Question about Pioneer Audio Players & Recorders
I have an older style Pioneer Stereo Hi-Fi set consisting of a Tuner/Synthesizer (F-X88Z) Double Cassette (DC-X88Z) CD Stacker (PD-Z83M) all contained in a cradle with a separate record turntable. The system needs a good overhaul as I am having problems with the remote control (volume control does not work) Cassette Decks ( probably require new drive belts) and the tuner volume control cuts in and out (high/low volume, from time to time). This can be rectified by turning on the light switch (would you believe?). I am disabled and need to contact an authorised repairer by telephone prior to taking the unit as it would be difficult for me to make mutiple trips to the repairers' workrooms. I have contacted Pioneer Australia who have given me the Bowen Hills address but they have been unable to put my call through to their Bowen Hills, Brisbane workshop. Is there anyone out there able to supply a telephone Number for the workshop or that of an alternative repairer. I live in Chapel Hill Brisbane and am most anxious to have the unit repaired as I rely on it greatly. Michael Bertram 07 3122 1040
SOURCE: Technics ST-X302L tuner - Unit not powering on
i have the same unit and a similar problem, after a fall of the tuner on the floor while i was cleaning my room, first times the st-x302l was powering fine but after some minuts it quit alone.. now (i dont know why) it remains on but if there is an interruption of electricity it dont turn on anymore, it turn on only by removing the metal chassis and moving random the electronics.. i think it has some electronic contact or circuit break.. i brought it to a specialist in electronics and he told me the reparation would be too expensive so i prefer to try fix it by myself.
Posted on Apr 10, 2008
SOURCE: kenwood stereo synthesizer tuner t-85l
T-85L is a component of a hifi system not suposed to work alone. You have to connect it to another Kenwood component (an amplifier like the A85 ) through a special cable to power it on/off. The special cable can be used point to point or as daisy-chained.
Posted on Sep 13, 2009
  • 4234 Answers
SOURCE: I own an AIWA Stereo Synthesizer Tuner which has a
Unfortunately without seeing the actual needle or cartridge, it is just about impossible to provide you with a part number. Where are you located? Needles are still available and I sell them all the time. I will try to locate the "standard" part number for your model, but there were often different setups available. Is there any way to provide a photo of the one you have now?
Check the balance of the tonearm as well. If there is not sufficient pressure on the needle, it won't track the record correctly either. Please note, the you shouldn't put too much pressure or you will wear the record.
Please keep us posted.
Thanks,
Dan
Posted on Sep 22, 2009
  • 336 Answers
SOURCE: pioneer digital tuner Z92 not working year 1989,
It may just need an adjustment. Check for audio in mono mode. If you get audio, then it needs an adjustment of the IF can. If still no audio pioneer commonly used an LM7001 14pin (might be16pins) IC, that goes bad.
Posted on Dec 31, 2009
Testimonial: "thank you so much John for info much appreciated, kind regards Michael."
SOURCE: Hello, I have found a Sansui
Hi!
I have the same deck. Did it come with rammophone or are you using your own grammophone?
I have it with original grammophone and I don't need a remote control, I don't even have it. You just turn on your grammophone and it is automatic, just place the needle on record and it should switch and play automatically. That is if you have connected the wires right (two wires for sound, one for automation, all in the same area).
If you have separate grammophone, I am assuming you just need to place two wires into the separate phono channels and it should work. There is just no automatic detection, so you have to swithc to mono manually: There is a button on the right, beside Volume control "tape to CD" or something.
To play the tape, just simply push the play button on the bottom, should work, or you could try tape to cd button off and see if it detects automatically when tape is inserted.
Currently I have it taken apart and there is tape detection system apparent. Its quite automated reciever, which sucks, because all kinds of problems appear and it is difficult to fix.
On my Sansui, the tape player starts winding slowly when pressed play button. And the tape motor seems to be on always, even when the tape is not used, and the motor is really loud. --Need to find a solution to this problem. And I hate it switch to radio/FM every time the record stops. Plus the original grammophone doesn't work correctly, it is supposed to take off the needle when record reaches an end, but it just pushes the neelde to the holder... over the record..... "screeeeech".
Posted on Dec 08, 2010
Where can I get a free manual
go on panasonic website or google the manual you want.i use manuals lib
Jul 02, 2014 | Technics Audio Players & Recorders
No disc error with pd-z83m
I had the same problem. I didn't clean the system I just got mad and inserted the cd holder really hard and smacked the radio a few times. Now it's working again. I suggest you do the same.
Sorry for my bad English.
Nov 14, 2012 | Pioneer Audio Players & Recorders
I´ve forgotten in what order I should connect my old (80´s) separate modul hifi system´s remote cables. It shuts down imadiatly when you try to start it with the remote. If I disconnect the...
I would have thought that it should go from the amp to the tuner,then the tape deck and finally the CD deck.
I'm suspecting that your tuner is faulty and thats whats causing the system to shut down
Aug 27, 2010 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
DC - F170U Sanyo Stero can not use radio tuner will not go to any stations how do I correct this
Does anyone have a user manual for a Sanyo Mini Hi Fi cassette / CD player, model DC-F170U. If you can help please reply to email, brandy.cherry@yahoo.com.au Thanks Cherry.
Aug 13, 2009 | Sanyo Audio Players & Recorders
I need cables for a 1991 Panasonic shelf audio system
Hi Will, I searched for flat cables ,seem to no longer be stocked. If you are interested in selling the whole system let me know. I have one working condition with cables, would like to have spare units(parts). I will check one more site on cables for you.
Contact Gregg at: GreggASef1@zoominternet.net
Feb 06, 2009 | Panasonic Audio Players & Recorders
I have a Pioneer SX 251R and a PD M501
How about a Pioneer CT-W302R stereo double cassette deck ?
I have a unit in very good condition for sale.
lftremblay@hotmail.com
Feb 16, 2008 | Pioneer SX-205 Receiver
100 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
