Hello 1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked 2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked 3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
You can unlock the FPA lock of your RCA TV. But, you must ahve its original remote control to perform the proceedings. if you haven't it original remote cntrol with you now, just try to buy a new one, of just borrow it from any of your friends or relatives who owns the same model Tv.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
One amoung the above process will surely unlock your RCA TV. OK.
Press UP & DOWN buttons together on tv's
local control and then switch on. You will see
SERVICE MODE. Do not press any button,
just power off the set, then on.
·Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
· Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step
OK
