Samsung hc-p5252w 52
I saw some of your replies to folks needing help and hoped you could give me some input on my problem.  I was given a samsung HC-P5252W 52" rear projection TV. The folks that had it said it was 3 years old. They said it just quit and they went out and bought another. I took it home and opened it up. I plugged it in and it wouldn't come on, but I could hear something power up (the flyback?) with a high tension whine. I heard the speakers click, but nothing else. I left it on for a while and started smelling something. I noticed the convergence IC chips were getting hot, and looked like one was maybe starting to smoke a bit. This was all with the power off? Anyway, I checked the board with the IC chips and heatsinks and saw 4 resistors that looked like they were getting a little hot too. RZ125, 126, 127, and 128. I have no manual or schematic for this tv. I'm not an electronics repairman, but I have a small amount of basic experience with electronics. Does anyone here have any experience with this problem, or suggestions?  The website you usually show with service manuals dosen't list one for our model.  I was told to clip the ic's and see if it would power up, I did and it would not.  The nearest shop that works on rear projection tv's is in the next state.  Could you please help me out?
  • cvsumner Sep 18, 2008
    Thanks, we have one on the way.
  • cvsumner Sep 21, 2008
    The board came in, and the tv is working again.  Thanks for the help.  We noticed a little bag in there while we were in there,  the bag and lines were empty.  We ordered some coolant.  Can you tell us is there any procedure to refil it?
  • 8,617 Answers
What you need to do to solve the issue is to replace the pwr deflection board. You can get one at the following link under the samsung parts category. Its the P59A pwr def board.
http://servicemanuals.vstore.ca/
Posted on Sep 18, 2008
Problems with color on 2005 Samsung 52 inch HDTV
Quite normal in many situations as signal is compressed with most cable and satellite systems, a fact of life.
Nov 29, 2012 | Samsung HC-P5241W 52" Rear Projection...
My daughter pushed a button on the remote. now i can't get a picture. it's snowy. i have no idea what she pushed.
Hello there,
Push the input button on the remote control if you can not find it on the remote Control there should be a input button on the front of the TV .
also make sure everything if turned on
i hope this information was helpful don't forget to rate
Jan 27, 2011 | Samsung LN52A850 52 in. LCD HDTV
What part number oregon chain do i need for a cs-52 john deere saw. They keep sending me the wrong john deere chain witch is three links short. thanks Vern.
Hello Sam;
I cannot find anything by Deere (probably an efco 152) about your saw. Oregon does list some particulars here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
I input:
John Deere; CS52; *see below; All (0.325"); All (0.050"); All (yours is likely green - low kickback).
*16" - 66 drive links (the part that fits in the bar).
*18" - 72 drive links.
If your saw does not use either 66 or 72 drive links I suspect the bar, drive sprocket, or drive sprocket and bar nose in use are not what the the saw was originally supplied with. Any local chainsaw seller/mechanic given your chain as a pattern can fabricate one in about 5 minutes. Often a local chain is less expensive (no shipping).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
efcoPower.com
http://www.efcopower.com/indexPri.jsp
Sep 07, 2010 | John Deere 16" Chain Saw Chain (Oregon ...
Samsung Plasma 52 inch flatscreen vintage 2004 - black line
Hi my name is Roety,
I can help you with your issue ,
If the line is present on all inputs, and effects the TV menu you most likely need a new screen.
You can try changing buffers, reseating cables.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 09, 2009 | Samsung HPN5039 50 in. Plasma HDTV
The pictures is yellow.
hello it sound like convergance chip may be the problem get an engineer out as it's a big job to do yourself trust me i've done a few good luck
shaun
Aug 23, 2009 | Samsung HC-R5245W 52" HDTV
How do I determine my tv's configuration.
You can get configuration from the link below
http://www.mediacollege.com/equipment/samsung/tv/hc/hcn529w.html
Jan 30, 2009 | Samsung HCN529W 52" Rear Projection...
Samsung hc-r5245w no power
Hello Chac c,
The reason that you are getting a 'red light' is because your lamp is burned out. There is a panel on the back of the TV that gives you access to this lamp. You can remove it and check the part# to be sure then replace it. I did a quick search for you just based on the model# which you provided. You can see it here - http://www.nextag.com/serv/main/buyer/OutPDir.jsp?search=samsung+lamp&gg_site=&gg_aid=1295966762
Hope this helps :)
Mar 17, 2008 | Samsung HC-R5245W 52" HDTV
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
