Question about Kenmore 44042 Front Load Washer
Kenmore 417 front load washer
I have grease spots on my clothes and I am assuming it is a bearing problem. My drum moves back and forth when I still my finger in between the drum.
Do I call a repairman out or do I just buy a new washer??
I hate to pay a repairman for him to say it would be cheaper to buy a new washer.
I have grease stains on my clothes, black rubber on washer was full of mold, I cleaned it best I can, was this the problem my clothes are getting ruined
Posted on Oct 24, 2008
    Brigadier General:
  • 6,966 Answers
Normally when the bearing goes, it was most likely caused initially by a damaged water seal that allowed water to reach the bearing. If this has been going on for sometime, then there is also the possibility of the shaft being worn out. Repair or replace decision would have to be done after a visual inspection. Additionally, pls bear in mind that:
  • bearing replacement would require removal of the entire rear half of the tub, less than 100USD;
  • a press would be needed to install the new bearing (if ever available solo);
  • not difficult repair job but very time consuming;
  • often the bearing is available only as part of the whole shell (with spin tub inside) and bearing assembly probably between 150~250USD ?part #134453200? tub ***'y.
Based on all of the above and the result(s) of your visual inspection, then repair or replace could then be made.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 17, 2008
Leaves spots on my clothes
Kathy, you may have the beginnings of a tub bearing failure. What usually happens is the water seal fails on the tub drum shaft. This lets water into the bearing cavity and usually some grease migrates out into the drum. What eventually happens is the wash water eventually washes the grease out of the bearings and they fail. You will notice your spin cycle getting louder and louder.
You can check for a loose tub bearing by lifting the drum gently at the top. Is there play where the drum can move vertically, independently of the outer assembly? That's my guess. You can do an internet search about tub bearing replacement if you want to get into that. Its doable, depending on your skill level. Good luck.
Been there and done that. Usually Frigidaire doesn't sell the bearings, but they are standard bearings and you can usually match up a seal.
Mar 17, 2014 | Frigidaire GLTR1670A Front Load Washer
We bought a kenmore front loading heavy duty washing machine with 2-way tumble in Feb 2003. Recently two problems have become evident. First, our clothes have started to have black marks (streaks and...
Likely the cause is grease from a failing rear bearing.
Unfortunately, it's cheaper to buy a new washer than to fix this one. That's pathetic for a washer that's only 8 years old, and completely negates any environmental and economic benefits of buying a front loader.
Jan 29, 2011 | Kenmore 44102 Front Load Washer
I get oil/grease spots on my laundry ffrom my
You probably have a bad seal on the back of the drum, as that bearing is the only source of grease near your clothes. Good luck.
Jan 03, 2010 | Frigidaire GLTF1670A Front Load Washer
My kenmore washer front load is leaving stains that look like soap spots or grease (not black) on my dark colored clothes red blue green navy I don't use fabric softner and I use less than half of the...
periodically this has happened in a white sheet wash in my kenmore front loader series 417. we ran the washer empty with washer cleaner and blackish water was ejected from the pump. Another site suggests mildew under the drum . I am wondering if some oil from the unit is leaking in on a high spin cycle where the load is too full.
Oct 29, 2009 | Kenmore Washing Machines
Brown spots on clothes
Brown spots indicates a bearing is breaking up, the spots are the grease from the bearing and as the seal breaks down due to the bearings going off centre, the grease gets in the drum.
Get the bearings replaced if affordable.
Jul 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Grease/dark spots on 'clean' clothes
This is a cronic problem of front loader machines. The two bearings that hold the wash drum are dried out and then they over heat. The heat build up weakens the seal that keeps water in and grease out starts to leak and the problem just becomes worse with every load. A service repair man will charge you the cost of a new machine to fix the unit. You can replace the bearings and seal with parts from a bearing supply store and if you do, only use bearings from Japan or Germany. Your machine came with ones from China and that is why these machines are failing after 4 years.
May 24, 2009 | Kenmore 46462 Front Load Washer
Spots on my clothes
hi, your drum bearing needs replacing, hope this helps, thanks for using fixya
Feb 15, 2009 | Kenmore Elite 45986 Front Load Washer
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Jan 18, 2009 | Kenmore 44102 Front Load Washer
Kenmore 44042 Front Load Washer Logo
367 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
