wind u180 to factory settings
Use the recovery partition on your MSI laptop to recover its original factory settings. Recovering your MSI laptop to its original factory settings will resolve problems with instability that you may be experiencing as a result of missing system files that were accidentally deleted. Recovering your MSI laptop to its original factory settings will also completely remove any viruses on your computer's hard drive that you were unable to remove with anti-virus software. Fortunately, you can wipe all of the information off your laptop's hard drive and start with a clean slate.
Instructions
  • 1
Turn on or restart your laptop. Press "F3" repeatedly when the MSI logo appears on the screen during the boot process to be redirected to the "Windows Boot Manager."
  • 2
Highlight "Windows Setup [EMS Enabled]" using the arrow keys on the keyboard. Press "Enter" to access the recovery partition on the hard drive of the MSI laptop. The "System Recovery Option" dialog box will appear on the screen. Click "MSI Recovery Manager." Click "OK" when a message appears on the screen notifying you that your computer will be restored to its original factory settings.
  • 3
Click "OK" when a message appears notifying you that the hard drive will be formatted to begin the recovery process. A dialog box with a status bar will appear to indicate how much time is left in the recovery process. Depending on the size of your hard drive as well as how much personal data needs to be erased, the recovery process could take up to 45 minutes.
  • 4
Click "OK" when a dialog box appears on the screen indicating that the recovery process is complete. Your laptop will automatically restart and boot up to the Windows setup screen, where you can begin personalizing the settings for your Windows operating system.
How to Recover an MSI Laptop to Original Factory Settings eHow
Oct 09, 2014 | MSI Wind Top Ae1920 1800 Mhz Intel Atom...
Windows XP sp3 not booting Error system halted
Is your First Boot Device in BIOS is Set to Hard Drive? IF not then Just Change it Hard Drive.
Aug 11, 2012 | Intel Computers & Internet
Digitizer Pro Exception Access Violation Exception code c0000005, Exception flags 0, Exception address 01697E72, Number Parameters 2,Start up Address 004011A0, offset 01296CD2, Digitizer pro was running...
Turn on your PC in safe mode by Pressing F8 on the keyboard immediately the PC is turned on or at start up.
A booting option will come up, choose safe mode and press enter on your key board.
Wait a while for it to boot up. After booting perform system restore.
System restore helps to back date your system to the time when the Digitizer pro was working perfectly. YOu can back date the system to like 1 week ago.
Follow below procedures to perform the system restore;
  • Start => All Programs => Accessories => System Tools => and click the System Restore. System restore will run and here you should see the Welcome System Restore page appear. Click Restore my computer button to an early time if it's not already selected. Click next to continue the steps.
  • There is on your laptop screen a Restore Point page appear, you can select it and then click the most recent system checkpoint it, click a restore point list. After you click the Next button, System Restore message may appear that lists configuration changes that System Restore will create. Click OK.
Your computer will be restarted after the restore and that would be all.
Try the Digitizer pro again, after the system restore is complete.
Good luck.
Jan 17, 2011 | Computers & Internet
Locked Laptop
This is from a factory repair and maintenance manual for Acer Aspire Laptops. It may work for you.
Forgotten Hard Disk Password
When the user keys in the wrong password three times, an error message appears. The user must now reset
the password.
1. Make a note of the error code that is displayed with the error message.
2. Run unlock6.exe from the DOS prompt in the following format:
unlock6 XXXXX 00
(XXXXX = HDD password error code, 00 = CRC base - default is 00)
3. Select Upper case ACSII Code from the screen that appears. The HDD master password is displayed.
Make a note of this password.
4. Reset your system. When the Enter Primary Master HDD User Password prompt appears, enter the
password you made a note of in step 3.
Resetting a BIOS Password
The user can reset a BIOS password using the clnpwd.exe utiility.
1. Copy clnpwd.exe to a DOS boot up disk (or flash drive).
2. Boot your system in DOS mode.
3. Execute clnpwd.exe from the boot up disk (or flash drive).
4. Press 1 or 2 to reset the required password as shown on screen.
5. A confirmation message appears when the process is successful.
May 24, 2010 | Acer Aspire 5315-2713 Notebook
Will not boot,bios does not show a hard drive,only two CD drives
The peripheral devices as Hard disk and cdrom is not connected with the IDE cable or has loose contace. Even power cable of devices is not properly done or left out. So you need to check the IO IDE cable connetions and the power cable connections of the devices being connected to the mother board.
Mar 30, 2009 | Intel D865GBF Motherboard
I have an ei system 103a desktop i have had to sytem restore now when i turn pc on it tells me to press f1 to start windows i have tried going into the bios and boot from hardisk but still have the problem...
The 'Press F1 to continue" message is a result of an error caused as the BIOS does its hardware checks during the boot process.
The BIOS boot process (bootstrap) preceeds the loading of the operating system.
The most amusing example of this occurs if you unplug a ps2 keyboard,
1, it generates the error
2, pressing F1 does no good because the keyboard is not plugged in.
3, if its ps2, you will need to do a hardware reset after plugging the keyboard in again.
The bios can be set to 'halt on'
'no errors' which will stop the error message appearing.
'keyboard errors' see above
'all errors' any hardware failure detected by the bios will halt the boot process and give the above message.
Mar 11, 2009 | Computers & Internet
Compaq Presario Laptop ERROR CODES
it is a hard drive problem plz try with another hdd
Jun 02, 2008 | Compaq Presario Notebook
Boot error accures
THE BEST SOLUTION IS TO FORMAT IT AND REINSTALL THE OPERATING SYSTEM. IF YOU DON'T KNOW HOW TO DO SO, BETTER CONTACT YOUR SYSTEM VENDOR OR IT PROFESSIONAL.
May 20, 2008 | Compaq Presario 1275 Notebook
Problem software not support motherboard
when the message say that incorrest boot divice means the boot order is wrong so go to bios by pressing the key F1 or F2 or F10 or DELETE when the computer try to boot up then go to boot order and change the order for the first your hard drive save it and restart the computer but if there is no operative system you have to re install it that message say it can not find the operative system on the boot order devices
Dec 31, 2007 | Intel Motherboard
Dell 2.8 GHz Second Processor for PowerEdge 830 Server Pentium 4 (DF904) Processor Upgrade Logo
88 people viewed this question
Alun Cox
