Apex AT2702 27" color television under scan
My Apex AT2702 has under scan. Both vertial and horiz. sweeps are pulled in about 1/2 inch. Any componet change experienced in order to fix?
  • Midget Digit Sep 19, 2008
    No! Under scan has nothing to do with vertical hold.
    Scholar:
  • 163 Answers
Read page 15 of your manual about vertical sync functions.
Posted on Sep 18, 2008
  • 2,071 Answers
Try to reset first;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
    Genius:
  • 1,665 Answers
You can get into the service mode by entering the special code from the remote control. But, you must have the service manual in order to get that information.
Go to this web site:
http://www.worldwideelec.com/apex_asc_site/apex.html
Then download the service manual for the model marked APEX AT2702 & AT2702S. It is not exactly the same model, but the service mode will be the same as far as I know.
Then, go to page 48 of the manual and follow the instructions on entering. There is a table given for all the adjustments that can be made for the set.
Menu 04 will give you control of the vertical size and position, etc.
Hope this will guide you sufficiently to get it adjusted properly.
click also below for the manual:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
  • 4,472 Answers
Being that it is an apex tv those are basically "throw away tv's".They are made quite cheaply and offer no support/parts. Are you planning on repairing this yourself?
Thanks,
Lee
  • Lee A.
    Lee A. Sep 18, 2008
    If you have a moment to accept and rate my solution it would be greatly appreciated if you have any questions or need further assistance please let me know.
    Thanks,
    Lee
    Genius:
  • 1,847 Answers
Well most of the modern tv today doesnt have vertical hold anymore.
this symptom is caused by a trouble in the IC integrated circuit or the vertical oscillator circuit. let the service guy do the job if u dont know anything about this. good luck!
Is my apex tv AT2702 high def??
According to apex its not and does not have a digital tuner the only way this can be high def would be 720P meaning 720 lines progressive scan.
Your aspec Ratio is 4:3 this indeed is a standard TV without a digital tuner so you will need a digital setop box or a digital tuner.
High DEF is not considered digital its conidered how many lines are displayed on the TV. For example 720p, 1080p .
  • Silver, 27-inch monaural television; 29.6 x 23.2 x 18.7 inches (W x H x D)
  • Front-panel audio/video input accommodates a camcorder, VCR, or gaming console
  • 3 rear AV inputs (including 1 S-video input), 1 RF antenna input
  • Channel scan, channel recall, closed-caption display
  • Offers V-Chip parental control, sleep timer, auto-off, and a full-function remote control
Technical Details
  • Brand Name: Apex
  • Model: AT2702
  • Display Technology: CRT
  • Display Size: 27 inches
  • Image Aspect Ratio: 4:3
  • Speakers Included: 2 speakers
  • Height: 18.7 inches
  • Width: 29.5 inches
  • Depth: 23.2 inches
  • Weight: 88.2 pounds
Jan 27, 2011 | Apex Digital AT2702 27" TV
When we turn on the TV it goes to standby and will not change
Switch mode power supply is shutting it down,,this is a protection mode and standby light shows it is still working,,most likley it has a horiz sweep failure,,if you know how I would check the Horiz output to see if it is shorted,,if so replace and if you have equipment bring it up at around 80 volts and see if current is excessive ,if it is you possible have a horiz sweep transformer gone bad, this is most likley problem but could be somthing else but this is where I would start,,35 years experenice in this field and today I despise working on big screens,,kinda burnt out .You might also note that the tubes have not leaked onto the board as there is some models done this,,you will see corrision on boards if this has happened
From Wendell
Aug 04, 2009 | Sony KP-61V90 61" Rear Projection...
Vertical line from document feeder
there is probably a dirt spot on the scanner glass where the document feeds in. try cleaning the thin glass under the document feed cover.
Apr 24, 2009 | HP Officejet J5780 All-In-One Printer
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
Color bar
Sounds like the TV is defective, if I were you I would take it back. There probably isn't much you can do on your own to fix it.
Jan 08, 2009 | Televison & Video
TV went "pop"
prob not worth repair sounds like horiz sweep circuit. 150 200 to repair.
Nov 30, 2008 | Zenith A32B41W 32" TV
No picture, vertial lines w/many colors, snow
lg plasma tv is not for a novice to play with. the three main circuit boards are control. y and z sustain and they are not repairable
find a shop that can replace the defective one for you.
May 17, 2008 | LG 42PX5D 42 in. Plasma HDTV
Convergence
You need sevice code to enter convergence.
Mar 27, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Service Mode for Apex PF2720
On a standard PU1 chassis use the following:
1. Decrease the volume to 0
2. On remote press and hold the MUTE button till the color of MUTE displayed changes color. At the same time press MENU on the front of the Tv.
CH +/- to select
Vol +/- to change value
All other chassis:
Decrease the volume to 0, Press mute and video at the same time.
Adjust the TV with menu select buttons on remote.
Exit with the power button.
Hope this helps.
Bill
Nov 25, 2007 | Apex Digital PF2720 27" TV
Toshiba 36afx61 tv
You have a cold solder connection on the vertical output IC or in the sweep power supply that feeds the voltages to the vertical output IC. You can download a service manual from here: http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=36AFX61 Good Luck
Apr 27, 2007 | Toshiba 36AFX61 36" TV
Televison & Video Logo
218 people viewed this question
Top Televison & Video Experts
