Question about Gateway Computers & Internet
My operating system has been restored and hard drive USB ports are no t operating
  • 1,226 Answers
If you have CD utility enclosed onto your computer then you to insert it to the cd room and then install the driver about usb or install all the drivers so that the system work to high performance.
try also to test the usb port maybe not functioning at all. its either damage port or loss connection.
may this help,
Posted on Sep 17, 2008
Installing Operating System on New Blank Hard Drive
Did you partition the hard drive ? Make sure that it is compatible .Some HP computers will only allow you to use certain products and you can not upgrade\downgrade or change an operating system .Try going online on another computer and see if the devices in your netbook can be changed or upgraded. HP is big for "Thank you for your business & your stuck with it the way it is " I wish you luck .
Feb 06, 2014 | Intel Hp Mini 1000/1035...
It want come up on my computer
Step 1:
Problems with Verbatim portable hard drives vary depending on your model of hard drive, your operating system and your computer hardware. Some problems can include insufficient USB power output, the file system format, and potential overheating due to enclosure materials.
File System b> Verbatim portable hard drives come formatted for use with Mac computers. If you're using it with a Windows or Linux computer, you will need to format it to a file system that your operating system will recognize; Windows computers typically work with NTFS, while modern Linux distributions use ext4. If you have computers with mutliple operating systems, FAT32 is usually considered easier for all operating systems to recognize. Verbatim does not recommend switching a portable drive between PC and Mac computers once you've formatted the drive one way or the other. Adequate Power While most computers supply adequate power with one USB port, older computers can have insufficient power output. If your computer doesn't seem to be powering the drive, use of a Y-shaped USB cable, designed to be plugged into two USB ports, can get more power to run the drive. Additionally, consider trying different USB ports on the same computer; some USB ports get more power than others. Drivers b> Make sure that you have any relevant drivers related to the hard drive that you have purchased. If your drive didn't come with a setup disc, you can check the Verbatim website for product drivers. Overheating b> Of Verbatim's seven portable hard drives, four are enclosed in plastic; of the other three, one is enclosed in aluminum, one in leather, and one in rubber. While all the drives are tested to run well with their enclosure, metal enclosures conduct heat away from the hard drive and help to prevent overheating. Plastic, on the other hand, is an insulator, so plastic enclosures may contribute to heat buildup. Check plastic-enclosed drives for overheating and avoid leaving them plugged in when not in use.
Apr 05, 2013 | Verbatim SmartDisk Firelite Portable USB...
Good day I am in need of drivers for an LG external HDD hxd7.Reason being my laptop will not recognise the hdd but sometimes it does.
You do not say which operating system you are using.
You do not say which type of computer this is (laptop or desktop).
Most operating systems do not need extra drivers to recognize a hard drive. The drivers are almost certainly already built into your operating system to operate almost any hard drive.
It could be a faulty USB port (try a different USB Port) or a faulty USB cable (try a different USB cable).
If the cable and port are not the problem, then either the hard drive itself or the hard drive enclosure are faulty (open the enclosure and test the hard drive in a hard drive dock or another (custom) external hard drive enclosure.
I hope this helps.
Aug 29, 2011 | Computers & Internet
My computer does not recognize my book 500. Is there any way to reset it?
Restore your computer to an older date (system tools / system restore). Try connecting your device into a DIFFERENT usb port after the process is complete.
Feb 06, 2011 | Western Digital 500GB My Book World...
I want to reset the settings on my hp mini to its factory settings.
Hello try to download the files on another computer running a Windows operating system and restore your
device, follow these steps:
1. From your computer, go to and download the
HP MIE Restore Image Creator utility and the HP Mini MIE recovery image.
2. Insert a USB flash drive into a USB port on the computer.
3. Launch the HP MIE Restore Image Creator utility from the Start menu.
4. Click the Browse button and select the HP Mini MIE recovery image.
– or –
Select HP Netbook Recovery Image to download the latest HP Mini MIE recovery image from
5. Click Start.
6. When the process is complete, remove the USB flash drive.
7. Insert the USB flash drive into a USB port on your HP MINI.
8. Change the boot order by turning on or restarting the device, and then pressing f9 while the “F9 =
Change Boot Device Order” message is displayed in the lower-left corner of the screen.
9. Use the arrow keys to select the USB flash drive, and then press enter.
10. Press enter again to begin restoring the device.
11. Follow the on-screen instructions to install the operating system and programs.
12. After the operating system and programs are installed, remove the USB flash drive(the device will automatically restart)
13. Restore your personal files and you are done
Good luck
Jan 20, 2010 | HP Computers & Internet
Hello, I am having trouble with my usb ports. It does not recognize anything that I plug into the usb ports. I did a system restore and it still does not recognize the usb ports. It only recognizes it if I...
reinstall your usb controllers and handlers off the factory system disk that came with your system..something corrupted the files somewhere ...system restore wont replace deleted system files only restore user settings when you put the disk in it will have a section to restore usb and reinstall then restart the system
Sep 28, 2009 | SimpleTech 500GB SimpleDrive Pro External...
I have windows Vista and just had a hard drive replaced. I tried the system restore but the computer is not reading the external hard drive files. Can anyone help?
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Aug 26, 2009 | Western Digital My Book Home Edition 500...
My portable hard drive was working . Then one day it would not reconize my hard drive anymore ? How do I fix this ?
Try to boot in bios and reset defaults.Connect drive in different usb ports and check. Check usb cables. Try to do system restore.
Aug 18, 2009 | Iomega CORP EGO PRTBL HD 160GB-HS USB 2.0...
USB 2.0 Host Controller on Windows 2000 Server (Emachine 5260)
raycrean, Windows 2000 service pack includes drivers for USB 2.0.
How do you know its not operating like 2.0?
Jan 19, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
35 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
